jeroenvt
hAP mini looses all settings after reboot
Thu Nov 23, 2017 2:05 pm
I have a Mikrotik hAP mini, which I can configure via the web-interface and change any setting (SSID, passwords , etc). However, every time that I reboot (either via the webinterface, or by switching power off) all my settings are lost and the default factory settings are loaded instead. In the mean time, I have tried many things, like resetting by holding the reset button for 5 sec during boot, or a netinstall by holding the button for 15 seconds, but nothing helped. What could be the problem?
satspy
Re: hAP mini looses all settings after reboot
Wed Jan 24, 2018 10:44 am
Hi !
I have same problems, 6.41 version.
Two pieces of device, both looses all settings after power cut.
Help !!
Best regards !
LucZWFM
Wed Jan 24, 2018 12:55 pm
I have this problem with some SXT5HPnD devices and was never able to find out what's wrong...
The problem occours when doing the setting via webfig, maybe I should try with Winbox and see what happens...
Volunteer Techie @ZuidWest FM / ZuidWest TV, Stichting Repeater Bergen op Zoom & WRLP CB Repeater
jeroenvt
Wed Jan 24, 2018 7:43 pm
I have found a workaround by opening a "New Terminal" from the Webfig, or ssh directly into the router. At some point I opened a terminal from the Webfig interface. Then, to my surprise it did not give the command prompt directly, but it first displayed the full defconf script. I had to scroll down to the end (pressing space bar) before I got to the command prompt. Then I changed some settings again (not in the terminal, but in Webfig) and the settings that I changed suddenly remained after a reboot! And I did not see this line “Starting_defconf_script_” in the log file anymore. I do not know exactly why it helped to open a terminal, but it seems to me that somewhere this defconf scripts was stuck in a wrong place. I had an email exchange with Mikrotik Support. And the problem seems to be in the WebFig interface. A potential fix will be included in RouterOS version 6.41c.
LucZWFM
Thu Jan 25, 2018 9:40 am
Thanks Jeroen! I was about to throw away a device.
ctcjdnadmin
Thu Sep 13, 2018 10:11 am
I have 2 hex on version 6.43 and both lost their configuration after a power blackout..... :(
Users browsing this forum: bpwl, genesispro, Lifz, Zary and 95 guests
