marwooj
OpenSSL and OpenVPN
Wed Nov 15, 2017 11:48 am
Hi, witch version of OpenSSL should I use to generate server and clients certificates to make OpenVPN work on hEX (RB750Gr3) 6.40.5?
gamba47
Re: OpenSSL and OpenVPN
Thu Nov 16, 2017 2:34 pm
Mikrotik does not support OpenVPN Client or Server.
best regards.
gamba47
Paternot
Forum Veteran
Forum Veteran
Thu Nov 16, 2017 3:05 pm
I generated mine last year, using whatever OpenSuse 42.2 gave me at the time. I don't think You will have much trouble with this, just use an up to date distro - or get the stable version from the project site.
normis
Fri Nov 17, 2017 1:55 pm
best regards.
gamba47
That is NOT true. Here is the manual:
https://wiki.mikrotik.com/wiki/OpenVPN
gamba47
Fri Nov 17, 2017 5:15 pm
Sorry :( , i mean UDP support. I forget some users can connect your vpn using OpenVPN over TCP.
cgood
Fri Nov 17, 2017 10:01 pm
Yes
> interface ovpn-server print count-only
113
  • MTCNA 99% '17
    MTCRE 89% '17
    MTCTCE 89% '18
cgood
Wed Feb 07, 2018 10:06 pm
ROS 6.41.1
*) ovpn - fixed resource leak on systems with high CPU usage;
  • MTCNA 99% '17
    MTCRE 89% '17
    MTCTCE 89% '18
Users browsing this forum: Bing [Bot], Znevna and 65 guests
