ajmal
web-proxy
Mon Dec 18, 2006 4:27 pm
Dear all,
we are using MT-2.9.34 for network (using public IPs not natting)we ave 500 concurent client online its working fine.
whenever we enables web-proxy and redirect port-80 its start working but resources are 100% used and router gets slow(cpu 100% and RAM 70-80%)
we have 1 GB RAM and P-3-2.8GHz processor,Intel original MB.
We have also made restriction in cache to cache for ftp/MPe contents.
Why its happening help me.
[/list][/code]
macgaiver
Mon Dec 18, 2006 4:29 pm
use web-proxy-test
or better - use web-proxy from 3.0beta4
it is no secret that web-proxy 2.9 was slow.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
ajmal
Mon Dec 18, 2006 6:58 pm
i tried to upgrade MT 2.9.34 to MT 2.9.38,i uploaded newer ver in router and rebooted the router but still is shows MT 2.9.34
any mistake in updating ?
sergejs
Tue Dec 19, 2006 8:20 am
Check the logs 'log print' for the errors after router reboot.
Probably, you have used incorrect packages, there are two types one type for RouterBOARD500/100 and another type for other systems.
macgaiver
Tue Dec 19, 2006 11:51 am
Copy files to the root directory!
raivis-v
Tue Dec 19, 2006 12:20 pm
1) Delete any package file on router
2) Download packages from the web and upload once again
3) ensure you are using x86 version
4) As macgaiver said - ensure files are in root directory
5) reboot
edit:
If that does not help, connect to router locally and see what does it say on reboot. Usually it says something, if there are package files on it and upgrade process is not initializing.
ajmal
Tue Dec 19, 2006 1:05 pm
i tried and able to upgrade
but my purpuse was to solve web-proxy problem.
Its still there in 2.9.38 its shows cpu 100% useage.
is still bugs in web-proxy in newer version MT 2.9.38
Users browsing this forum: Bing [Bot] and 104 guests
