shivansps
Hotspot can get internet from a diferent gateway?
Tue Oct 03, 2017 2:04 am
It is possible to change it so instead of using the main enabled gateway for internet, to use a secondary gateway for internet? Like the one i use for failover? I know it can be done using a external proxy for example, but then i have no idea of how website control whould work. i whould preffer to use the built-in proxy.
wfuzatto
Re: Hotspot can get internet from a diferent gateway?
Tue Oct 03, 2017 6:17 am
Yes, my set is running on:
1 - masquarade both links.
2 - use distance 2+ on route table for the backup link.
3 - use a script on netwatch to disable the main gateway when it goes offline.
4 - use a defined route that your netwatch will monitor the main link.
5 - use a stable public ip to ping your link.
Users browsing this forum: anav, Baidu [Spider], m1m1, torstorm and 171 guests
