I have following network topology.
LAN clients gets ip's from main Cisco switch dhcp which have vlan assigned and intervlan ip routing is enabled. all vlan clients can communicate with each other using there dhcp ips because all clients have there default gateway pointed to there local vlan interfaces ip's.
This switch trunk port is connected with the mikrotik which is acting as pppoe server. As soon as client dials the pppoe dialer (as per policy user must dialer pppoe dialer for tracking/accounting purposes), there local vlan traffic starts to pass/route via mikrotik router which puts high load dueto heavy media sharing used by vlan clients with each other.
How can I force my pppoe clients to use local switch for there local traffic.
