MUM Europe 2020
dakobg
Hex v3 ( RB750Gr3 ) EoIP/IPsec
Mon Nov 06, 2017 9:10 am
I'm new in the forum, I have a quick question for hex and EoIP.
If we use EoIP and IPsec (aes-128-cbc) is this will use hardware acceleration for encryption in hex ?
From what I check hw accerl. should work just I need a confirmation.
Paternot
Long time Member
Long time Member
Re: Hex v3 ( RB750Gr3 ) EoIP/IPsec
Mon Nov 06, 2017 1:28 pm
Yes, it should.
Anumrak
Tue Nov 07, 2017 11:25 am
Yes, it will. In IPsec menu in security associations(I think) you can find a symbol of hardware encryption. Try to find it out there.
markmcn
Fri Nov 10, 2017 5:59 pm
I believe it should use the hardware offloading for the IPSec,
However I'm thinking the EOIP will be CPU bound, It can be fast path however will still depend on cpu for encapsulation. If some knows otherwise please share
idlemind
Fri Nov 10, 2017 6:38 pm
If you don't actually need the functionality of EoIP (tunneling layer 2) then you could use straight IPSec tunnel mode and maintain an accelerated state with little overhead from the tunneling action.
dakobg
Fri Jan 05, 2018 10:20 am
Sorry for late reply, Happy new year to every one.
Just for info, EoIP/IPsec and hex (r3) use hw encryption
Users browsing this forum: No registered users and 124 guests
