triac
WDS-bridge or EoIP tunnel, which is the best solution?
Sun Dec 17, 2006 4:20 pm
Hi, which is the best solution for transparent bridge? WDS Bridge or EoIP tunnel? I mean which is the method that require much resources to the system?
Thank You
Paolo
Paolo Torri
believewireless
Sun Dec 17, 2006 4:34 pm
We're seeing only 50% of available bandwidth when using EoIP so stick with WDS.
FNC
Sun Dec 17, 2006 4:49 pm
believewireless
can u be precise more pls
cause i want to do transparent bridging and in wds bridge if the link disconnects it takes a long time to reconnect again
UniKyrn
Mon Dec 18, 2006 12:35 am
Use WDS where possible, because it allows bridging of the 1500 byte frames without having to split them into two smaller frames the way EoIP has to.
janisk
Mon Dec 18, 2006 12:36 pm
and use WDS in to ways - first - dynamic to see which links are stable and then select stable links and create static WDS environment. then disconnects will be brought to minimum.
and EoIP is more like ethernetish solution and since wireless is not duplex it hits performance pretty bad.
Users browsing this forum: didis81, mkx, PiGeonCZ, rocky10 and 115 guests
