lapsio
NATing entire subnet to bridge colliding address spaces
Tue Nov 07, 2017 2:18 am
I have 2 sites with own infrastructures. I'd like to connect them using VPN however unfortunately networks semantically the same (ones that should be bridged) have different address spaces so for example:
site1---site2
192.168.2.0/24---172.16.14.0/24
192.168.4.0/24---172.30.130.0/24
192.168.3.0/24---192.168.1.0/24
192.168.1.0/24---172.30.4.0/24
Would it be possible to map those networks 1:1 (they're the same size) and bridge them using ovpn implementation in ROS?
MTCNA, MTCRE, MTCINE
idlemind
Re: NATing entire subnet to bridge colliding address spaces
Tue Nov 07, 2017 2:31 am
Search my posts for double NAT you should find an example of doing this. It can be done with any VPN method. You mind OVPN in MikroTik limiting I think it's still TCP only.
Users browsing this forum: No registered users and 84 guests
