mjz
Problem with PPTP Server
Wed Oct 25, 2017 10:46 am
Hi Fellas
I'm using mikrotik pptp server for connecting to my thin client agents. most of them are working perfectly. Sometimes they get disconnected and after a while I get a lot of established connections from that client ip address ! but no tunnel whatsoever
and this is my connections from firewall
As you see this happening to me and I don't no what to do ! my agents are Debian and i'm using pptp-linux package for my client side connections. right now I have over 50 client connected to server but sometimes for some reason that I have no idea what it is, I get this for some users and it's going on and on and on. I don't have any physical access to client side. I just sit here and pray for gods that something happen to the power of thin client so it's get restarted ...
Can anybody help me ?!!
Shine on ...
There's a hunger still unsatisfied ...
Pink Floyd
MTCNA ===> DONE
MTCWE ===> DONE
MTCRE ===> DONE
MTCTCE ===> DONE
MTCUME ===> ------
MTCINE ===> ------
Anumrak
Re: Problem with PPTP Server
Thu Oct 26, 2017 11:22 am
Seems like they're behind NAPT(this is why one IP but different ports keep popping up) and the connectivity is really bad. They trying to connect over and over again. Check the physical connections from them, maybe there is a broken cables or something.
mjz
Fri Oct 27, 2017 9:12 pm
Nah everything is okay...
cabling, connection, devices and etc...
Pink Floyd
MTCNA ===> DONE
MTCWE ===> DONE
MTCRE ===> DONE
MTCTCE ===> DONE
MTCUME ===> ------
MTCINE ===> ------
mjz
Sat Oct 28, 2017 1:14 pm
Up Up Up
Pink Floyd
MTCNA ===> DONE
MTCWE ===> DONE
MTCRE ===> DONE
MTCTCE ===> DONE
MTCUME ===> ------
MTCINE ===> ------
Users browsing this forum: Bing [Bot], Google [Bot], sindy, SteveM2, tikker and 233 guests
