ajmal
bugs in proxy ussage 100% CPU
Thu Dec 21, 2006 3:17 pm
we are using MT 2.9.38 with web-proxy test packge as per suggestion of forum.
But still its showing 100% of CPU ussage.
we have 1000 active user and all the dst port 80 is redirected to use proxy our bandwidth consuption 5 Mbps.But redirecte traffice on proxy only shows max 30kbps.
Suggest me how to improve the performance of cache or still bugs in proxy.
ajmal
Sat Dec 23, 2006 9:16 am
Is there no solution for the same in miktotik router software
Alex
Sat Dec 23, 2006 3:43 pm
what is your cpu and how much memory do you have?
ajmal
Sun Dec 24, 2006 5:15 am
its intel P-4-2.8GHz and RAM is 1GB, HDD-40GB intel 845 motherboard
anything else required?
sergejs
Wed Dec 27, 2006 8:16 am
ajmal,
you can try 3.0beta version in the current scenario, however probably CPU load is not generated by the proxy package.
Probably there are a lot of connected clients to the router, that generate a lot of bandwidth and overload the router.
P.S.
It is more recommended to contact MikroTik support (support@mikrotik.com) with attached support output file in such cases.
ajmal
Fri Dec 29, 2006 6:45 am
ajmal,
P.S.
I monitored server and seen diffrence with proxy and without proxy.
but i would like to know how many client and server connection Mikrotik support while running proxy package i mean proxy is configured and transparent proxy running.
we have seen whenever 30-50 clinets are using proxy then somewhere its resources uses up to 60%.
as client base goes up in betweeb 70 -80 and above our resources get 100%.
(server configuration is P-4,2.8GHz,RAM-1GB,IDE-40GB,Intel-945MB, and RTL-chipset NIC)
hci
Long time Member
Long time Member
Sun Dec 31, 2006 8:05 pm
We are seeing a similiar problem. We have a 2.6Ghz P4 with 1Gbyte of RAM. Its serving 500 wireless and 240 dialup users. CPU usage is very high with proxy running. As I understand its the DST-Nat sucking all the CPU load. I have just ordered a single core AMD64 3800+ with 1Gbyte of DDR2. I am going to see how that changes things. Does Mikrotik 3.x support dual core?
A suggestion. Trash your Realteck NIC for a 3com or Intel. Realtech's are great cheap NIC's but not for high traffic tasks like this.
Matt
smacebr
High Performance Web-Proxy
Thu Feb 01, 2007 3:05 am
One High Performance Proxy would be great! Supporting multiples harddisks and sharing data with other proxies just like Squid does when well configured. But as always MK would make it easier to configure. A Dream :-)
monaro
hacked proxy
Fri Feb 16, 2007 9:07 am
I think your proxy might be hacked by someone outside (internet). I have 100% CPU Usage before. Turn out, a non customers is using my proxy.
Try to change your proxy port. Dont use 3128 port. Change your proxy port regularly.
Have you increased your RAM? How much RAM u using?
Users browsing this forum: dioeyandika and 49 guests
