jrpaz
wAP-R Compatible LTE Modem?
Thu Dec 14, 2017 3:55 pm
Hi All,
I have an RBwAPR-2nD with a Quectel EC25-V LTE running on RC RoS 6.41.61 and the LTE card just shows up as android under the USB device section.
Do anyone have a wAP-R working with a 3rd party LTE card?
https://wiki.mikrotik.com/wiki/Manual:Peripherals is pretty much useless at this point as I have tried several adapters from here and they just don't work.
I have sent multiple support requests but no one has been able to address the issue.
jrpaz
Re: wAP-R Compatible LTE Modem?
Fri Dec 15, 2017 3:08 pm
It's working now I needed to go to ports - firmware and set the ignore-direct-ip-driver to yes & it reboot.
The issue I have is the same one I had with the Novotel 730L that it would reboot every few seconds and drop the connection.
wpeople
Thu Jan 25, 2018 11:08 pm
https://wiki.mikrotik.com/wiki/Cellular ... _modems_01
Check the above tutorial.
After initializing the modem with this: at+qcfg="usbnet",1
you will have the LTE interface, what is faster.
dc2
Sat Jun 23, 2018 12:01 pm
The above linked tutorial mentions to "tape" the usb3 pins on Ep06 in order for the modem to be recognized. Any idea which are these pins?
omidhe
Wed Dec 12, 2018 6:44 pm
This method is working !!
Thank you so much :) :)
Users browsing this forum: No registered users and 34 guests
