aaronw
IPSec xauth with Linux NetworkManager
Tue Nov 14, 2017 5:35 am
Hi all,
I finally managed to get IPSec with xauth working with my Android devices after a lot of experimentation but I have been unable to get my Linux laptop to connect. One difference is that NetworkManager on my laptop insists on the group identifier field being filled out. As far as I can tell this is the same as the Android IPSec identifier field. It looks like RouterOS doesn't support this since I have to leave this blank on my Android devices. Are there any plans to add support this or are there any known workarounds? BTW, I'm running OpenSuse Tumbleweed.
Here is my setup for Android support (works with Oreo)
/ip ipsec peer
add address=0.0.0.0/0 local-address=xxx.yy.aaa.zz passive=yes auth-method=pre-shared-key-xauth secret="group-secret-pw" generate-policy=port-strict
       policy-template-group=default exchange-mode=main mode-config=request-only send-initial-contact=yes nat-traversal=yes proposal-check=obey
       hash-algorithm=sha512 enc-algorithm=aes-256,aes-128 dh-group=ec2n185,ec2n155,modp2048,modp1024 lifetime=8h dpd-interval=2m dpd-maximum-failures=5
/ip ipsec policy
add group=default src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all proposal=default template=yes
/ip ipsec proposal
add name="default" auth-algorithms=sha512,sha256,sha1 enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=8h pfs-group=modp2048
/ip ipsec user
add name=loginname password="userpassword"
Nowhere do I see any option to set a group name or identifier in Routeros. I'm running 6.40
-Aaron
emils
Re: IPSec xauth with Linux NetworkManager
Tue Nov 14, 2017 8:54 am
Xauth group parameters are currently ignored by default. What error messages do you see in the RouterOS log when trying to connect? If you are using the "Cisco Compatible VPN (vpnc)" it uses "aggressive" mode instead of "main".
aaronw
Thu Nov 16, 2017 9:03 am
I've given up with NetworkManager and am now trying to get Strongswan to work directly but phase 1 negotiation keeps failing. I attempted to set StrongSwan to use the same rules that work with Android but phase 1 keeps failing. Any idea what could be wrong?
Here's my ipsec.conf:
# ipsec.conf - strongSwan IPsec configuration file
# basic configuration
config setup
        # strictcrlpolicy=yes
        # uniqueids = no
        charondebug="ike 1, knl 1, cfg 0"
        uniqueids=no
# Add connections here.
# Sample VPN connections
#conn sample-self-signed
#      leftsubnet=10.1.0.0/16
#      leftcert=selfCert.der
#      leftsendcert=never
#      right=192.168.0.2
#      rightsubnet=10.2.0.0/16
#      rightcert=peerCert.der
#      auto=start
#conn sample-with-ca-cert
#      leftcert=myCert.pem
#      right=192.168.0.2
#      rightid="C=CH, O=Linux strongSwan CN=peer name"
#      auto=start
conn home-base
    left=%any
    leftfirewall=yes
    right=1.2.3.4 (my external public IP (not my actual IP))
    auto=add
    type=transport
conn Home
    also=home-base
    dpdaction=restart
    dpddelay=30s
    dpdtimeout=120s
    fragmentation=accept
    keyexchange=ikev1
    ah=sha512-sha256-modp2048-modp1024
    ike=aes256-sha512-modp2048,aes128-sha256-modp2048,aes128-sha256-modp1024,aes256-sha256-modp1024,aes256-sha512-modp1024
    ikelifetime=8h
    esp=aes256-sha512-modp2048,aes256-sha256-modp2048,aes256-sha512,aes256-sha256-modp1024,aes256-sha512-modp1024
    leftauth=psk
    rightauth=psk
    rightauth2=xauth
    lifetime=8h
    xauth_identity=xxxx (xauth login)
    xauth=client
    authby=xauthpsk
ipsec.secrets:
# ipsec.secrets
# This file holds the RSA private keys or the PSK preshared secrets for
# the IKE/IPsec authentication. See the ipsec.secrets(5) manual page.
1.2.3.4 %any : PSK "psk password"
1.2.3.4 xxxx (xauth login) : XAUTH "(xauth password)"
I'm getting the following error when connecting with StrongSwan:
nov/15 22:31:07 ipsec,debug ipsec: ===== received 384 bytes from xx.xxx.148.156[56269] to 1.2.3.4[500]
nov/15 22:31:07 ipsec,debug,packet ipsec: e3a47dfb 486cd7d2 00000000 00000000 01100200 00000000 00000180 0d000104
nov/15 22:31:07 ipsec,debug,packet ipsec: 00000001 00000001 000000f8 00010007 03000024 01010000 80010007 800e0100
nov/15 22:31:07 ipsec,debug,packet ipsec: 80020006 8004000e 8003fdea 800b0001 800c7080 03000024 02010000 80010007
nov/15 22:31:07 ipsec,debug,packet ipsec: 800e0080 80020004 8004000e 8003fdea 800b0001 800c7080 03000024 03010000
nov/15 22:31:07 ipsec,debug,packet ipsec: 80010007 800e0080 80020004 80040002 8003fdea 800b0001 800c7080 03000024
nov/15 22:31:07 ipsec,debug,packet ipsec: 04010000 80010007 800e0100 80020004 80040002 8003fdea 800b0001 800c7080
nov/15 22:31:07 ipsec,debug,packet ipsec: 03000024 05010000 80010007 800e0100 80020006 80040002 8003fdea 800b0001
nov/15 22:31:07 ipsec,debug,packet ipsec: 800c7080 03000024 06010000 80010007 800e0080 80020004 80040013 8003fdea
nov/15 22:31:07 ipsec,debug,packet ipsec: 800b0001 800c7080 00000018 07010000 80040013 8003fdea 800b0001 800c7080
nov/15 22:31:07 ipsec,debug,packet ipsec: 0d00000c 09002689 dfd6b712 0d000014 afcad713 68a1f1c9 6b8696fc 77570100
nov/15 22:31:07 ipsec,debug,packet ipsec: 0d000018 4048b7d5 6ebce885 25e7de7f 00d6c2d3 80000000 0d000014 4a131c81
nov/15 22:31:07 ipsec,debug,packet ipsec: 07035845 5c5728f2 0e95452f 00000014 90cb8091 3ebb696e 086381b5 ec427b1f
nov/15 22:31:07 ipsec,info respond new phase 1 (Identity Protection): 1.2.3.4[500]<=>xx.xxx.148.156[56269]
nov/15 22:31:07 ipsec,debug ipsec: begin.
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=1(sa) len=260
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=13(vid) len=12
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=13(vid) len=20
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=13(vid) len=24
nov/15 22:31:07 ipsec,debug ipsec: succeed.
nov/15 22:31:07 ipsec,debug ipsec: remote supports DPD
nov/15 22:31:07 ipsec,debug ipsec: total SA len=256
nov/15 22:31:07 ipsec,debug ipsec: 00000001 00000001 000000f8 00010007 03000024 01010000 80010007 800e0100
nov/15 22:31:07 ipsec,debug ipsec: 80020006 8004000e 8003fdea 800b0001 800c7080 03000024 02010000 80010007
nov/15 22:31:07 ipsec,debug ipsec: 800e0080 80020004 8004000e 8003fdea 800b0001 800c7080 03000024 03010000
nov/15 22:31:07 ipsec,debug ipsec: 80010007 800e0080 80020004 80040002 8003fdea 800b0001 800c7080 03000024
nov/15 22:31:07 ipsec,debug ipsec: 04010000 80010007 800e0100 80020004 80040002 8003fdea 800b0001 800c7080
nov/15 22:31:07 ipsec,debug ipsec: 03000024 05010000 80010007 800e0100 80020006 80040002 8003fdea 800b0001
nov/15 22:31:07 ipsec,debug ipsec: 800c7080 03000024 06010000 80010007 800e0080 80020004 80040013 8003fdea
nov/15 22:31:07 ipsec,debug ipsec: 800b0001 800c7080 00000018 07010000 80040013 8003fdea 800b0001 800c7080
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=2(prop) len=248
nov/15 22:31:07 ipsec,debug ipsec: proposal #0 len=248
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=3(trns) len=36
nov/15 22:31:07 ipsec,debug ipsec: seen nptype=3(trns) len=24
nov/15 22:31:07 ipsec,debug ipsec: transform #1 len=36
nov/15 22:31:07 ipsec,debug ipsec: type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
nov/15 22:31:07 ipsec,debug ipsec: encryption(aes)
nov/15 22:31:07 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=256
nov/15 22:31:07 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=6
nov/15 22:31:07 ipsec,debug ipsec: hash(sha2_512)
nov/15 22:31:07 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=2048-bit MODP group
nov/15 22:31:07 ipsec,debug ipsec: dh(modp2048)
nov/15 22:31:07 ipsec,debug ipsec: type=Authentication Method, flag=0x8000, lorv=XAuth pskey server
nov/15 22:31:07 ipsec,debug ipsec: transform #2 len=36
nov/15 22:31:07 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=128
nov/15 22:31:07 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=4
nov/15 22:31:07 ipsec,debug ipsec: hash(sha2_256)
nov/15 22:31:07 ipsec,debug ipsec: transform #3 len=36
nov/15 22:31:07 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=1024-bit MODP group
nov/15 22:31:07 ipsec,debug ipsec: dh(modp1024)
nov/15 22:31:07 ipsec,debug ipsec: transform #4 len=36
nov/15 22:31:07 ipsec,debug ipsec: transform #5 len=36
nov/15 22:31:07 ipsec,debug ipsec: transform #6 len=36
nov/15 22:31:07 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=19
nov/15 22:31:07 ipsec,debug ipsec: transform #7 len=24
nov/15 22:31:07 ipsec,error xx.xxx.148.156 failed to get valid proposal.
nov/15 22:31:07 ipsec,error xx.xxx.148.156 failed to pre-process ph1 packet (side: 1, status 1).
nov/15 22:31:07 ipsec,error xx.xxx.148.156 phase1 negotiation failed.
nov/15 22:31:11 ipsec,debug ipsec: ===== received 384 bytes from xx.xxx.148.156[56269] to 1.2.3.4[500]
nov/15 22:31:11 ipsec,debug,packet ipsec: e3a47dfb 486cd7d2 00000000 00000000 01100200 00000000 00000180 0d000104
nov/15 22:31:11 ipsec,debug,packet ipsec: 00000001 00000001 000000f8 00010007 03000024 01010000 80010007 800e0100
nov/15 22:31:11 ipsec,debug,packet ipsec: 80020006 8004000e 8003fdea 800b0001 800c7080 03000024 02010000 80010007
nov/15 22:31:11 ipsec,debug,packet ipsec: 800e0080 80020004 8004000e 8003fdea 800b0001 800c7080 03000024 03010000
nov/15 22:31:11 ipsec,debug,packet ipsec: 80010007 800e0080 80020004 80040002 8003fdea 800b0001 800c7080 03000024
nov/15 22:31:11 ipsec,debug,packet ipsec: 04010000 80010007 800e0100 80020004 80040002 8003fdea 800b0001 800c7080
nov/15 22:31:11 ipsec,debug,packet ipsec: 03000024 05010000 80010007 800e0100 80020006 80040002 8003fdea 800b0001
nov/15 22:31:11 ipsec,debug,packet ipsec: 800c7080 03000024 06010000 80010007 800e0080 80020004 80040013 8003fdea
nov/15 22:31:11 ipsec,debug,packet ipsec: 800b0001 800c7080 00000018 07010000 80040013 8003fdea 800b0001 800c7080
nov/15 22:31:11 ipsec,debug,packet ipsec: 0d00000c 09002689 dfd6b712 0d000014 afcad713 68a1f1c9 6b8696fc 77570100
nov/15 22:31:11 ipsec,debug,packet ipsec: 0d000018 4048b7d5 6ebce885 25e7de7f 00d6c2d3 80000000 0d000014 4a131c81
nov/15 22:31:11 ipsec,debug,packet ipsec: 07035845 5c5728f2 0e95452f 00000014 90cb8091 3ebb696e 086381b5 ec427b1f
nov/15 22:31:11 ipsec,info respond new phase 1 (Identity Protection) 1.2.3.4[500]<=>xx.xxx.148.156[56269]
nov/15 22:31:11 ipsec,debug ipsec: begin.
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=1(sa) len=260
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=13(vid) len=12
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=13(vid) len=20
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=13(vid) len=24
nov/15 22:31:11 ipsec,debug ipsec: succeed.
nov/15 22:31:11 ipsec,debug ipsec: remote supports DPD
nov/15 22:31:11 ipsec,debug ipsec: total SA len=256
nov/15 22:31:11 ipsec,debug ipsec: 00000001 00000001 000000f8 00010007 03000024 01010000 80010007 800e0100
nov/15 22:31:11 ipsec,debug ipsec: 80020006 8004000e 8003fdea 800b0001 800c7080 03000024 02010000 80010007
nov/15 22:31:11 ipsec,debug ipsec: 800e0080 80020004 8004000e 8003fdea 800b0001 800c7080 03000024 03010000
nov/15 22:31:11 ipsec,debug ipsec: 80010007 800e0080 80020004 80040002 8003fdea 800b0001 800c7080 03000024
nov/15 22:31:11 ipsec,debug ipsec: 04010000 80010007 800e0100 80020004 80040002 8003fdea 800b0001 800c7080
nov/15 22:31:11 ipsec,debug ipsec: 03000024 05010000 80010007 800e0100 80020006 80040002 8003fdea 800b0001
nov/15 22:31:11 ipsec,debug ipsec: 800c7080 03000024 06010000 80010007 800e0080 80020004 80040013 8003fdea
nov/15 22:31:11 ipsec,debug ipsec: 800b0001 800c7080 00000018 07010000 80040013 8003fdea 800b0001 800c7080
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=2(prop) len=248
nov/15 22:31:11 ipsec,debug ipsec: proposal #0 len=248
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=3(trns) len=36
nov/15 22:31:11 ipsec,debug ipsec: seen nptype=3(trns) len=24
nov/15 22:31:11 ipsec,debug ipsec: transform #1 len=36
nov/15 22:31:11 ipsec,debug ipsec: type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
nov/15 22:31:11 ipsec,debug ipsec: encryption(aes)
nov/15 22:31:11 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=256
nov/15 22:31:11 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=6
nov/15 22:31:11 ipsec,debug ipsec: hash(sha2_512)
nov/15 22:31:11 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=2048-bit MODP group
nov/15 22:31:11 ipsec,debug ipsec: dh(modp2048)
nov/15 22:31:11 ipsec,debug ipsec: type=Authentication Method, flag=0x8000, lorv=XAuth pskey server
nov/15 22:31:11 ipsec,debug ipsec: transform #2 len=36
nov/15 22:31:11 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=128
nov/15 22:31:11 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=4
nov/15 22:31:11 ipsec,debug ipsec: hash(sha2_256)
nov/15 22:31:11 ipsec,debug ipsec: transform #3 len=36
nov/15 22:31:11 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=1024-bit MODP group
nov/15 22:31:11 ipsec,debug ipsec: dh(modp1024)
nov/15 22:31:11 ipsec,debug ipsec: transform #4 len=36
nov/15 22:31:11 ipsec,debug ipsec: transform #5 len=36
nov/15 22:31:11 ipsec,debug ipsec: transform #6 len=36
nov/15 22:31:11 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=19
nov/15 22:31:11 ipsec,debug ipsec: transform #7 len=24
nov/15 22:31:11 ipsec,error xx.xxx.148.156 failed to get valid proposal.
nov/15 22:31:11 ipsec,error xx.xxx.148.156 failed to pre-process ph1 packet (side: 1, status 1).
nov/15 22:31:11 ipsec,error xx.xxx.148.156 phase1 negotiation failed.
Now this works fine with my Android client configured to use XAUTH PSK. In this case I have the server address set to 1.2.3.4, the IPSec identifier blank, the xauth user and password set to the values I use in /ip ipsec users (and ipsec.secrets).
Here's the log with a successful connection with Android:
nov/15 22:44:31 ipsec,debug ipsec: ===== received 756 bytes from xx.xxx.148.156[23059] to 1.2.3.4[500]
nov/15 22:44:31 ipsec,debug,packet ipsec: 54878e47 70d12b0d 00000000 00000000 01100200 00000000 000002f4 0d00023c
nov/15 22:44:31 ipsec,debug,packet ipsec: 00000001 00000001 00000230 01010010 03000024 01010000 800b0001 800c7080
nov/15 22:44:31 ipsec,debug,packet ipsec: 80010007 800e0100 8003fde9 80020005 80040002 03000024 02010000 800b0001
nov/15 22:44:31 ipsec,debug,packet ipsec: 800c7080 80010007 800e0100 8003fde9 80020004 80040002 03000024 03010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010007 800e0100 8003fde9 80020006 80040002 03000024
nov/15 22:44:31 ipsec,debug,packet ipsec: 04010000 800b0001 800c7080 80010007 800e0100 8003fde9 80020002 80040002
nov/15 22:44:31 ipsec,debug,packet ipsec: 03000024 05010000 800b0001 800c7080 80010007 800e0100 8003fde9 80020001
nov/15 22:44:31 ipsec,debug,packet ipsec: 80040002 03000024 06010000 800b0001 800c7080 80010007 800e0080 8003fde9
nov/15 22:44:31 ipsec,debug,packet ipsec: 80020006 80040002 03000024 07010000 800b0001 800c7080 80010007 800e0080
nov/15 22:44:31 ipsec,debug,packet ipsec: 8003fde9 80020005 80040002 03000024 08010000 800b0001 800c7080 80010007
nov/15 22:44:31 ipsec,debug,packet ipsec: 800e0080 8003fde9 80020004 80040002 03000024 09010000 800b0001 800c7080
nov/15 22:44:31 ipsec,debug,packet ipsec: 80010007 800e0080 8003fde9 80020002 80040002 03000024 0a010000 800b0001
nov/15 22:44:31 ipsec,debug,packet ipsec: 800c7080 80010007 800e0080 8003fde9 80020001 80040002 03000020 0b010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010005 8003fde9 80020004 80040002 03000020 0c010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010005 8003fde9 80020002 80040002 03000020 0d010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010005 8003fde9 80020001 80040002 03000020 0e010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010001 8003fde9 80020004 80040002 03000020 0f010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010001 8003fde9 80020002 80040002 00000020 10010000
nov/15 22:44:31 ipsec,debug,packet ipsec: 800b0001 800c7080 80010001 8003fde9 80020001 80040002 0d000014 4a131c81
nov/15 22:44:31 ipsec,debug,packet ipsec: 07035845 5c5728f2 0e95452f 0d000014 cd604643 35df21f8 7cfdb2fc 68b6a448
nov/15 22:44:31 ipsec,debug,packet ipsec: 0d000014 90cb8091 3ebb696e 086381b5 ec427b1f 0d000014 4485152d 18b6bbcd
nov/15 22:44:31 ipsec,debug,packet ipsec: 0be8a846 9579ddcc 0d00000c 09002689 dfd6b712 0d000014 12f5f28c 457168a9
nov/15 22:44:31 ipsec,debug,packet ipsec: 702d9fe2 74cc0100 0d000018 4048b7d5 6ebce885 25e7de7f 00d6c2d3 80000000
nov/15 22:44:31 ipsec,debug,packet ipsec: 00000014 afcad713 68a1f1c9 6b8696fc 77570100
nov/15 22:44:31 ipsec,info respond new phase 1 (Identity Protection): 1.2.3.4[500]<=>xx.xxx.148.156[23059]
nov/15 22:44:31 ipsec,debug ipsec: begin.
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=1(sa) len=572
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=13(vid) len=20
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=13(vid) len=12
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=13(vid) len=24
nov/15 22:44:31 ipsec,debug ipsec: succeed.
nov/15 22:44:31 ipsec,debug ipsec: remote supports DPD
nov/15 22:44:31 ipsec,debug ipsec: total SA len=568
nov/15 22:44:31 ipsec,debug ipsec: 00000001 00000001 00000230 01010010 03000024 01010000 800b0001 800c7080
nov/15 22:44:31 ipsec,debug ipsec: 80010007 800e0100 8003fde9 80020005 80040002 03000024 02010000 800b0001
nov/15 22:44:31 ipsec,debug ipsec: 800c7080 80010007 800e0100 8003fde9 80020004 80040002 03000024 03010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010007 800e0100 8003fde9 80020006 80040002 03000024
nov/15 22:44:31 ipsec,debug ipsec: 04010000 800b0001 800c7080 80010007 800e0100 8003fde9 80020002 80040002
nov/15 22:44:31 ipsec,debug ipsec: 03000024 05010000 800b0001 800c7080 80010007 800e0100 8003fde9 80020001
nov/15 22:44:31 ipsec,debug ipsec: 80040002 03000024 06010000 800b0001 800c7080 80010007 800e0080 8003fde9
nov/15 22:44:31 ipsec,debug ipsec: 80020006 80040002 03000024 07010000 800b0001 800c7080 80010007 800e0080
nov/15 22:44:31 ipsec,debug ipsec: 8003fde9 80020005 80040002 03000024 08010000 800b0001 800c7080 80010007
nov/15 22:44:31 ipsec,debug ipsec: 800e0080 8003fde9 80020004 80040002 03000024 09010000 800b0001 800c7080
nov/15 22:44:31 ipsec,debug ipsec: 80010007 800e0080 8003fde9 80020002 80040002 03000024 0a010000 800b0001
nov/15 22:44:31 ipsec,debug ipsec: 800c7080 80010007 800e0080 8003fde9 80020001 80040002 03000020 0b010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010005 8003fde9 80020004 80040002 03000020 0c010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010005 8003fde9 80020002 80040002 03000020 0d010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010005 8003fde9 80020001 80040002 03000020 0e010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010001 8003fde9 80020004 80040002 03000020 0f010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010001 8003fde9 80020002 80040002 00000020 10010000
nov/15 22:44:31 ipsec,debug ipsec: 800b0001 800c7080 80010001 8003fde9 80020001 80040002
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=2(prop) len=560
nov/15 22:44:31 ipsec,debug ipsec: proposal #1 len=560
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=3(trns) len=36
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=3(trns) len=32
nov/15 22:44:31 ipsec,debug ipsec: transform #1 len=36
nov/15 22:44:31 ipsec,debug ipsec: type=Life Type, flag=0x8000, lorv=seconds
nov/15 22:44:31 ipsec,debug ipsec: type=Life Duration, flag=0x8000, lorv=28800
nov/15 22:44:31 ipsec,debug ipsec: type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
nov/15 22:44:31 ipsec,debug ipsec: encryption(aes)
nov/15 22:44:31 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=256
nov/15 22:44:31 ipsec,debug ipsec: type=Authentication Method, flag=0x8000, lorv=GSS-API on Kerberos 5
nov/15 22:44:31 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=5
nov/15 22:44:31 ipsec,debug ipsec: transform #2 len=36
nov/15 22:44:31 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=4
nov/15 22:44:31 ipsec,debug ipsec: hash(sha2_256)
nov/15 22:44:31 ipsec,debug ipsec: type=Group Description, flag=0x8000, lorv=1024-bit MODP group
nov/15 22:44:31 ipsec,debug ipsec: dh(modp1024)
nov/15 22:44:31 ipsec,debug ipsec: transform #3 len=36
nov/15 22:44:31 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=6
nov/15 22:44:31 ipsec,debug ipsec: hash(sha2_512)
nov/15 22:44:31 ipsec,debug ipsec: transform #4 len=36
nov/15 22:44:31 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=SHA
nov/15 22:44:31 ipsec,debug ipsec: hash(sha1)
nov/15 22:44:31 ipsec,debug ipsec: transform #5 len=36
nov/15 22:44:31 ipsec,debug ipsec: type=Hash Algorithm, flag=0x8000, lorv=MD5
nov/15 22:44:31 ipsec,debug ipsec: hash(md5)
nov/15 22:44:31 ipsec,debug ipsec: transform #6 len=36
nov/15 22:44:31 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=128
nov/15 22:44:31 ipsec,debug ipsec: transform #7 len=36
nov/15 22:44:31 ipsec,debug ipsec: transform #8 len=36
nov/15 22:44:31 ipsec,debug ipsec: transform #9 len=36
nov/15 22:44:31 ipsec,debug ipsec: transform #10 len=36
nov/15 22:44:31 ipsec,debug ipsec: transform #11 len=32
nov/15 22:44:31 ipsec,debug ipsec: type=Encryption Algorithm, flag=0x8000, lorv=3DES-CBC
nov/15 22:44:31 ipsec,debug ipsec: encryption(3des)
nov/15 22:44:31 ipsec,debug ipsec: transform #12 len=32
nov/15 22:44:31 ipsec,debug ipsec: transform #13 len=32
nov/15 22:44:31 ipsec,debug ipsec: transform #14 len=32
nov/15 22:44:31 ipsec,debug ipsec: type=Encryption Algorithm, flag=0x8000, lorv=DES-CBC
nov/15 22:44:31 ipsec,debug ipsec: encryption(des)
nov/15 22:44:31 ipsec,debug ipsec: transform #15 len=32
nov/15 22:44:31 ipsec,debug ipsec: transform #16 len=32
nov/15 22:44:31 ipsec,debug ipsec: pair 1:
nov/15 22:44:31 ipsec,debug ipsec:  0x48f440: next=(nil) tnext=0x48f5c8
nov/15 22:44:31 ipsec,debug ipsec:   0x48f5c8: next=(nil) tnext=0x48d680
nov/15 22:44:31 ipsec,debug ipsec:    0x48d680: next=(nil) tnext=0x48c1f8
nov/15 22:44:31 ipsec,debug ipsec:     0x48c1f8: next=(nil) tnext=0x491460
nov/15 22:44:31 ipsec,debug ipsec:      0x491460: next=(nil) tnext=0x4887d0
nov/15 22:44:31 ipsec,debug ipsec:       0x4887d0: next=(nil) tnext=0x48f2b0
nov/15 22:44:31 ipsec,debug ipsec:        0x48f2b0: next=(nil) tnext=0x48d728
nov/15 22:44:31 ipsec,debug ipsec:         0x48d728: next=(nil) tnext=0x48daf8
nov/15 22:44:31 ipsec,debug ipsec:          0x48daf8: next=(nil) tnext=0x48ea00
nov/15 22:44:31 ipsec,debug ipsec:           0x48ea00: next=(nil) tnext=0x48db28
nov/15 22:44:31 ipsec,debug ipsec:            0x48db28: next=(nil) tnext=0x48c840
nov/15 22:44:31 ipsec,debug ipsec:             0x48c840: next=(nil) tnext=0x48dd38
nov/15 22:44:31 ipsec,debug ipsec:              0x48dd38: next=(nil) tnext=0x48e900
nov/15 22:44:31 ipsec,debug ipsec:               0x48e900: next=(nil) tnext=(nil)
nov/15 22:44:31 ipsec,debug ipsec: proposal #1: 14 transform
nov/15 22:44:31 ipsec,debug ipsec: prop#=1, prot-id=ISAKMP, spi-size=0, #trns=16
nov/15 22:44:31 ipsec,debug ipsec: trns#=2, trns-id=IKE
nov/15 22:44:31 ipsec,debug ipsec: Compared: Local:Peer
nov/15 22:44:31 ipsec,debug ipsec: (lifetime = 28800:28800)
nov/15 22:44:31 ipsec,debug ipsec: (lifebyte = 0:0)
nov/15 22:44:31 ipsec,debug ipsec: enctype = AES-CBC:AES-CBC
nov/15 22:44:31 ipsec,debug ipsec: (encklen = 256:256)
nov/15 22:44:31 ipsec,debug ipsec: hashtype = 4:4
nov/15 22:44:31 ipsec,debug ipsec: authmethod = XAuth pskey server:GSS-API on Kerberos 5
nov/15 22:44:31 ipsec,debug ipsec: dh_group = 4096-bit MODP group:1024-bit MODP group
nov/15 22:44:31 ipsec,debug ipsec: dh_group = 3072-bit MODP group:1024-bit MODP group
nov/15 22:44:31 ipsec,debug ipsec: dh_group = 2048-bit MODP group:1024-bit MODP group
nov/15 22:44:31 ipsec,debug ipsec: dh_group = 1024-bit MODP group:1024-bit MODP group
nov/15 22:44:31 ipsec,debug ipsec: (encklen = 128:256)
nov/15 22:44:31 ipsec,debug ipsec: trns#=3, trns-id=IKE
nov/15 22:44:31 ipsec,debug ipsec: hashtype = 6:6
nov/15 22:44:31 ipsec,debug ipsec: an acceptable proposal found.
nov/15 22:44:31 ipsec,debug ipsec: agreed on XAuth pskey server auth.
nov/15 22:44:31 ipsec,debug ipsec: new cookie:
nov/15 22:44:31 ipsec,debug ipsec: ee0c3df5e8b5733d
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 52, next type 13
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 16, next type 13
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 8, next type 13
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 20, next type 0
nov/15 22:44:31 ipsec,debug ipsec: 180 bytes from 1.2.3.4[500] to xx.xxx.148.156[23059]
nov/15 22:44:31 ipsec,debug ipsec: 1 times of 180 bytes message will be sent to xx.xxx.148.156[23059]
nov/15 22:44:31 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 01100200 00000000 000000b4 0d000038
nov/15 22:44:31 ipsec,debug,packet ipsec: 00000001 00000001 0000002c 01010001 00000024 03010000 800b0001 800c7080
nov/15 22:44:31 ipsec,debug,packet ipsec: 80010007 800e0100 8003fde9 80020006 80040002 0d000014 4a131c81 07035845
nov/15 22:44:31 ipsec,debug,packet ipsec: 5c5728f2 0e95452f 0d00000c 09002689 dfd6b712 0d000014 12f5f28c 457168a9
nov/15 22:44:31 ipsec,debug,packet ipsec: 702d9fe2 74cc0100 0d000014 afcad713 68a1f1c9 6b8696fc 77570100 00000018
nov/15 22:44:31 ipsec,debug,packet ipsec: 4048b7d5 6ebce885 25e7de7f 00d6c2d3 80000000
nov/15 22:44:31 ipsec,debug ipsec: ===== received 316 bytes from xx.xxx.148.156[23059] to 1.2.3.4[500]
nov/15 22:44:31 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 04100200 00000000 0000013c 0a000084
nov/15 22:44:31 ipsec,debug,packet ipsec: 18e170e1 403f9577 829d0fdb c43f0e35 15ba5e75 47a06cc0 aa78c625 6ca8484d
nov/15 22:44:31 ipsec,debug,packet ipsec: ee859096 3b894632 c3af7a8d 149ba88e 4e861058 dbfb98d7 e53d7826 f4c6f5c2
nov/15 22:44:31 ipsec,debug,packet ipsec: cc051f5c dd81dc9e 4040f439 d9bbed8c cedcd788 81f4b07a 1fdbf468 424c6b15
nov/15 22:44:31 ipsec,debug,packet ipsec: 6ab1d148 937b887c a5cfb164 78f37580 347cc58c 1630dba2 c08e700b a3cd3379
nov/15 22:44:31 ipsec,debug,packet ipsec: 14000014 c18fe519 358336c1 709d1380 284b3a61 14000044 28446259 14cbdf27
nov/15 22:44:31 ipsec,debug,packet ipsec: 9da89315 15fb0d68 5cbac20b 39e5832a 7a037ef0 691056c4 826f9320 9668c15e
nov/15 22:44:31 ipsec,debug,packet ipsec: 6925d4cc 25617f0a 4d98014e 1bc940aa aa2a1f55 eb3ac676 00000044 e755b3d8
nov/15 22:44:31 ipsec,debug,packet ipsec: 7816db27 58f781d0 e3de7cf9 55b8a6cc 71d855f9 8a6843ad 7cde1e8d 614308b8
nov/15 22:44:31 ipsec,debug,packet ipsec: cece4dc1 5e91c2fc 6bfee603 c487120a 8dd3fb7c 0e8ee12d 6eeb4b15
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=4(ke) len=132
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=10(nonce) len=20
nov/15 22:44:31 ipsec,debug ipsec: seen nptype=20(nat-d) len=68
nov/15 22:44:31 ipsec,debug ipsec: compute DH's private.
nov/15 22:44:31 ipsec,debug ipsec: 66c586a9 e8041e28 34d3489d 883556bb 05c8625c fa95721c ea4dd546 5ab92fc4
nov/15 22:44:31 ipsec,debug ipsec: c329b720 3b2985f9 21c59cca 25636de7 8178425e 8b92677a 52070afb cbaadbc1
nov/15 22:44:31 ipsec,debug ipsec: 1c3f7fb0 cc0f187f aaadc983 0daae930 c501600c bc4af6f6 30f2cc81 771c0178
nov/15 22:44:31 ipsec,debug ipsec: ecf64e08 498bed50 3b562d0f b75017b9 9d25747b ce11a881 880f5d4a 0ff098c3
nov/15 22:44:31 ipsec,debug ipsec: compute DH's public.
nov/15 22:44:31 ipsec,debug ipsec: 191ed5cd 258a1d78 c3ba62f2 23fbeee4 bed3b45c 65d09cd8 ecf84c1f 93ef6dcb
nov/15 22:44:31 ipsec,debug ipsec: 3594330c 68fec16f b434d4f5 b273fdbd eede8776 d94e0ad8 5b569ceb a72b744d
nov/15 22:44:31 ipsec,debug ipsec: 09ec1533 6260381d b52f4ae1 8791ab9d d41c9932 bbb37f43 0156a8bf 1e754a62
nov/15 22:44:31 ipsec,debug ipsec: 2bfe8faf 987174b1 1fd9a725 09e79424 7b621641 e4647d6f 0691c7c6 e2a0cb65
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 128, next type 10
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 24, next type 20
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 64, next type 20
nov/15 22:44:31 ipsec,debug ipsec: add payload of len 64, next type 0
nov/15 22:44:31 ipsec,debug ipsec: 324 bytes from 1.2.3.4[500] to xx.xxx.148.156[23059]
nov/15 22:44:31 ipsec,debug ipsec: 1 times of 324 bytes message will be sent to xx.xxx.148.156[23059]
nov/15 22:44:31 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 04100200 00000000 00000144 0a000084
nov/15 22:44:31 ipsec,debug,packet ipsec: 191ed5cd 258a1d78 c3ba62f2 23fbeee4 bed3b45c 65d09cd8 ecf84c1f 93ef6dcb
nov/15 22:44:31 ipsec,debug,packet ipsec: 3594330c 68fec16f b434d4f5 b273fdbd eede8776 d94e0ad8 5b569ceb a72b744d
nov/15 22:44:31 ipsec,debug,packet ipsec: 09ec1533 6260381d b52f4ae1 8791ab9d d41c9932 bbb37f43 0156a8bf 1e754a62
nov/15 22:44:31 ipsec,debug,packet ipsec: 2bfe8faf 987174b1 1fd9a725 09e79424 7b621641 e4647d6f 0691c7c6 e2a0cb65
nov/15 22:44:31 ipsec,debug,packet ipsec: 1400001c d92dac31 38b12a40 605ee18e 67574fe8 4f333cfe a2c6be9c 14000044
nov/15 22:44:31 ipsec,debug,packet ipsec: 23970d09 9b284c37 169257ee b71896b1 30877f4a 2657c29e d36f8e60 cbf365e9
nov/15 22:44:31 ipsec,debug,packet ipsec: 335fab7f 9701399c b792acdd e83766af bccede3a f4fa973f 73cde5f6 206b32d3
nov/15 22:44:31 ipsec,debug,packet ipsec: 00000044 28446259 14cbdf27 9da89315 15fb0d68 5cbac20b 39e5832a 7a037ef0
nov/15 22:44:31 ipsec,debug,packet ipsec: 691056c4 826f9320 9668c15e 6925d4cc 25617f0a 4d98014e 1bc940aa aa2a1f55
nov/15 22:44:31 ipsec,debug,packet ipsec: eb3ac676
nov/15 22:44:32 ipsec,debug ipsec: compute DH's shared.
nov/15 22:44:32 ipsec,debug ipsec: f417d98b ccb126dd 5b02f7ed b90cfd17 84c319f7 856de400 31e4ec37 ea011b10
nov/15 22:44:32 ipsec,debug ipsec: 4048a92f 78eab385 4a8aeca3 4e055449 9e9a519e 96ee3f03 9af8c061 5101c57f
nov/15 22:44:32 ipsec,debug ipsec: d53335de ef1095fc 9b161316 108a3262 7e421fe2 0a9f8403 54efbc16 721db97b
nov/15 22:44:32 ipsec,debug ipsec: 7ed5325d a1b6dea5 c9c5b2fb 12d31a41 010ac4e3 6fcebf8f 19c01871 181bf77e
nov/15 22:44:32 ipsec,debug ipsec: nonce 1:
nov/15 22:44:32 ipsec,debug ipsec: c18fe519 358336c1 709d1380 284b3a61
nov/15 22:44:32 ipsec,debug ipsec: nonce 2:
nov/15 22:44:32 ipsec,debug ipsec: d92dac31 38b12a40 605ee18e 67574fe8 4f333cfe a2c6be9c
nov/15 22:44:32 ipsec,debug ipsec: hmac(hmac_sha2_512)
nov/15 22:44:32 ipsec,debug ipsec: SKEYID computed:
nov/15 22:44:32 ipsec,debug ipsec: 22cd60f6 1d7540a1 1ff59c14 1b4f3fbb bd1b5134 29b4f03f 71b99114 be0aa666
nov/15 22:44:32 ipsec,debug ipsec: 6096f1d0 b6b05abf f55e410c a59a3b80 f9e9367c e198ea81 cdeb68f3 1769b1a7
nov/15 22:44:32 ipsec,debug ipsec: SKEYID_d computed:
nov/15 22:44:32 ipsec,debug ipsec: 82bd8df5 bf1f5158 d7c8276f 9ff8e318 c30f26f0 24c1552d 94c6ce15 c2bad27a
nov/15 22:44:32 ipsec,debug ipsec: 61d0e0c0 89f71d8d 10c58521 cef03d26 13e6f637 15be4eeb 516ca1a4 973f5e02
nov/15 22:44:32 ipsec,debug ipsec: SKEYID_a computed:
nov/15 22:44:32 ipsec,debug ipsec: 2f858037 5dc2dbe6 b27c52a9 19873aff 3870ac08 29a0dcef e7e0841d 03bed397
nov/15 22:44:32 ipsec,debug ipsec: b892b530 1b60fb95 82384887 0f8bef08 15998ff0 7cdced94 b155d20c dba21398
nov/15 22:44:32 ipsec,debug ipsec: SKEYID_e computed:
nov/15 22:44:32 ipsec,debug ipsec: 3c793463 a8f770a5 664642cd 214842f2 4d1e4370 c93e16cd 2a34207d b9094992
nov/15 22:44:32 ipsec,debug ipsec: e4a9b933 7fdfaa28 e67fbbb7 d64e8e53 6d9c75eb a6671405 481ae606 601028ca
nov/15 22:44:32 ipsec,debug ipsec: encryption(aes)
nov/15 22:44:32 ipsec,debug ipsec: hash(sha2_512)
nov/15 22:44:32 ipsec,debug ipsec: final encryption key computed:
nov/15 22:44:32 ipsec,debug ipsec: IV computed:
nov/15 22:44:32 ipsec,debug ipsec: dbd07bb2 2fc6817a efecbf00 080d8f6e
nov/15 22:44:32 ipsec,debug ipsec: ===== received 140 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 05100201 00000000 0000008c 0ad1142c
nov/15 22:44:32 ipsec,debug,packet ipsec: 98d08ce0 056bda89 06160047 e430099a 4e355567 e218b4ee b3e5d3df ffea8517
nov/15 22:44:32 ipsec,debug,packet ipsec: ef70c0a5 382aac13 ecd30a7d ffe63581 4131a7e0 b15843d1 ba9c4346 bdd21144
nov/15 22:44:32 ipsec,debug,packet ipsec: 89654b19 98a4360e 1beebf21 70a257d0 2effd04b f8512e75 f1d1300b d431b5dc
nov/15 22:44:32 ipsec,debug,packet ipsec: a218b552 27dbedd1 b05369c8
nov/15 22:44:32 ipsec,debug ipsec: IV was saved for next processing:
nov/15 22:44:32 ipsec,debug ipsec: d431b5dc a218b552 27dbedd1 b05369c8
nov/15 22:44:32 ipsec,debug ipsec: with key:
nov/15 22:44:32 ipsec,debug ipsec: decrypted payload by IV:
nov/15 22:44:32 ipsec,debug ipsec: decrypted payload, but not trimed.
nov/15 22:44:32 ipsec,debug ipsec: 0800000c 011101f4 0a160a6c 00000044 370635e0 37a71515 71ac342b 20c1e5f3
nov/15 22:44:32 ipsec,debug ipsec: a8c25b1d fef62976 1bf87a3b de35dfb9 69aec47f a7d88009 9e6d0465 e956de88
nov/15 22:44:32 ipsec,debug ipsec: a229ee21 8d43d417 62d5b275 8d7d7986 aae3c2d9 aedff29c a1898ad3 88cba9b6
nov/15 22:44:32 ipsec,debug ipsec: ffc5ada7 c8b49d93 f6dffa83 8faad01f
nov/15 22:44:32 ipsec,debug ipsec: padding len=32
nov/15 22:44:32 ipsec,debug ipsec: skip to trim padding.
nov/15 22:44:32 ipsec,debug ipsec: decrypted.
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 05100201 00000000 0000008c 0800000c
nov/15 22:44:32 ipsec,debug ipsec: 011101f4 0a160a6c 00000044 370635e0 37a71515 71ac342b 20c1e5f3 a8c25b1d
nov/15 22:44:32 ipsec,debug ipsec: fef62976 1bf87a3b de35dfb9 69aec47f a7d88009 9e6d0465 e956de88 a229ee21
nov/15 22:44:32 ipsec,debug ipsec: 8d43d417 62d5b275 8d7d7986 aae3c2d9 aedff29c a1898ad3 88cba9b6 ffc5ada7
nov/15 22:44:32 ipsec,debug ipsec: c8b49d93 f6dffa83 8faad01f
nov/15 22:44:32 ipsec,debug ipsec: begin.
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=5(id) len=12
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=8(hash) len=68
nov/15 22:44:32 ipsec,debug ipsec: succeed.
nov/15 22:44:32 ipsec,debug ipsec: HASH received:
nov/15 22:44:32 ipsec,debug ipsec: 370635e0 37a71515 71ac342b 20c1e5f3 a8c25b1d fef62976 1bf87a3b de35dfb9
nov/15 22:44:32 ipsec,debug ipsec: 69aec47f a7d88009 9e6d0465 e956de88 a229ee21 8d43d417 62d5b275 8d7d7986
nov/15 22:44:32 ipsec,debug ipsec: HASH with:
nov/15 22:44:32 ipsec,debug ipsec: 18e170e1 403f9577 829d0fdb c43f0e35 15ba5e75 47a06cc0 aa78c625 6ca8484d
nov/15 22:44:32 ipsec,debug ipsec: ee859096 3b894632 c3af7a8d 149ba88e 4e861058 dbfb98d7 e53d7826 f4c6f5c2
nov/15 22:44:32 ipsec,debug ipsec: cc051f5c dd81dc9e 4040f439 d9bbed8c cedcd788 81f4b07a 1fdbf468 424c6b15
nov/15 22:44:32 ipsec,debug ipsec: 6ab1d148 937b887c a5cfb164 78f37580 347cc58c 1630dba2 c08e700b a3cd3379
nov/15 22:44:32 ipsec,debug ipsec: 191ed5cd 258a1d78 c3ba62f2 23fbeee4 bed3b45c 65d09cd8 ecf84c1f 93ef6dcb
nov/15 22:44:32 ipsec,debug ipsec: 3594330c 68fec16f b434d4f5 b273fdbd eede8776 d94e0ad8 5b569ceb a72b744d
nov/15 22:44:32 ipsec,debug ipsec: 09ec1533 6260381d b52f4ae1 8791ab9d d41c9932 bbb37f43 0156a8bf 1e754a62
nov/15 22:44:32 ipsec,debug ipsec: 2bfe8faf 987174b1 1fd9a725 09e79424 7b621641 e4647d6f 0691c7c6 e2a0cb65
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 00000001 00000001 00000230 01010010
nov/15 22:44:32 ipsec,debug ipsec: 03000024 01010000 800b0001 800c7080 80010007 800e0100 8003fde9 80020005
nov/15 22:44:32 ipsec,debug ipsec: 80040002 03000024 02010000 800b0001 800c7080 80010007 800e0100 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020004 80040002 03000024 03010000 800b0001 800c7080 80010007 800e0100
nov/15 22:44:32 ipsec,debug ipsec: 8003fde9 80020006 80040002 03000024 04010000 800b0001 800c7080 80010007
nov/15 22:44:32 ipsec,debug ipsec: 800e0100 8003fde9 80020002 80040002 03000024 05010000 800b0001 800c7080
nov/15 22:44:32 ipsec,debug ipsec: 80010007 800e0100 8003fde9 80020001 80040002 03000024 06010000 800b0001
nov/15 22:44:32 ipsec,debug ipsec: 800c7080 80010007 800e0080 8003fde9 80020006 80040002 03000024 07010000
nov/15 22:44:32 ipsec,debug ipsec: 800b0001 800c7080 80010007 800e0080 8003fde9 80020005 80040002 03000024
nov/15 22:44:32 ipsec,debug ipsec: 08010000 800b0001 800c7080 80010007 800e0080 8003fde9 80020004 80040002
nov/15 22:44:32 ipsec,debug ipsec: 03000024 09010000 800b0001 800c7080 80010007 800e0080 8003fde9 80020002
nov/15 22:44:32 ipsec,debug ipsec: 80040002 03000024 0a010000 800b0001 800c7080 80010007 800e0080 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020001 80040002 03000020 0b010000 800b0001 800c7080 80010005 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020004 80040002 03000020 0c010000 800b0001 800c7080 80010005 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020002 80040002 03000020 0d010000 800b0001 800c7080 80010005 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020001 80040002 03000020 0e010000 800b0001 800c7080 80010001 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020004 80040002 03000020 0f010000 800b0001 800c7080 80010001 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020002 80040002 00000020 10010000 800b0001 800c7080 80010001 8003fde9
nov/15 22:44:32 ipsec,debug ipsec: 80020001 80040002 011101f4 0a160a6c
nov/15 22:44:32 ipsec,debug ipsec: HASH computed:
nov/15 22:44:32 ipsec,debug ipsec: HASH for PSK validated.
nov/15 22:44:32 ipsec,debug ipsec: xx.xxx.148.156 peer's ID
nov/15 22:44:32 ipsec,debug ipsec: use ID type of IPv4_address
nov/15 22:44:32 ipsec,debug ipsec: generate HASH_R
nov/15 22:44:32 ipsec,debug ipsec: ee0c3df5 e8b5733d 54878e47 70d12b0d 00000001 00000001 00000230 01010010
nov/15 22:44:32 ipsec,debug ipsec: 80020001 80040002 011101f4 ad08ac59
nov/15 22:44:32 ipsec,debug ipsec: d5389b75 8ac61c2d 7b618e7a 5095b588 ba7d5026 7dd8fff3 d7ac432a f4b350ee
nov/15 22:44:32 ipsec,debug ipsec: a057bf3e a2fe46c0 f7d5154b 3d270c04 81d7a3de 213039af 1d1e3b73 716c08ed
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 8, next type 8
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 64, next type 0
nov/15 22:44:32 ipsec,debug ipsec: begin encryption.
nov/15 22:44:32 ipsec,debug ipsec: pad length = 16
nov/15 22:44:32 ipsec,debug ipsec: 0800000c 011101f4 ad08ac59 00000044 d5389b75 8ac61c2d 7b618e7a 5095b588
nov/15 22:44:32 ipsec,debug ipsec: ba7d5026 7dd8fff3 d7ac432a f4b350ee a057bf3e a2fe46c0 f7d5154b 3d270c04
nov/15 22:44:32 ipsec,debug ipsec: 81d7a3de 213039af 1d1e3b73 716c08ed a52e5258 c6a63163 59e06f56 db04740f
nov/15 22:44:32 ipsec,debug ipsec: encrypted payload by IV:
nov/15 22:44:32 ipsec,debug ipsec: save IV for next:
nov/15 22:44:32 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45
nov/15 22:44:32 ipsec,debug ipsec: encrypted.
nov/15 22:44:32 ipsec,debug ipsec: 124 bytes from 1.2.3.4[4500] to xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug ipsec: 1 times of 128 bytes message will be sent to xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 05100201 00000000 0000007c 2e910074
nov/15 22:44:32 ipsec,debug,packet ipsec: 2346cf5e d9a826fa 6c8e8750 cebbcb70 b5ccc41d 27d39487 c641b804 8b909243
nov/15 22:44:32 ipsec,debug,packet ipsec: 4704a24e bb89f8f3 19489ae7 656a9ec9 f52fb2ad b2c41002 a999b177 53db298f
nov/15 22:44:32 ipsec,debug,packet ipsec: 4304e3b1 7a49134d 2c2eb0b4 ac9fdb98 7eb0f474 940801db b5abcb45
nov/15 22:44:32 ipsec,debug ipsec: compute IV for phase2
nov/15 22:44:32 ipsec,debug ipsec: phase1 last IV:
nov/15 22:44:32 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 a16baeb7
nov/15 22:44:32 ipsec,debug ipsec: phase2 IV computed:
nov/15 22:44:32 ipsec,debug ipsec: ac93a70a fcac3df1 6a1d2227 807647ba
nov/15 22:44:32 ipsec,debug ipsec: a16baeb7 00000014 0100b19d c0880000 40890000 408a0000
nov/15 22:44:32 ipsec,debug ipsec: 286c1063 fe047722 cd23c037 9434230f d687bbcb 8664d8af 18984c03 9a90bb4a
nov/15 22:44:32 ipsec,debug ipsec: a524b132 aef26c14 8da305b7 40bee7a8 57d27971 a2cb44ea d75bc813 5f9a86fc
nov/15 22:44:32 ipsec,debug ipsec: MODE_CFG packet to send
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a16baeb7 00000074 0e000044
nov/15 22:44:32 ipsec,debug ipsec: 00000014 0100b19d c0880000 40890000 408a0000
nov/15 22:44:32 ipsec,debug ipsec: pad length = 8
nov/15 22:44:32 ipsec,debug ipsec: 0e000044 286c1063 fe047722 cd23c037 9434230f d687bbcb 8664d8af 18984c03
nov/15 22:44:32 ipsec,debug ipsec: 9a90bb4a a524b132 aef26c14 8da305b7 40bee7a8 57d27971 a2cb44ea d75bc813
nov/15 22:44:32 ipsec,debug ipsec: 5f9a86fc 00000014 0100b19d c0880000 40890000 408a0000 29e635ce d858c407
nov/15 22:44:32 ipsec,debug ipsec: dfe9c271 cfd49b85 7203bbe7 0a4c8537
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a16baeb7 0000007c 5073076a
nov/15 22:44:32 ipsec,debug,packet ipsec: 2c3a35d2 78213332 36aaa3e4 b0fe0630 66460b5f 20a01996 65943fed a64a472a
nov/15 22:44:32 ipsec,debug,packet ipsec: c0a4983b 24e2009a 8a23d8a5 2fd3d846 4f6cc619 8206ef96 dd9c13d4 fec222ad
nov/15 22:44:32 ipsec,debug,packet ipsec: b2418950 121f34ed c351555f dfe9c271 cfd49b85 7203bbe7 0a4c8537
nov/15 22:44:32 ipsec,debug ipsec: sendto mode config 14.
nov/15 22:44:32 ipsec,info ISAKMP-SA established 1.2.3.4[4500]-xx.xxx.148.156[60634] spi:54878e4770d12b0d:ee0c3df5e8b5733d
nov/15 22:44:32 ipsec,debug ipsec: ===== received 156 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100501 e12af7d6 0000009c ed03fde8
nov/15 22:44:32 ipsec,debug,packet ipsec: 67590c6b 7ead09f4 e9e4ae6c e28627d8 609527c3 b0aca199 9579e0ec 5421374e
nov/15 22:44:32 ipsec,debug,packet ipsec: 4931d69c 075942da eb38c4a9 9a07794b 0521e31b 3dcef366 b5268bbc 5831774f
nov/15 22:44:32 ipsec,debug,packet ipsec: f145007f f5ee2404 6b506fd5 882ad0d8 5e634d32 ab8aa45a 4cf84957 25d0463e
nov/15 22:44:32 ipsec,debug,packet ipsec: b98ba08d 187f6e4f c034814f ddf16578 7c549338 10ca518a d479ef28
nov/15 22:44:32 ipsec,debug ipsec: receive Information.
nov/15 22:44:32 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 e12af7d6
nov/15 22:44:32 ipsec,debug ipsec: f537da6e 2a6e5e87 bb0b8318 2cc890da
nov/15 22:44:32 ipsec,debug ipsec: ddf16578 7c549338 10ca518a d479ef28
nov/15 22:44:32 ipsec,debug ipsec: 0b000044 2bdc1c5b f902df2a d95a1802 a889506d f5eb70a8 4a464094 d675ed26
nov/15 22:44:32 ipsec,debug ipsec: 700eb66a 07eee9b4 74c77fad d21e0881 9517c096 d4aef8d3 ab51850d e1419409
nov/15 22:44:32 ipsec,debug ipsec: 96e2c9b7 0000001c 00000001 01106002 54878e47 70d12b0d ee0c3df5 e8b5733d
nov/15 22:44:32 ipsec,debug ipsec: 9ab885f0 86969ce1 b4b9a3bc 83a68cf4 8f8ffd8f c1eb8191 93b2bab3 8a9df71f
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100501 e12af7d6 0000009c 0b000044
nov/15 22:44:32 ipsec,debug ipsec: 2bdc1c5b f902df2a d95a1802 a889506d f5eb70a8 4a464094 d675ed26 700eb66a
nov/15 22:44:32 ipsec,debug ipsec: 07eee9b4 74c77fad d21e0881 9517c096 d4aef8d3 ab51850d e1419409 96e2c9b7
nov/15 22:44:32 ipsec,debug ipsec: 0000001c 00000001 01106002 54878e47 70d12b0d ee0c3df5 e8b5733d 9ab885f0
nov/15 22:44:32 ipsec,debug ipsec: 86969ce1 b4b9a3bc 83a68cf4 8f8ffd8f c1eb8191 93b2bab3 8a9df71f
nov/15 22:44:32 ipsec,debug ipsec: e12af7d6 0000001c 00000001 01106002 54878e47 70d12b0d ee0c3df5 e8b5733d
nov/15 22:44:32 ipsec,debug ipsec: hash validated.
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=11(notify) len=28
nov/15 22:44:32 ipsec,debug ipsec: xx.xxx.148.156 notify: INITIAL-CONTACT
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a16baeb7 0000009c 9fecf543
nov/15 22:44:32 ipsec,debug,packet ipsec: df0baf2f 41b742d5 c20e0caa 5f05f1ce 41f0edf2 71b6cd74 8d496b25 6bdc336c
nov/15 22:44:32 ipsec,debug,packet ipsec: 1296be9c 0831753f 2493aa97 3b9d94bf 393f7e03 2300486c 30f417d4 fe9ec7a8
nov/15 22:44:32 ipsec,debug,packet ipsec: 8ebcf84f 04f280bb adba86c6 9e653e09 129b5aec 034ad0a4 b1b7e0be 5aa54385
nov/15 22:44:32 ipsec,debug,packet ipsec: 0c72332d 5931f1ec 0530e2d4 d5794dce 11c48d55 dee664e8 854fc6bc
nov/15 22:44:32 ipsec,debug ipsec: d5794dce 11c48d55 dee664e8 854fc6bc
nov/15 22:44:32 ipsec,debug ipsec: 0e000044 753bedd7 adfc039c 4d781628 0c9d52eb 6507a24b 1b39d051 5ac3a775
nov/15 22:44:32 ipsec,debug ipsec: 19cf69a7 9a9aeec9 5b850a91 77c9a34f c5656561 96e85f72 6b23607a e6ff2b09
nov/15 22:44:32 ipsec,debug ipsec: d88c68cf 0000002a 0200b19d c0880000 40890006 6161726f 6e77408a 00106168
nov/15 22:44:32 ipsec,debug ipsec: 43686565 33497869 74364569 3675f289 f3ddf794 93cb8d88 e2cef7b1 a8ecb111
nov/15 22:44:32 ipsec,debug ipsec: padding len=18
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a16baeb7 0000009c 0e000044
nov/15 22:44:32 ipsec,debug ipsec: 753bedd7 adfc039c 4d781628 0c9d52eb 6507a24b 1b39d051 5ac3a775 19cf69a7
nov/15 22:44:32 ipsec,debug ipsec: 9a9aeec9 5b850a91 77c9a34f c5656561 96e85f72 6b23607a e6ff2b09 d88c68cf
nov/15 22:44:32 ipsec,debug ipsec: 0000002a 0200b19d c0880000 40890006 6161726f 6e77408a 00106168 43686565
nov/15 22:44:32 ipsec,debug ipsec: 33497869 74364569 3675f289 f3ddf794 93cb8d88 e2cef7b1 a8ecb111
nov/15 22:44:32 ipsec,debug ipsec: Seen payload 8
nov/15 22:44:32 ipsec,debug ipsec: a16baeb7 0000002a 0200b19d c0880000 40890006 6161726f 6e77408a 00106168
nov/15 22:44:32 ipsec,debug ipsec: Seen payload 14
nov/15 22:44:32 ipsec,debug ipsec: Short attribute XAUTH_TYPE = 0
nov/15 22:44:32 ipsec,debug ipsec: Attribute XAUTH_USER_NAME len 6
nov/15 22:44:32 ipsec,debug ipsec: Attribute XAUTH_USER_PASSWORD len 16
nov/15 22:44:32 ipsec,info XAuth login succeeded for user: xauth-user
nov/15 22:44:32 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 a3be7fcf
nov/15 22:44:32 ipsec,debug ipsec: 480825b2 33f29818 1aa52355 e3faf97f
nov/15 22:44:32 ipsec,debug ipsec: a3be7fcf 0000000c 0300b19d c08f0001
nov/15 22:44:32 ipsec,debug ipsec: e361ef1a 4849319b 4900c265 f0b8fade 056d35f1 8ada237e 9b8b675c 962645dd
nov/15 22:44:32 ipsec,debug ipsec: f769ca9f f2089c66 cd5ce2ec d345d986 8a9a111e 9518d8c9 d048aa50 72dbed9e
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a3be7fcf 0000006c 0e000044
nov/15 22:44:32 ipsec,debug ipsec: 0000000c 0300b19d c08f0001
nov/15 22:44:32 ipsec,debug ipsec: 0e000044 e361ef1a 4849319b 4900c265 f0b8fade 056d35f1 8ada237e 9b8b675c
nov/15 22:44:32 ipsec,debug ipsec: 962645dd f769ca9f f2089c66 cd5ce2ec d345d986 8a9a111e 9518d8c9 d048aa50
nov/15 22:44:32 ipsec,debug ipsec: 72dbed9e 0000000c 0300b19d c08f0001 7c66c482 b1d4308b 4c63b9b5 3b7e7b0f
nov/15 22:44:32 ipsec,debug ipsec: 4d756900 1b5c6316 25ad52a7 ea45c1f8
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a3be7fcf 0000007c abcc067e
nov/15 22:44:32 ipsec,debug,packet ipsec: 81dc5af0 fc374899 2c96abab 8b40b18a 95e742b2 b42e2764 85e9c9c1 062c2c09
nov/15 22:44:32 ipsec,debug,packet ipsec: 1d9dcaa7 aa8aaf30 6e176433 849da897 0e2c3c1b 84541b37 029ce95b d6a0cc1f
nov/15 22:44:32 ipsec,debug,packet ipsec: aee1c301 b383a1d2 11e039df 4d756900 1b5c6316 25ad52a7 ea45c1f8
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a3be7fcf 0000008c b20cb74a
nov/15 22:44:32 ipsec,debug,packet ipsec: 2b4d634e c4cdd5c2 4994ae92 2d7e7142 932ab328 73c24d5f cd71845b c1f4b20f
nov/15 22:44:32 ipsec,debug,packet ipsec: 1a926470 5fee4b56 864b4cc0 bc442a72 5ff30adf 7b775f04 ee80b1a1 989c6048
nov/15 22:44:32 ipsec,debug,packet ipsec: 09c4ceb4 48454d07 e4688548 3d1579aa 6e8d305e 5a45bc88 057c3590 0b82296b
nov/15 22:44:32 ipsec,debug,packet ipsec: 9176e448 8ee754ef 711fd692
nov/15 22:44:32 ipsec,debug ipsec: 0b82296b 9176e448 8ee754ef 711fd692
nov/15 22:44:32 ipsec,debug ipsec: 0e000044 a4b1a8de 088a7025 b458b6b7 8ee2c81e 00c05ba3 a64af933 c6548781
nov/15 22:44:32 ipsec,debug ipsec: 52c2abce d2871e1f bd0bc927 80e631f0 dae1a748 46affd01 ac63d791 845c9ce0
nov/15 22:44:32 ipsec,debug ipsec: 7f54bf42 0000000c 0400b19d c08f0000 9aa9c7a2 f386aef5 d7a7a886 dbc9f3dc
nov/15 22:44:32 ipsec,debug ipsec: db9cd5ba f4d18ece fc8b81f0 c2dda31f
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 a3be7fcf 0000008c 0e000044
nov/15 22:44:32 ipsec,debug ipsec: a4b1a8de 088a7025 b458b6b7 8ee2c81e 00c05ba3 a64af933 c6548781 52c2abce
nov/15 22:44:32 ipsec,debug ipsec: d2871e1f bd0bc927 80e631f0 dae1a748 46affd01 ac63d791 845c9ce0 7f54bf42
nov/15 22:44:32 ipsec,debug ipsec: 0000000c 0400b19d c08f0000 9aa9c7a2 f386aef5 d7a7a886 dbc9f3dc db9cd5ba
nov/15 22:44:32 ipsec,debug ipsec: f4d18ece fc8b81f0 c2dda31f
nov/15 22:44:32 ipsec,debug ipsec: a3be7fcf 0000000c 0400b19d c08f0000
nov/15 22:44:32 ipsec,debug ipsec: ===== received 172 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 f4b95af2 000000ac c14f009b
nov/15 22:44:32 ipsec,debug,packet ipsec: 3695dcab 9380051d 4264555c 8daed0bb 3b1ba2de a9aa213f dadb0d04 0d9848eb
nov/15 22:44:32 ipsec,debug,packet ipsec: 10229415 3aada531 41079aa7 1cc268ce fb297240 586f1e44 0f22d2be a0bb94e6
nov/15 22:44:32 ipsec,debug,packet ipsec: 7036646e f40cdfb6 0e102d1d e231d2ff b7b57a28 86b98b21 17a0b6cc 1de035ad
nov/15 22:44:32 ipsec,debug,packet ipsec: 574a1a30 6e411c71 ab4f6024 aedb0282 fe98dac4 c1600fec 66ff97ec 39021275
nov/15 22:44:32 ipsec,debug,packet ipsec: cba101b3 8eb222a4 764d720d
nov/15 22:44:32 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 f4b95af2
nov/15 22:44:32 ipsec,debug ipsec: 9a8a27d2 a473420e c4f2b929 06370c46
nov/15 22:44:32 ipsec,debug ipsec: 39021275 cba101b3 8eb222a4 764d720d
nov/15 22:44:32 ipsec,debug ipsec: 0e000044 7c1cad3e c87f5a1a f3a727ee 46b3cdfb 650d6234 49a45db3 c3258192
nov/15 22:44:32 ipsec,debug ipsec: fb05b62c 8519046f 93a9df0b e0120985 8e18b5da 674b1c9a 25a71a4f d4639458
nov/15 22:44:32 ipsec,debug ipsec: 68133749 00000030 0100d4b0 00010000 00020000 00030000 00040000 70000000
nov/15 22:44:32 ipsec,debug ipsec: 70020000 70030000 70040000 70060000 00070000 9af2abc4 e3a2f5a0 eaadb2be
nov/15 22:44:32 ipsec,debug ipsec: b9c5a7f7 dca99b85 f1f19d96 d8a5b31b
nov/15 22:44:32 ipsec,debug ipsec: padding len=28
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 f4b95af2 000000ac 0e000044
nov/15 22:44:32 ipsec,debug ipsec: 7c1cad3e c87f5a1a f3a727ee 46b3cdfb 650d6234 49a45db3 c3258192 fb05b62c
nov/15 22:44:32 ipsec,debug ipsec: 8519046f 93a9df0b e0120985 8e18b5da 674b1c9a 25a71a4f d4639458 68133749
nov/15 22:44:32 ipsec,debug ipsec: 00000030 0100d4b0 00010000 00020000 00030000 00040000 70000000 70020000
nov/15 22:44:32 ipsec,debug ipsec: 70030000 70040000 70060000 00070000 9af2abc4 e3a2f5a0 eaadb2be b9c5a7f7
nov/15 22:44:32 ipsec,debug ipsec: dca99b85 f1f19d96 d8a5b31b
nov/15 22:44:32 ipsec,debug ipsec: f4b95af2 00000030 0100d4b0 00010000 00020000 00030000 00040000 70000000
nov/15 22:44:32 ipsec,debug ipsec: Attribute INTERNAL_IP4_ADDRESS, len 0
nov/15 22:44:32 ipsec,info acquired 192.168.0.70 address for xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug ipsec: Attribute INTERNAL_IP4_NETMASK, len 0
nov/15 22:44:32 ipsec,debug ipsec: Attribute INTERNAL_IP4_DNS, len 0
nov/15 22:44:32 ipsec,debug ipsec: Attribute INTERNAL_IP4_NBNS, len 0
nov/15 22:44:32 ipsec,debug ipsec: Attribute UNITY_BANNER, len 0
nov/15 22:44:32 ipsec,debug ipsec: Ignored attribute UNITY_BANNER
nov/15 22:44:32 ipsec,debug ipsec: Attribute UNITY_DEF_DOMAIN, len 0
nov/15 22:44:32 ipsec,debug ipsec: Ignored attribute UNITY_DEF_DOMAIN
nov/15 22:44:32 ipsec,debug ipsec: Attribute UNITY_SPLITDNS_NAME, len 0
nov/15 22:44:32 ipsec,debug ipsec: Ignored attribute UNITY_SPLITDNS_NAME
nov/15 22:44:32 ipsec,debug ipsec: Attribute UNITY_SPLIT_INCLUDE, len 0
nov/15 22:44:32 ipsec,debug ipsec: adding split: 192.168.0.0/24
nov/15 22:44:32 ipsec,debug ipsec: adding split: 192.168.1.0/24
nov/15 22:44:32 ipsec,debug ipsec: Attribute UNITY_LOCAL_LAN, len 0
nov/15 22:44:32 ipsec,debug ipsec: Ignored attribute UNITY_LOCAL_LAN
nov/15 22:44:32 ipsec,debug ipsec: Attribute APPLICATION_VERSION, len 0
nov/15 22:44:32 ipsec,debug ipsec: f4b95af2 00000060 0200d4b0 00010004 c0a80046 00020004 ffffff00 00030004
nov/15 22:44:32 ipsec,debug ipsec: c0a80003 00030004 08080808 7004001c c0a80000 ffffff00 00000000 0000c0a8
nov/15 22:44:32 ipsec,debug ipsec: 0100ffff ff000000 00000000 00070014 7261636f 6f6e202f 20495073 65632d74
nov/15 22:44:32 ipsec,debug ipsec: 6f6f6c73
nov/15 22:44:32 ipsec,debug ipsec: 9c18480c 505e55a6 a408d502 3e2a9131 caf2f561 b1679933 24896840 5bef6d0a
nov/15 22:44:32 ipsec,debug ipsec: 564593b0 5f59b82c d9a89b1b f996c050 60d3e2a4 a17c4823 38469371 d5298e77
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 f4b95af2 000000c0 0e000044
nov/15 22:44:32 ipsec,debug ipsec: 00000060 0200d4b0 00010004 c0a80046 00020004 ffffff00 00030004 c0a80003
nov/15 22:44:32 ipsec,debug ipsec: 00030004 08080808 7004001c c0a80000 ffffff00 00000000 0000c0a8 0100ffff
nov/15 22:44:32 ipsec,debug ipsec: ff000000 00000000 00070014 7261636f 6f6e202f 20495073 65632d74 6f6f6c73
nov/15 22:44:32 ipsec,debug ipsec: pad length = 12
nov/15 22:44:32 ipsec,debug ipsec: 0e000044 9c18480c 505e55a6 a408d502 3e2a9131 caf2f561 b1679933 24896840
nov/15 22:44:32 ipsec,debug ipsec: 5bef6d0a 564593b0 5f59b82c d9a89b1b f996c050 60d3e2a4 a17c4823 38469371
nov/15 22:44:32 ipsec,debug ipsec: d5298e77 00000060 0200d4b0 00010004 c0a80046 00020004 ffffff00 00030004
nov/15 22:44:32 ipsec,debug ipsec: 6f6f6c73 4ebcde9c 3319f529 cf58730b
nov/15 22:44:32 ipsec,debug ipsec: d7d3c1ca d31bfca9 5eedddce c135b4dd
nov/15 22:44:32 ipsec,debug ipsec: 204 bytes from 1.2.3.4[4500] to xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug ipsec: 1 times of 208 bytes message will be sent to xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100601 f4b95af2 000000cc ad2653a9
nov/15 22:44:32 ipsec,debug,packet ipsec: 3c050d38 8957f19f 64a0ddc0 e5bb8536 b3adc4ff 07c4da2f f0d449ea 5f944e9c
nov/15 22:44:32 ipsec,debug,packet ipsec: e0fbc1a5 95008c41 b2c11a3a ac6cc597 b22f5908 8fee3f23 c8673330 f06894fd
nov/15 22:44:32 ipsec,debug,packet ipsec: 3f4a48b2 0cbc355b 758b7bf0 99656dc2 6a5f6c94 72576f58 efdccddd 422df583
nov/15 22:44:32 ipsec,debug,packet ipsec: 3308c9f2 8ac827e8 d0f2972c 565cef66 3352b733 8c446f15 fdc40d9b 2ffcc6db
nov/15 22:44:32 ipsec,debug,packet ipsec: ba334218 b75a8553 edec0a1b aae967f6 b5b7bb2c 3b16b250 1635fd05 d7d3c1ca
nov/15 22:44:32 ipsec,debug,packet ipsec: d31bfca9 5eedddce c135b4dd
nov/15 22:44:32 ipsec,debug ipsec: ===== received 716 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08102001 fe051a75 000002cc ed2a874f
nov/15 22:44:32 ipsec,debug,packet ipsec: 726c3037 e2aa3c0c 6a4f8a10 45fa2957 0ddf914c 88fb7d6b 853d069c e50c1661
nov/15 22:44:32 ipsec,debug,packet ipsec: c4884143 bd444478 2e0040ca fa093ba7 34356e3e cee53c43 e9988732 68c849bd
nov/15 22:44:32 ipsec,debug,packet ipsec: 991d839b 7509814e 712f8411 26eacc8d 5a411183 c8ae7867 a35404d7 4070f1c0
nov/15 22:44:32 ipsec,debug,packet ipsec: 61835579 0f11f585 d5066d16 63d260c9 37e7948e ba6d2480 7230f67b b4ac927e
nov/15 22:44:32 ipsec,debug,packet ipsec: abe5c984 08e0f1f8 93ddc4b6 99516213 3b308b98 8bd35034 d7d8371e f56c7f32
nov/15 22:44:32 ipsec,debug,packet ipsec: dd6b3691 c3789424 6fce40a2 d4c58b9f fe0d5c91 ee9c0f7e 70957148 67a3f200
nov/15 22:44:32 ipsec,debug,packet ipsec: 3d0d1c43 e0b3ccff ff07665b 3a15698e 371bb6fc b4782c83 1df551ea 9c6045ec
nov/15 22:44:32 ipsec,debug,packet ipsec: d9adb5ee 1d37911d f4cf9087 98d59e7a d9a80d5a 7a7d0c04 ff57e04f 01330496
nov/15 22:44:32 ipsec,debug,packet ipsec: ffac4dde 662ad72d 584c0e84 00d11531 0e1bc4f7 ee6d787e 554272a7 25a48c33
nov/15 22:44:32 ipsec,debug,packet ipsec: 8b22b08d 40c79926 fac9ed9a bb9ed853 a2946dbd 40d30c0e 5ef204a6 893eaf28
nov/15 22:44:32 ipsec,debug,packet ipsec: 0e595131 165996cb 489b8f18 ded3290f a95a0942 46963dd3 ae56dcfb 6b926098
nov/15 22:44:32 ipsec,debug,packet ipsec: 96efa715 fc4e2cc2 d4e222ea b89c141d 55709595 baa766d7 2d140ef0 65a67fe3
nov/15 22:44:32 ipsec,debug,packet ipsec: 62575a04 45341f8e aaba0bf0 2bc41170 a43231a3 6ded2947 3d90972e 6ba02e10
nov/15 22:44:32 ipsec,debug,packet ipsec: 2fe3dbd3 0689c9bf d6d795a7 b832f9bd 1edd26de e8ec9475 841dee04 1dcec247
nov/15 22:44:32 ipsec,debug,packet ipsec: ddced02f 81063a9d 2e3bed97 549089ea 8a42d522 ce160bd7 09e287fb bc5c54c7
nov/15 22:44:32 ipsec,debug,packet ipsec: 1b39b189 21f21dde 37d8b7df 11a50571 d4b62443 6e827297 c794306d 167b78c3
nov/15 22:44:32 ipsec,debug,packet ipsec: 27130a60 f3ba0ffe 4c8f1cc2 36f09254 d23218a0 9e609860 c95629c0 f401d2bd
nov/15 22:44:32 ipsec,debug,packet ipsec: 4a397cfc 77d3060e 61ed1a02 6d604d1b 507a1604 c641af11 9b769ae8 6a625d59
nov/15 22:44:32 ipsec,debug,packet ipsec: 43a0ea55 74e7ed0c b530a82a 60375233 41e4f2d4 eeb713b2 56e87468 ca539f75
nov/15 22:44:32 ipsec,debug,packet ipsec: 5ea80eda 9de46236 60227b8b cab8ad43 38687188 762cd4e6 e28765bd c3f7fa46
nov/15 22:44:32 ipsec,debug,packet ipsec: 4cfd5a2e 06010a35 4340e491 51b661b0 6c16afde 467e4362 5ec34504 9e3e3d69
nov/15 22:44:32 ipsec,debug,packet ipsec: 2a0a6e8f c7481cc4 6b13b8b5
nov/15 22:44:32 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 fe051a75
nov/15 22:44:32 ipsec,debug ipsec: c19cafe9 05848f33 8a0f16b5 576bb278
nov/15 22:44:32 ipsec,debug ipsec: 9e3e3d69 2a0a6e8f c7481cc4 6b13b8b5
nov/15 22:44:32 ipsec,debug ipsec: 01000044 43076e78 401a233d 132ccc67 cc3348fc d886ef69 4bb00236 725a2ab0
nov/15 22:44:32 ipsec,debug ipsec: f474d5dd 904f8388 152cb028 25226e2b ea253f47 4963cee2 13e3e0b8 af87f075
nov/15 22:44:32 ipsec,debug ipsec: 089d1505 0a000220 00000001 00000001 00000214 01030414 00d1fad9 0300001c
nov/15 22:44:32 ipsec,debug ipsec: 010c0000 80010001 80027080 80040003 80060100 80050007 0300001c 020c0000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80060100 80050006 0300001c 030c0000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80060100 80050002 0300001c 040c0000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80060100 80050005 0300001c 050c0000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80060100 80050001 0300001c 060c0000 80010001 80027080 80040003 80060080
nov/15 22:44:32 ipsec,debug ipsec: 80050007 0300001c 070c0000 80010001 80027080 80040003 80060080 80050006
nov/15 22:44:32 ipsec,debug ipsec: 0300001c 080c0000 80010001 80027080 80040003 80060080 80050002 0300001c
nov/15 22:44:32 ipsec,debug ipsec: 090c0000 80010001 80027080 80040003 80060080 80050005 0300001c 0a0c0000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80060080 80050001 03000018 0b030000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80050007 03000018 0c030000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80050006 03000018 0d030000 80010001 80027080 80040003 80050002 03000018
nov/15 22:44:32 ipsec,debug ipsec: 0e030000 80010001 80027080 80040003 80050005 03000018 0f030000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80050001 03000018 10020000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80050007 03000018 11020000 80010001 80027080 80040003 80050006 03000018
nov/15 22:44:32 ipsec,debug ipsec: 12020000 80010001 80027080 80040003 80050002 03000018 13020000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80050005 00000018 14020000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80050001 05000014 e248c64f 5b4e21ed 45795486 97d4f619 0500000c 01000000
nov/15 22:44:32 ipsec,debug ipsec: c0a80046 00000010 04000000 00000000 00000000 abacf3af fcaf9ed6 dfb5c8ab
nov/15 22:44:32 ipsec,debug ipsec: c58beddd 93e58495 838eecbe dc8baa1b
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08102001 fe051a75 000002cc 01000044
nov/15 22:44:32 ipsec,debug ipsec: 43076e78 401a233d 132ccc67 cc3348fc d886ef69 4bb00236 725a2ab0 f474d5dd
nov/15 22:44:32 ipsec,debug ipsec: 904f8388 152cb028 25226e2b ea253f47 4963cee2 13e3e0b8 af87f075 089d1505
nov/15 22:44:32 ipsec,debug ipsec: 0a000220 00000001 00000001 00000214 01030414 00d1fad9 0300001c 010c0000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80060100 80050007 0300001c 020c0000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80060100 80050006 0300001c 030c0000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80060100 80050002 0300001c 040c0000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80060100 80050005 0300001c 050c0000 80010001 80027080 80040003 80060100
nov/15 22:44:32 ipsec,debug ipsec: 80050001 0300001c 060c0000 80010001 80027080 80040003 80060080 80050007
nov/15 22:44:32 ipsec,debug ipsec: 0300001c 070c0000 80010001 80027080 80040003 80060080 80050006 0300001c
nov/15 22:44:32 ipsec,debug ipsec: 080c0000 80010001 80027080 80040003 80060080 80050002 0300001c 090c0000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80060080 80050005 0300001c 0a0c0000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80060080 80050001 03000018 0b030000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80050007 03000018 0c030000 80010001 80027080 80040003 80050006
nov/15 22:44:32 ipsec,debug ipsec: 03000018 0d030000 80010001 80027080 80040003 80050002 03000018 0e030000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80050005 03000018 0f030000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80050001 03000018 10020000 80010001 80027080 80040003 80050007
nov/15 22:44:32 ipsec,debug ipsec: 03000018 11020000 80010001 80027080 80040003 80050006 03000018 12020000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80050002 03000018 13020000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80050005 00000018 14020000 80010001 80027080 80040003 80050001
nov/15 22:44:32 ipsec,debug ipsec: 05000014 e248c64f 5b4e21ed 45795486 97d4f619 0500000c 01000000 c0a80046
nov/15 22:44:32 ipsec,debug ipsec: 00000010 04000000 00000000 00000000 abacf3af fcaf9ed6 dfb5c8ab c58beddd
nov/15 22:44:32 ipsec,debug ipsec: 93e58495 838eecbe dc8baa1b
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=1(sa) len=544
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=10(nonce) len=20
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=5(id) len=16
nov/15 22:44:32 ipsec,debug ipsec: received IDci2:
nov/15 22:44:32 ipsec,debug ipsec: 01000000 c0a80046
nov/15 22:44:32 ipsec,debug ipsec: received IDcr2:
nov/15 22:44:32 ipsec,debug ipsec: 04000000 00000000 00000000
nov/15 22:44:32 ipsec,debug ipsec: HASH(1) validate:
nov/15 22:44:32 ipsec,debug ipsec: fe051a75 0a000220 00000001 00000001 00000214 01030414 00d1fad9 0300001c
nov/15 22:44:32 ipsec,debug ipsec: total SA len=540
nov/15 22:44:32 ipsec,debug ipsec: 00000001 00000001 00000214 01030414 00d1fad9 0300001c 010c0000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80060100 80050007 0300001c 020c0000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80060100 80050006 0300001c 030c0000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80060100 80050002 0300001c 040c0000 80010001 80027080 80040003 80060100
nov/15 22:44:32 ipsec,debug ipsec: 80050005 0300001c 050c0000 80010001 80027080 80040003 80060100 80050001
nov/15 22:44:32 ipsec,debug ipsec: 0300001c 060c0000 80010001 80027080 80040003 80060080 80050007 0300001c
nov/15 22:44:32 ipsec,debug ipsec: 070c0000 80010001 80027080 80040003 80060080 80050006 0300001c 080c0000
nov/15 22:44:32 ipsec,debug ipsec: 80010001 80027080 80040003 80060080 80050002 0300001c 090c0000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80060080 80050005 0300001c 0a0c0000 80010001 80027080
nov/15 22:44:32 ipsec,debug ipsec: 80040003 80060080 80050001 03000018 0b030000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80050007 03000018 0c030000 80010001 80027080 80040003 80050006 03000018
nov/15 22:44:32 ipsec,debug ipsec: 0d030000 80010001 80027080 80040003 80050002 03000018 0e030000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80050005 03000018 0f030000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80050001 03000018 10020000 80010001 80027080 80040003 80050007 03000018
nov/15 22:44:32 ipsec,debug ipsec: 11020000 80010001 80027080 80040003 80050006 03000018 12020000 80010001
nov/15 22:44:32 ipsec,debug ipsec: 80027080 80040003 80050002 03000018 13020000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80050005 00000018 14020000 80010001 80027080 80040003 80050001
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=2(prop) len=532
nov/15 22:44:32 ipsec,debug ipsec: proposal #1 len=532
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=3(trns) len=28
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=3(trns) len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #1 len=28
nov/15 22:44:32 ipsec,debug ipsec: type=SA Life Type, flag=0x8000, lorv=seconds
nov/15 22:44:32 ipsec,debug ipsec: type=SA Life Duration, flag=0x8000, lorv=28800
nov/15 22:44:32 ipsec,debug ipsec: life duration was in TLV.
nov/15 22:44:32 ipsec,debug ipsec: type=Encryption Mode, flag=0x8000, lorv=UDP-Tunnel
nov/15 22:44:32 ipsec,debug ipsec: UDP encapsulation requested
nov/15 22:44:32 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=256
nov/15 22:44:32 ipsec,debug ipsec: type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha512
nov/15 22:44:32 ipsec,debug ipsec: transform #2 len=28
nov/15 22:44:32 ipsec,debug ipsec: type=Authentication Algorithm, flag=0x8000, lorv=6
nov/15 22:44:32 ipsec,debug ipsec: transform #3 len=28
nov/15 22:44:32 ipsec,debug ipsec: type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha1
nov/15 22:44:32 ipsec,debug ipsec: transform #4 len=28
nov/15 22:44:32 ipsec,debug ipsec: type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha256
nov/15 22:44:32 ipsec,debug ipsec: transform #5 len=28
nov/15 22:44:32 ipsec,debug ipsec: type=Authentication Algorithm, flag=0x8000, lorv=hmac-md5
nov/15 22:44:32 ipsec,debug ipsec: transform #6 len=28
nov/15 22:44:32 ipsec,debug ipsec: type=Key Length, flag=0x8000, lorv=128
nov/15 22:44:32 ipsec,debug ipsec: transform #7 len=28
nov/15 22:44:32 ipsec,debug ipsec: transform #8 len=28
nov/15 22:44:32 ipsec,debug ipsec: transform #9 len=28
nov/15 22:44:32 ipsec,debug ipsec: transform #10 len=28
nov/15 22:44:32 ipsec,debug ipsec: transform #11 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #12 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #13 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #14 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #15 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #16 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #17 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #18 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #19 len=24
nov/15 22:44:32 ipsec,debug ipsec: transform #20 len=24
nov/15 22:44:32 ipsec,debug ipsec: pair 1:
nov/15 22:44:32 ipsec,debug ipsec:  0x492db0: next=(nil) tnext=0x48ede0
nov/15 22:44:32 ipsec,debug ipsec:   0x48ede0: next=(nil) tnext=0x48e4b8
nov/15 22:44:32 ipsec,debug ipsec:    0x48e4b8: next=(nil) tnext=0x48d198
nov/15 22:44:32 ipsec,debug ipsec:     0x48d198: next=(nil) tnext=0x48e460
nov/15 22:44:32 ipsec,debug ipsec:      0x48e460: next=(nil) tnext=0x48dc78
nov/15 22:44:32 ipsec,debug ipsec:       0x48dc78: next=(nil) tnext=0x48c3b0
nov/15 22:44:32 ipsec,debug ipsec:        0x48c3b0: next=(nil) tnext=0x48e1f0
nov/15 22:44:32 ipsec,debug ipsec:         0x48e1f0: next=(nil) tnext=0x494678
nov/15 22:44:32 ipsec,debug ipsec:          0x494678: next=(nil) tnext=0x494690
nov/15 22:44:32 ipsec,debug ipsec:           0x494690: next=(nil) tnext=0x490568
nov/15 22:44:32 ipsec,debug ipsec:            0x490568: next=(nil) tnext=0x490580
nov/15 22:44:32 ipsec,debug ipsec:             0x490580: next=(nil) tnext=0x48f690
nov/15 22:44:32 ipsec,debug ipsec:              0x48f690: next=(nil) tnext=0x48f6a8
nov/15 22:44:32 ipsec,debug ipsec:               0x48f6a8: next=(nil) tnext=0x4903b8
nov/15 22:44:32 ipsec,debug ipsec:                0x4903b8: next=(nil) tnext=0x4903d0
nov/15 22:44:32 ipsec,debug ipsec:                 0x4903d0: next=(nil) tnext=(nil)
nov/15 22:44:32 ipsec,debug ipsec: proposal #1: 16 transform
nov/15 22:44:32 ipsec,debug ipsec: got the local address from ID payload 0.0.0.0[0] prefixlen=0 ul_proto=255
nov/15 22:44:32 ipsec,debug ipsec: got the peer address from ID payload 192.168.0.70[0] prefixlen=32 ul_proto=255
nov/15 22:44:32 ipsec,debug ipsec:  (proto_id=ESP spisize=4 spi=00000000 spi_p=00000000 encmode=UDP-Tunnel reqid=55:55)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=256 authtype=hmac-sha512)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=256 authtype=hmac-sha256)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CTR encklen=288 authtype=hmac-sha512)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CTR encklen=288 authtype=hmac-sha256)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-GCM-ICV16 encklen=288 authtype=254)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=128 authtype=hmac-sha512)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=128 authtype=hmac-sha256)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CTR encklen=160 authtype=hmac-sha512)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CTR encklen=160 authtype=hmac-sha256)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-GCM-ICV16 encklen=160 authtype=254)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=3DES encklen=0 authtype=hmac-sha512)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=3DES encklen=0 authtype=hmac-sha256)
nov/15 22:44:32 ipsec,debug ipsec: begin compare proposals.
nov/15 22:44:32 ipsec,debug ipsec: pair[1]: 0x492db0
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=1 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=3 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=4 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=5 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=6 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=8 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=9 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=10 trns-id=AES-CBC
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=11 trns-id=3DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=13 trns-id=3DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=14 trns-id=3DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=15 trns-id=3DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=16 trns-id=DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=18 trns-id=DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=19 trns-id=DES
nov/15 22:44:32 ipsec,debug ipsec: prop#=1 prot-id=ESP spi-size=4 #trns=20 trns#=20 trns-id=DES
nov/15 22:44:32 ipsec,debug ipsec: peer's single bundle:
nov/15 22:44:32 ipsec,debug ipsec:  (proto_id=ESP spisize=4 spi=00d1fad9 spi_p=00000000 encmode=UDP-Tunnel reqid=0:0)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=256 authtype=hmac-sha1)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=256 authtype=hmac-md5)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=128 authtype=hmac-sha1)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=AES-CBC encklen=128 authtype=hmac-md5)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=3DES encklen=0 authtype=hmac-sha1)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=3DES encklen=0 authtype=hmac-md5)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=DES encklen=0 authtype=hmac-sha512)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=DES encklen=0 authtype=hmac-sha1)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=DES encklen=0 authtype=hmac-sha256)
nov/15 22:44:32 ipsec,debug ipsec:   (trns_id=DES encklen=0 authtype=hmac-md5)
nov/15 22:44:32 ipsec,debug ipsec: my single bundle:
nov/15 22:44:32 ipsec,debug ipsec: matched
nov/15 22:44:32 ipsec,debug ipsec: call pfkey_send_getspi 958c32b0
nov/15 22:44:32 ipsec,debug ipsec: pfkey GETSPI sent: ESP/Tunnel xx.xxx.148.156[60634]->1.2.3.4[4500]
nov/15 22:44:32 ipsec,debug ipsec: pfkey getspi sent.
nov/15 22:44:32 ipsec,debug ipsec: total SA len=48
nov/15 22:44:32 ipsec,debug ipsec: 00000001 00000001 00000028 01030401 00000000 0000001c 010c0000 80010001
nov/15 22:44:32 ipsec,debug ipsec: seen nptype=2(prop) len=40
nov/15 22:44:32 ipsec,debug ipsec: proposal #1 len=40
nov/15 22:44:32 ipsec,debug ipsec:  0x48f528: next=(nil) tnext=(nil)
nov/15 22:44:32 ipsec,debug ipsec: proposal #1: 1 transform
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 48, next type 10
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 24, next type 5
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 8, next type 5
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 12, next type 0
nov/15 22:44:32 ipsec,debug ipsec: fe051a75 e248c64f 5b4e21ed 45795486 97d4f619 0a000034 00000001 00000001
nov/15 22:44:32 ipsec,debug ipsec: 00000028 01030401 0272a892 0000001c 010c0000 80010001 80027080 80040003
nov/15 22:44:32 ipsec,debug ipsec: 80060100 80050007 0500001c 883ba9fc 2e0cdd12 b80d88eb 5d35236e 02e25c2b
nov/15 22:44:32 ipsec,debug ipsec: 2acd9c3d 0500000c 01000000 c0a80046 00000010 04000000 00000000 00000000
nov/15 22:44:32 ipsec,debug ipsec: 030fc012 492223e7 f1d65157 18f87498 3b26883e d322b72f 0eba95fb 7d0474e5
nov/15 22:44:32 ipsec,debug ipsec: 3678137c e1ea3395 3c25b04c 9887aaee 6fb31c09 50b73380 c6b8138b e1fd8acf
nov/15 22:44:32 ipsec,debug ipsec: add payload of len 64, next type 1
nov/15 22:44:32 ipsec,debug ipsec: 01000044 030fc012 492223e7 f1d65157 18f87498 3b26883e d322b72f 0eba95fb
nov/15 22:44:32 ipsec,debug ipsec: 7d0474e5 3678137c e1ea3395 3c25b04c 9887aaee 6fb31c09 50b73380 c6b8138b
nov/15 22:44:32 ipsec,debug ipsec: e1fd8acf 0a000034 00000001 00000001 00000028 01030401 0272a892 0000001c
nov/15 22:44:32 ipsec,debug ipsec: 010c0000 80010001 80027080 80040003 80060100 80050007 0500001c 883ba9fc
nov/15 22:44:32 ipsec,debug ipsec: 2e0cdd12 b80d88eb 5d35236e 02e25c2b 2acd9c3d 0500000c 01000000 c0a80046
nov/15 22:44:32 ipsec,debug ipsec: 00000010 04000000 00000000 00000000 6751ca1c da564e02 e3c6407f d2cb920f
nov/15 22:44:32 ipsec,debug ipsec: 7fb63897 3eb670f7 c5356188 0e29e836
nov/15 22:44:32 ipsec,debug ipsec: 220 bytes from 1.2.3.4[4500] to xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug ipsec: 1 times of 224 bytes message will be sent to xx.xxx.148.156[60634]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08102001 fe051a75 000000dc cf18433a
nov/15 22:44:32 ipsec,debug,packet ipsec: 13555044 ecf75432 d9227ada 3e7da031 3149d533 7f849a4d 6404ea81 fdb8c974
nov/15 22:44:32 ipsec,debug,packet ipsec: 881f9dfe 520558b8 1b14d89b 60dd38c5 0bf63201 4de28047 5f3484c4 86ee52e0
nov/15 22:44:32 ipsec,debug,packet ipsec: a9a22fd5 45782758 655a84d3 6e76b718 8d07bbf8 8dd66819 9661ddaa 54c4b415
nov/15 22:44:32 ipsec,debug,packet ipsec: c625dd65 e8498ee9 5cdc974e 4ae57915 dc725e76 0f1f9282 c3d2b6a1 d0f6d071
nov/15 22:44:32 ipsec,debug,packet ipsec: 71a85135 385ac028 5ae96e3d 6b3ed60f 3913050c c164ff6f 48817622 f5042546
nov/15 22:44:32 ipsec,debug,packet ipsec: 39d14cd3 f557282f e80b926a 7fb63897 3eb670f7 c5356188 0e29e836
nov/15 22:44:32 ipsec,debug ipsec: ===== received 124 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:32 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08102001 fe051a75 0000007c b614afee
nov/15 22:44:32 ipsec,debug,packet ipsec: 3dd8771c 57140621 3f93f2e6 fafd384e c86d6625 3ad8eec4 07f1095c fe446c2b
nov/15 22:44:32 ipsec,debug,packet ipsec: 3f5a5cf3 1bdb577d c0cbe03a 4de4fc35 9219955a 9595f91b d2d00194 53591c76
nov/15 22:44:32 ipsec,debug,packet ipsec: 94ac045f c611787a a79034b8 9883a54f 31163873 b1e67948 93647b0c
nov/15 22:44:32 ipsec,debug ipsec: 9883a54f 31163873 b1e67948 93647b0c
nov/15 22:44:32 ipsec,debug ipsec: 00000044 07130abd c334d2ca e26bc9b3 ce0ec740 86997367 06bd9276 2deb444f
nov/15 22:44:32 ipsec,debug ipsec: 33752d15 663b62e2 b08f0fb9 fba044ff a55d91c3 debd2d57 597fdc6c e48070e9
nov/15 22:44:32 ipsec,debug ipsec: 16c90759 b390f3f5 87cbd4b1 ac81baa4 adaeffe4 c9a3ebd7 b6d9aeba e9eabc1b
nov/15 22:44:32 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08102001 fe051a75 0000007c 00000044
nov/15 22:44:32 ipsec,debug ipsec: 07130abd c334d2ca e26bc9b3 ce0ec740 86997367 06bd9276 2deb444f 33752d15
nov/15 22:44:32 ipsec,debug ipsec: 663b62e2 b08f0fb9 fba044ff a55d91c3 debd2d57 597fdc6c e48070e9 16c90759
nov/15 22:44:32 ipsec,debug ipsec: b390f3f5 87cbd4b1 ac81baa4 adaeffe4 c9a3ebd7 b6d9aeba e9eabc1b
nov/15 22:44:32 ipsec,debug ipsec: HASH(3) validate:
nov/15 22:44:32 ipsec,debug ipsec: 00fe051a 75e248c6 4f5b4e21 ed457954 8697d4f6 19883ba9 fc2e0cdd 12b80d88
nov/15 22:44:32 ipsec,debug ipsec: eb5d3523 6e02e25c 2b2acd9c 3d
nov/15 22:44:32 ipsec,debug ipsec: KEYMAT compute with
nov/15 22:44:32 ipsec,debug ipsec: 030272a8 92e248c6 4f5b4e21 ed457954 8697d4f6 19883ba9 fc2e0cdd 12b80d88
nov/15 22:44:32 ipsec,debug ipsec: encryption(aes-cbc)
nov/15 22:44:32 ipsec,debug ipsec: encklen=256 authklen=512
nov/15 22:44:32 ipsec,debug ipsec: generating 1536 bits of key (dupkeymat=3)
nov/15 22:44:32 ipsec,debug ipsec: generating K1...K3 for KEYMAT.
nov/15 22:44:32 ipsec,debug ipsec: b2bf34be 66491b9a 99ced2fd 6d05fd56 86a25eca 7c92df0f 4d0e52fc 4aa91325
nov/15 22:44:32 ipsec,debug ipsec: 0ac570ae ab0422f7 c7b2ed69 4aff743e 0a61f86f 3288609d 5eeab6a9 595c9931
nov/15 22:44:32 ipsec,debug ipsec: 3d2c9ec8 91590740 fe1c84ed abc39be4 8e3d35b6 c4e55f7d 92c44454 088c7910
nov/15 22:44:32 ipsec,debug ipsec: 61670c57 8f3e05a4 3c958d69 2a808f4c d332712f f2fd2fa0 f0a2b2be cb79d3ea
nov/15 22:44:32 ipsec,debug ipsec: 3bebb4c3 793ea1ff d7ea83ef 80136c54 b4ecd4ec 554abe7e d1150c26 827bba69
nov/15 22:44:32 ipsec,debug ipsec: 6699689e 868531e0 ed7621f5 9d5a3fb2 8076e68d b74a15e2 9b2cc5ce 9772c857
nov/15 22:44:32 ipsec,debug ipsec: 0300d1fa d9e248c6 4f5b4e21 ed457954 8697d4f6 19883ba9 fc2e0cdd 12b80d88
nov/15 22:44:32 ipsec,debug ipsec: d65e7704 cec0b0fb 69c805e8 43715a52 4a3db437 de2a4989 ae0c74f8 9d7b3c19
nov/15 22:44:32 ipsec,debug ipsec: 1070a712 1a627e2c e871232d 62557bb9 1e3d5998 dd4a74a7 a1d90cd7 c3c97527
nov/15 22:44:32 ipsec,debug ipsec: 16623ba3 e91e6195 1cf1d5b0 506e244d 4b8cadb0 6b3f4589 723f5903 379880e3
nov/15 22:44:32 ipsec,debug ipsec: ae665edb 55d86276 159c70a4 b03e3a54 7088dae1 d505ae2e 7a07e873 8975bad6
nov/15 22:44:32 ipsec,debug ipsec: c9b0ba45 adf10a7c 576085c0 c1a3afdc 0c6f95ed 13bc633e db6cb378 c2d8fd3a
nov/15 22:44:32 ipsec,debug ipsec: fa71712e e06fdab3 7cc20b9d 53fbaa57 71cb0f78 e4fbd502 c8d00d55 4c0f6a8e
nov/15 22:44:32 ipsec,debug ipsec: KEYMAT computed.
nov/15 22:44:32 ipsec,debug ipsec: call pk_sendupdate
nov/15 22:44:32 ipsec,debug ipsec: call pfkey_send_update_nat
nov/15 22:44:32 ipsec,debug ipsec: pfkey update sent.
nov/15 22:44:32 ipsec,debug ipsec: call pfkey_send_add_nat
nov/15 22:44:32 ipsec,debug ipsec: pfkey add sent.
nov/15 22:44:41 ipsec,debug ipsec: ===== received 140 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:41 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100501 e2bfc2a7 0000008c d7a97572
nov/15 22:44:41 ipsec,debug,packet ipsec: 718c2ebc df721c7c 64f801cc 2ac475fd 21f70e40 3e1cb7a7 24da0683 4276857a
nov/15 22:44:41 ipsec,debug,packet ipsec: c2c15f34 4be4cd31 06876bc8 760cdf0e 183f2b44 58b8f5f2 e3688693 7be6a197
nov/15 22:44:41 ipsec,debug,packet ipsec: 4557f966 84fcc7b9 2cb35728 29cdff09 e09dcd87 7550490f 4d11d172 ae5a38f6
nov/15 22:44:41 ipsec,debug,packet ipsec: d24473fe 99cf1de8 f2e44bcc
nov/15 22:44:41 ipsec,debug ipsec: receive Information.
nov/15 22:44:41 ipsec,debug ipsec: compute IV for phase2
nov/15 22:44:41 ipsec,debug ipsec: phase1 last IV:
nov/15 22:44:41 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 e2bfc2a7
nov/15 22:44:41 ipsec,debug ipsec: hash(sha2_512)
nov/15 22:44:41 ipsec,debug ipsec: encryption(aes)
nov/15 22:44:41 ipsec,debug ipsec: phase2 IV computed:
nov/15 22:44:41 ipsec,debug ipsec: e582d267 e346463a 87b701fb 3b6ee480
nov/15 22:44:41 ipsec,debug ipsec: IV was saved for next processing:
nov/15 22:44:41 ipsec,debug ipsec: ae5a38f6 d24473fe 99cf1de8 f2e44bcc
nov/15 22:44:41 ipsec,debug ipsec: with key:
nov/15 22:44:41 ipsec,debug ipsec: 3c793463 a8f770a5 664642cd 214842f2 4d1e4370 c93e16cd 2a34207d b9094992
nov/15 22:44:41 ipsec,debug ipsec: decrypted payload by IV:
nov/15 22:44:41 ipsec,debug ipsec: decrypted payload, but not trimed.
nov/15 22:44:41 ipsec,debug ipsec: 0c000044 2507b389 a8825b91 0519e7d0 7099eff3 590e6038 4ee22635 b072c57e
nov/15 22:44:41 ipsec,debug ipsec: 847fc744 1d11954e 5a87e4ca d542ae16 1deaba37 a1ce541d da1a8b5c d99fda5e
nov/15 22:44:41 ipsec,debug ipsec: 78a79910 00000010 00000001 03040001 00d1fad9 e182e891 f7e4c1df a9eac180
nov/15 22:44:41 ipsec,debug ipsec: 8aa1cb9f 84ffe1ac 84ebd984 b4ed8a1b
nov/15 22:44:41 ipsec,debug ipsec: padding len=28
nov/15 22:44:41 ipsec,debug ipsec: skip to trim padding.
nov/15 22:44:41 ipsec,debug ipsec: decrypted.
nov/15 22:44:41 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100501 e2bfc2a7 0000008c 0c000044
nov/15 22:44:41 ipsec,debug ipsec: 2507b389 a8825b91 0519e7d0 7099eff3 590e6038 4ee22635 b072c57e 847fc744
nov/15 22:44:41 ipsec,debug ipsec: 1d11954e 5a87e4ca d542ae16 1deaba37 a1ce541d da1a8b5c d99fda5e 78a79910
nov/15 22:44:41 ipsec,debug ipsec: 00000010 00000001 03040001 00d1fad9 e182e891 f7e4c1df a9eac180 8aa1cb9f
nov/15 22:44:41 ipsec,debug ipsec: 84ffe1ac 84ebd984 b4ed8a1b
nov/15 22:44:41 ipsec,debug ipsec: HASH with:
nov/15 22:44:41 ipsec,debug ipsec: e2bfc2a7 00000010 00000001 03040001 00d1fad9
nov/15 22:44:41 ipsec,debug ipsec: hmac(hmac_sha2_512)
nov/15 22:44:41 ipsec,debug ipsec: HASH computed:
nov/15 22:44:41 ipsec,debug ipsec: hash validated.
nov/15 22:44:41 ipsec,debug ipsec: begin.
nov/15 22:44:41 ipsec,debug ipsec: seen nptype=8(hash) len=68
nov/15 22:44:41 ipsec,debug ipsec: seen nptype=12(delete) len=16
nov/15 22:44:41 ipsec,debug ipsec: succeed.
nov/15 22:44:41 ipsec,debug ipsec: xx.xxx.148.156 delete payload for protocol ESP
nov/15 22:44:41 ipsec,debug ipsec: an undead schedule has been deleted.
nov/15 22:44:41 ipsec,debug ipsec: purged SAs.
nov/15 22:44:41 ipsec,debug ipsec: ===== received 156 bytes from xx.xxx.148.156[60634] to 1.2.3.4[4500]
nov/15 22:44:41 ipsec,debug,packet ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100501 b2da164a 0000009c b66c34e1
nov/15 22:44:41 ipsec,debug,packet ipsec: f051d05a cf11f5a4 3a712fe2 1481cd71 3e37c15f 01265271 1bdb0582 50aa7b1c
nov/15 22:44:41 ipsec,debug,packet ipsec: 560c3a61 096769a5 4fa474e1 4eae7eae 35b1112a e2b53fd2 9ce86124 4eafa3dd
nov/15 22:44:41 ipsec,debug,packet ipsec: 2d6f8261 d9545910 fceabe3d 05780feb 5445ad5d 0bc3060f 73772397 86d046b0
nov/15 22:44:41 ipsec,debug,packet ipsec: 827bcbcf 3f7273c3 9da3aa12 89628464 8c47e7ef e5571281 e71221c9
nov/15 22:44:41 ipsec,debug ipsec: ac9fdb98 7eb0f474 940801db b5abcb45 b2da164a
nov/15 22:44:41 ipsec,debug ipsec: 29fca554 8123f317 6fafcfeb 77d474cf
nov/15 22:44:41 ipsec,debug ipsec: 89628464 8c47e7ef e5571281 e71221c9
nov/15 22:44:41 ipsec,debug ipsec: 0c000044 7f667c9c 0ef33d1a b388c8ef 1b1ae8d8 c0df3836 68af01eb 0d041549
nov/15 22:44:41 ipsec,debug ipsec: 85c5b08e 8c5bbd08 ae410410 29302494 5009a1fb cbc1121e 8794d8a4 b4727f2a
nov/15 22:44:41 ipsec,debug ipsec: f9c53bd9 0000001c 00000001 01100001 54878e47 70d12b0d ee0c3df5 e8b5733d
nov/15 22:44:41 ipsec,debug ipsec: febdef95 feeeeac4 ccb3d1a7 b8e5fcf1 b0f786d9 cca8b3c5 abb0e2b2 eaec8b1f
nov/15 22:44:41 ipsec,debug ipsec: padding len=32
nov/15 22:44:41 ipsec,debug ipsec: 54878e47 70d12b0d ee0c3df5 e8b5733d 08100501 b2da164a 0000009c 0c000044
nov/15 22:44:41 ipsec,debug ipsec: 7f667c9c 0ef33d1a b388c8ef 1b1ae8d8 c0df3836 68af01eb 0d041549 85c5b08e
nov/15 22:44:41 ipsec,debug ipsec: 8c5bbd08 ae410410 29302494 5009a1fb cbc1121e 8794d8a4 b4727f2a f9c53bd9
nov/15 22:44:41 ipsec,debug ipsec: 0000001c 00000001 01100001 54878e47 70d12b0d ee0c3df5 e8b5733d febdef95
nov/15 22:44:41 ipsec,debug ipsec: feeeeac4 ccb3d1a7 b8e5fcf1 b0f786d9 cca8b3c5 abb0e2b2 eaec8b1f
nov/15 22:44:41 ipsec,debug ipsec: b2da164a 0000001c 00000001 01100001 54878e47 70d12b0d ee0c3df5 e8b5733d
nov/15 22:44:41 ipsec,debug ipsec: seen nptype=12(delete) len=28
nov/15 22:44:41 ipsec,debug ipsec: xx.xxx.148.156 delete payload for protocol ISAKMP
nov/15 22:44:41 ipsec,info purging ISAKMP-SA 1.2.3.4[4500]<=>xx.xxx.148.156[60634] spi=54878e4770d12b0d:ee0c3df5e8b5733d:f4b95af2.
nov/15 22:44:41 ipsec,info ISAKMP-SA deleted 1.2.3.4[4500]-xx.xxx.148.156[60634] spi:54878e4770d12b0d:ee0c3df5e8b5733d rekey:0
nov/15 22:44:41 ipsec,info releasing address 192.168.0.70
nov/15 22:44:41 ipsec,debug ipsec: KA tree dump: 1.2.3.4[4500]->xx.xxx.148.156[60634] (in_use=1)
nov/15 22:44:41 ipsec,debug ipsec: KA removing this one...
Here's my current peer settings:
/ip ipsec peer print
Flags: X - disabled, D - dynamic, R - responder
 0   R ;;; Android IPSec
       address=0.0.0.0/0 local-address=1.2.3.4 auth-method=pre-shared-key-xauth secret="secret-psk" xauth-login="xauth-user" xauth-password="xauth-password"
       generate-policy=port-strict policy-template-group=default exchange-mode=main mode-config=request-only send-initial-contact=yes nat-traversal=yes proposal-check=obey
       hash-algorithm=sha512 enc-algorithm=aes-256,aes-128 dh-group=modp4096,modp3072,modp2048,modp1024 lifetime=8h dpd-interval=2m dpd-maximum-failures=5
/ip ipsec proposal print
 0  * name="default" auth-algorithms=sha512,sha256 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm,3des lifetime=8h pfs-group=modp2048
Users browsing this forum: Baidu [Spider], Szynku and 81 guests
