MUM Europe 2020
OlofL
LTE Huawei E3372?
Fri Oct 20, 2017 4:37 pm
I cannot get this one started.
Interface LTE shows nothing.
Nothing in logs.
RouterOS 6.41RC47.
Ubuntu reports this as
[23892.376108] usb 2-3.2: new high-speed USB device number 13 using xhci_hcd
[23892.481169] usb 2-3.2: New USB device found, idVendor=12d1, idProduct=1f01
[23892.481172] usb 2-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23892.481174] usb 2-3.2: Product: HUAWEI_MOBILE
[23892.481176] usb 2-3.2: Manufacturer: HUAWEI_MOBILE
[23894.424106] usb 2-3.2: new high-speed USB device number 14 using xhci_hcd
[23894.529062] usb 2-3.2: New USB device found, idVendor=12d1, idProduct=14dc
[23894.529065] usb 2-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[23894.529067] usb 2-3.2: Product: HUAWEI_MOBILE
[23894.529069] usb 2-3.2: Manufacturer: HUAWEI_MOBILE
uldis
Re: LTE Huawei E3372?
Fri Oct 20, 2017 5:38 pm
on which board you test that?
Check if the usb port is added under system ports.
OlofL
Mon Oct 23, 2017 9:59 am
RB2011.
And no, nothing under system ports. Just the serial interface.
irghost
Mon Oct 23, 2017 10:46 am
just Unplug Power wait few seconds then plug it back
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
OlofL
Mon Oct 23, 2017 11:13 am
Nope.
Model		2011UiAS
Serial Number		4CA904EC4A14
Firmware Type		ar9344
Factory Firmware		3.10
Current Firmware		3.41
Version		6.41rc47 (testing)
And
/port> print
Flags: I - inactive
 #   DEVICE NAME                         CHANNELS USED-BY                       BAUD-RATE
 0          serial0                             1 Serial Console                auto
OlofL
Mon Oct 23, 2017 2:26 pm
It's weird. I got it up running once. It showed up under /interface lte
But then I had to unplug the device, and now its not showing up again.
Have tried reboot router and unplug a couple of times without success.
irghost
Re: LTE Huawei E3372?  [SOLVED]
Mon Oct 23, 2017 7:08 pm
are you using original OTG?
OlofL
Tue Oct 24, 2017 2:00 pm
This was probably it. I was using a one dollar china cable :)
Users browsing this forum: bobrovski, MSN [Bot] and 116 guests
