deanMKD1
Monthly Stats for WAN interface only?
Mon Nov 20, 2017 1:28 am
Hi Mikrotik
I used a shared internet connection, and at end of month i want to know how much traffic i have used. How is this possible? Can someone give me manual how to ? i used RB750Gr3 for routing and DHCP server.
Thanks in advance !
BRMateus2
Re: Monthly Stats for WAN interface only?
Mon Nov 20, 2017 11:56 pm
You can't get end of month GB consumption but can estimate by tool->graphing.
The GB can only be made by scripts. Not obtained as it doesn't have.
Remember to save to disk at highest interval possible or else your flash will be gone. Put 24hs.
deanMKD1
Tue Nov 21, 2017 1:57 am
Oh no other way ? i dont plan to save nothing on flash.
BRMateus2
Tue Nov 21, 2017 2:54 am
Unfortunately no 2-step feature. As MikroTik is not really meant to be housed but running into dedicated bandwidth and such.
I would like to implement such scripts but would occupy some of my time, but here's references:
Use version v1.5 from link redirect: https://wiki.mikrotik.com/wiki/Automate ... sermanager
Overkill solution, you will get very high precision: https://networkengineering.stackexchang ... n-mikrotik
For the least flash writes, the graphing is the easiest way.
You can also use simple queues other than interface graphing: viewtopic.php?t=50997
As I use queue tree, it doesn't apply to me.
And that topic also references Traffic-Flow, which works too.
aacable
Tue Nov 21, 2017 6:44 am
OR you can use scripting method as well to acquire data usage of particular wan interface using filter rules approach. you can save the data in txt file in mikrotik and configure it to email on every 1st of month and then reset counters.
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
Users browsing this forum: arkos, seriosha, simplextech, sindy and 170 guests
