ukzerosniper
CAPsMAN Bug (I think)
Tue Nov 07, 2017 10:10 pm
I have an RB2011 and a hAP AC lite.
I have setup CAPsMAN on the RB2011. The hAP AC lite is a CAP.
I created 2 sets of channels, 1 for 2.4 and 1 for 5 named "2.4GHz" and "5GHz" respectivly. The 2.4GHz channels I added a number of frequency's and set the extension to Ce. The 5GHz channels I also added a number of frequency's, I also added the band 5ghz-onlyac and Extension Channel Ceee.
I created 2 configurations with the same names. I gave them the SSIDS "MikroTik" and "MikroTik 5G". I added the Channels I created to the configs.
I then created 2 sets of provisioning rules. In
set one I set it up for the 2.4GHz radios with the following configuration
Hardware supported : an
Action : create dynamic enabled
Master config : 2.4GHz
Name format : identity
set two I set up for 5GHz radios with the following configuration
Hardware supported : ac
Action : Create dynamic enabled
Master Configuration : 5GHz
I set the radio mac on both to 00:00:00:00:00:00
The 2.4GHz profile was first in the list. This resulted in the 2.4GHz radios being added, but the 5GHz radios just said, no band support.
When I created a provisioning rule specifically for each radio and added the individual MACs, everything worked. However, the 2nd wlan on the hAP lite is added as "cap2", it does not follow the correct naming format.
matiaszon
Re: CAPsMAN Bug (I think)
Tue Nov 07, 2017 11:03 pm
hAP lite doesn't support 5 GHz, as it doesn't have such a radio.
Here is the spec
https://mikrotik.com/product/RB941-2nD-TC
ukzerosniper
Tue Nov 07, 2017 11:52 pm
Sorry, its a hAP AC lite. Ill edit the OP for clarity. Thanks for point that out.
Users browsing this forum: Google [Bot] and 126 guests
