bluebsh
192.168.1.1 wont work as gateway suddenly
Thu Dec 07, 2017 4:02 am
I had my system set up and working for a year now with it's default gateway IP set as 192.168.1.1, which worked great until yesterday... I told it to do a routerboard firmware upgrade to the latest version, and suddenly I had no internet access after it rebooted.
I could ping everything in the 192.168.1.0/24 range including the gateway 192.168.1.1, I could connect via winbox, but for some reason the internet would not work at all.
I did a config reset and it went back to 192.168.88.1 and everything worked great.. so started rebuilding the config (restoring the config just went to the same issue immediately, requiring another reset).
Everything worked until I switched the router's IP back to 192.168.1.1, then suddenly I had "limited connectivity" according to windows... nothing outside my LAN would talk again. but still could ping it fine...
did another reset, and this time used quick set to set it up as a 192.168.1.1 gateway IP and DHCP range 192.168.1.100 - 254 and again no internet....
did a reset, and quick setup set it to 192.168.2.1 and a same DHCP range 192.168.2.x and worked....
change DHCP to 192.168.1.100 - 256 and widened my sub net to 255.255.0.0 and still worked as long as 192.168.2.1 was the gateway...
added 192.168.1.1/24 to the address list so I have it as a gateway too... switched my PC to talk to that gateway... and once again... no internet
reverted my firmware back, didn't help... rolled the routeros back to 6.40.5 and no change in behavior (was previously running an RC build to test out the bridge offloading)
I can't figure out what is going on... here's what my config looks like right now
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 6.40.5 (c) 1999-2017       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
[admin@MikroTik] > export
# dec/06/2017 21:00:59 by RouterOS 6.40.5
# software id = JGID-4PLY
# model = RouterBOARD 3011UiAS
# serial number = 5D6A05225239
add admin-mac=E4:8D:8C:7E:46:92 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
set [ find default-name=ether6 ] name=ether6-master
set [ find default-name=ether7 ] master-port=ether6-master
set [ find default-name=ether8 ] master-port=ether6-master
set [ find default-name=ether9 ] master-port=ether6-master
set [ find default-name=ether10 ] master-port=ether6-master
/ip neighbor discovery
set ether1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.2.1/24 comment=defconf interface=ether2-master network=\
    192.168.2.0
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.1.0/24 comment=defconf gateway=192.168.2.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=51.202.2.221/28 list=work_block
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=3389 protocol=tcp src-address-list=\
    work_block to-addresses=192.168.88.10 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3389 protocol=udp src-address-list=\
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/16
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
set time-zone-name=America/New_York
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
jarda
Re: 192.168.1.1 wont work as gateway suddenly
Thu Dec 07, 2017 8:53 am
Remove the bridge and all related settings. You are mixing ip ranges on the bridge and on the ether2 as its member. Correct the ip addresses everywhere, don't you see the 1.0, 2.0 and 88.0 mess in your export?
bluebsh
Thu Dec 07, 2017 3:39 pm
That's actually the wrong export... I was in the middle of making changes and dumped the wrong one ugh, wasn't thinking...
Like I said if I do a factory reset and take the default config then switch from 192.168.88.x to 192.168.1.x using quick set the same problem happens
It's only when it's set up to be 192.168.1.1 as the gateway... which never caused this issue before...
I can't even restore backup configs suddenly, as soon as I do that winbox wont even connect by MAC address (backup configs are from the same build)
bluebsh
Thu Dec 07, 2017 3:45 pm
Need to also add that my MAC address of the router keeps changing in winbox's neighbors lookup... one time it's E4:8D:8C:7E:46:92 the next it's E4:8D:8C:7E:46:97 it keeps alternating between those two... and usually when it switches it tells me the alternate one and I have to change it to the other to connect... I am not changing which ports I am plugged into, it just keeps seeing a different MAC address randomly
bluebsh
Thu Dec 07, 2017 3:50 pm
Did another reset and built some simple rules that I use for RDP in NAT but this is basically the initial config but with changed IP's... and once again internet will not work but I can ping 192.168.1.1 fine
  MikroTik RouterOS 6.41rc61 (c) 1999-2017       http://www.mikrotik.com/
# dec/07/2017 08:48:14 by RouterOS 6.41rc61
add name=mactel
add name=mac-winbox
add name=dhcp ranges=192.168.1.100-192.168.1.200
add bridge=bridge comment=defconf hw=no interface=sfp1
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.1.1/24 comment=defconf interface=ether2-master network=\
    192.168.1.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.100 client-id=1:44:8a:5b:9c:a5:94 mac-address=\
    44:8A:5B:9C:A5:94 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1 netmask=24
/ip dns static
add address=192.168.1.1 name=router.lan
add address=51.202.2.221/28 list=Work_Range
    invalid
    invalid
    Work_Range to-addresses=192.168.1.100 to-ports=3389
/ip upnp
set enabled=yes
/ip upnp interfaces
    invalid
    protocol=udp
    ipsec-ah
    ipsec-esp
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
/system package update
set channel=release-candidate
/tool mac-server
set allowed-interface-list=mactel
set allowed-interface-list=mac-winbox
[admin@MikroTik] >
w32pamela
Thu Dec 07, 2017 4:20 pm
What IP, Gateway etc is your router receiving on its WAN port?
bluebsh
Thu Dec 07, 2017 4:37 pm
WAN is just a DHCP'ed address from the ISP (Comcast) but it's current values are:
IP: 71.206.244.49
Mask: 255.255.254.0
Gateway: 71.206.244.1
I get the same address for all my tests issued to me, so I doubt it's a ISP gateway issue.
I need to add this also, when the internet doesn't work it's just on the lan side, I can ping and tracert perfectly fine from the winbox terminal window... so the router itself does have internet access
jarda
Thu Dec 07, 2017 4:54 pm
Put ip address on bridge instead of the ether2. Check the mac address of the bridge against other mac addresses of the router. To which port it corresponds?
bluebsh
Thu Dec 07, 2017 5:33 pm
Bridge MAC - E4:8D:8C:7E:46:92
ether1-E4:8D:8C:7E:46:91
ether2-E4:8D:8C:7E:46:92
ether3-E4:8D:8C:7E:46:93
ether4-E4:8D:8C:7E:46:94
ether5-E4:8D:8C:7E:46:95
ether6-E4:8D:8C:7E:46:97
ether7-E4:8D:8C:7E:46:98
ether8-E4:8D:8C:7E:46:99
ether9-E4:8D:8C:7E:46:9A
ether10-E4:8D:8C:7E:46:9B
sfp1- E4:8D:8C:7E:46:96
bridge and ether2 have the same mac from what I can see
putting the IP on the bridge instead doesn't help, same issue, internet doesn't work with the 192.168.1.1 address but does when changed to 192.168.2.1
ekpesinyang
Thu Dec 07, 2017 6:17 pm
Are you sure there's no device on your network that is running on that IP address. try and isolate the router and connect only your PC to it. How many port is the router? you can change the port as well.
i'll Never stop Learning....!!!!
Ekpedeme Inyang
jarda
Thu Dec 07, 2017 6:27 pm
Remove ip dns static. You should get outer dns server from your isp via dhcp or set 8.8.8.8 for testing purposes. By this setting you are looping the dns requests so you are not able to resolve ip addresses from domain names.
jarda
Thu Dec 07, 2017 6:29 pm
Use stable instead release candidate. Latest stable is 6.40.5.
bluebsh
Thu Dec 07, 2017 6:46 pm
already did that, no luck, doesn't mater what port the lan or wan is in either
bluebsh
Thu Dec 07, 2017 6:47 pm
Like I said in the original post, I've went back to that version to test and same issue, went back forward again to see if anything changed and still same issue
bluebsh
Thu Dec 07, 2017 6:50 pm
changing DNS doesn't make a difference, I've tried using comcasts 75.75.75.75 and googles 8.8.8.8 and quad9's 9.9.9.9
bluebsh
Thu Dec 07, 2017 7:06 pm
I also have no entries in DNS Static right now, no change
setting the local machine to a static IP and DNS on a system plugged into it also does not help
jarda
Thu Dec 07, 2017 8:58 pm
Post your actual config and the working config for comparison.
bluebsh
Fri Dec 08, 2017 2:54 am
Go to redo the config tonight to get the configs... and now it's not acting up....
ugh... I'm on 192.168.1.1 just fine right now as the gateway
ekpesinyang
Fri Dec 08, 2017 9:21 am
Are you saying it's okay now? If yes. What and where went wrong from your own observations please.
Ekpedeme Inyang
jarda
Fri Dec 08, 2017 9:49 am
Put here the config that works with 1.1 network.
bluebsh
Sun Dec 24, 2017 4:45 am
Problem solved? maybe?
I rebuild my entire network and reloaded all firmware again everything was working fine, only different is I did not have my RIPE Atlas Probe connected to the router, which I did the first time... just had not got to reconnecting it... well yesterday plugged it back in and everything was working ok until I powered up my system this morning and I had the yellow triangle on my Ethernet icon in the system tray in windows 10... said no internet, then suddenly it went away but there was no internet again...
3 minutes later internet worked...
thought odd, but didn't think much about it until later had my laptop boot and SAME THING!
tonight rebooted and when I did noticed it again... so I started trouble shooting... only this time I dumped the ARP table first... and got this...
Interface: 192.168.1.100 --- 0x2
Internet Address Physical Address Type
192.168.1.1 f8-1a-67-4d-51-cc dynamic
192.168.1.25 f0-9f-c2-15-e2-40 dynamic
192.168.1.30 00-11-32-48-7d-e5 dynamic
192.168.1.67 00-11-d9-57-6a-9f dynamic
192.168.1.125 f4-81-39-e3-1d-35 dynamic
192.168.1.252 ac-63-be-84-a6-a8 dynamic
192.168.1.255 ff-ff-ff-ff-ff-ff static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
notice anything odd? 192.168.1.1 is my router..... that isn't a microtik MAC.... that's TP-LINK which is the mfg of the device that RIPE uses for the Atlas Probes
after 3 minutes internet worked again so I dumped the ARP table again...
192.168.1.1 e4-8d-8c-7e-46-92 dynamic
well it's now microtik again! so I unplugged the atlas probe... rebooted and boom router somehow reports the TP-LINK MAC address again?! The probe isn't even connected!
reboot the router...... same thing....
Reflash the router and this stops happening.....
plug the probe back into the router and boom there it goes again!
I have no idea what it's doing but RIPE did do a software update in the past month to these, but somehow it seems to of broke something?! I don't know what but if I plug it in, somehow the routers MAC address starts getting handed out for ARP for 192.168.1.1 and continues after I disconnect the Probe until I reflash.....
can anyone understand why this would happen? It makes no sense to me at all.
Users browsing this forum: AndyGs, Google [Bot], sindy and 60 guests
