Frostbyte
Ideas/Features for detnet
Mon Dec 25, 2017 3:19 am
Seeing the new detect-internet feature introduced on v6.41, I couldn't help but think how it can be further tooled to assist with WAN Failover mechanisms.
  • Introduce a GUI for it, in winbox.
  • Don't lock interfaces to states after X amount of time.
  • Allow the user to specify try (we have internet, and we check if we still have it) and retry (we don't have internet, and we check if it came back) intervals in seconds.
  • Allow the user to specify an IP/FQDN and port (optional) for testing, not just "8.8.8.8" or "cloud.mikrotik.com:30000"
  • Make on-event handlers, so users can execute scripts when the state changes. (e.g. Check for 3 consecutive failures, then alter the corresponding route distance)
  • Optional environment consisting of variables like: the ID of the 0.0.0.0 route associated with the interface we're checking internet connectivity for.
These are just a few ideas that I've already scripted in my own (home) infrastructure, if I think of any more, I'll be sure to follow-up.
marting
Re: Ideas/Features for detnet
Thu Feb 15, 2018 1:24 pm
I also have three questions/suggestions for this feature:
1. How stable is cloud.mikrotik.com. If this address is unreachable it doesn´t mean there really is no internet.
2. Will it be possible to have another Mikrotik router as check partner in future?
3. Which data is transmitted to cloud.mikrotik.com. Had a look into with packetsniffer and saw 32bytes but could not recognize pattern. As there is a bugfix of detect-internet with a too long Router identitiy I guess at least Routername is being transmitted.
manuelm
Wed Feb 27, 2019 6:46 pm
Thank you for Sharing your script, I noticed that your last commit was about two months ago, so I'm assuming that it will work with my router.
I'm trying to used your script on a RB3011UiAS (arm) router v6.43.12, but when I run the command $provision auto. I get the following errors.
[Pwhismadmn@HISM-Backup] > $provision auto
[Provision][Info]: Provisioning all available modules.
[Provision][Info]: Provisioning gateways.
[Provision][Error]: The configuration variable WANNames cannot be left empty or co
ntain an invalid value.
[Provision][Error]: The configuration variable WANGateways cannot be left empty or
contain an invalid value.
[Provision][Error]: The configuration variable WANGatewayPrefix cannot be left emp
ty or contain an invalid value.
[Provision][Error]: The configuration variable BalancingRulePrefix cannot be left
empty or contain an invalid value.
[Provision][Error]: The gateways configuration is invalid, please check the config
file and try again.
[Provision][Info]: Provisioning failover.
[Provision][Error]: The failover module depends on the gateway selector module, pl
ease provision it and try again.
[Provision][Info]: Provisioning dyndns.
[Provision][Error]: The configuration variable DDNSService cannot be left empty or
[Provision][Error]: The configuration variable DDNSUsername cannot be left empty o
[Provision][Error]: The configuration variable DDNSPassword cannot be left empty o
[Provision][Error]: The configuration variable DDNSHostname cannot be left empty o
[Provision][Error]: The dyndns configuration is invalid, please check the config f
ile and try again.
[Provision][Info]: Provisioning resolver.
[Provision][Info]: Provisioning livestream.
[Provision][Error]: The configuration variable LVStreamList cannot be left empty o
[Provision][Error]: The configuration variable LVStreamFQDN cannot be left empty o
[Provision][Error]: The configuration variable LVStreamRulePrefix cannot be left e
[Provision][Error]: The livestream configuration is invalid, please check the conf
ig file and try again.
[Provision][Error]: Completed with errors.
This is the configuration settings I'm using to test your script. I edited the original cfg file.
[Gateways]
WANNames=WAN1,WAN2
WANGateways=172.31.31.1,10.20.20.1
WANGatewayPrefix=Default route
BalancingRulePrefix=LDBLNCR
[Failover]
FailoverTarget=8.8.8.8
FailoverThreshold=1
FailoverInterval=1
[DynDNS]
DDNSService=NoIP
DDNSInterval=3600
DDNSUsername=username
DDNSPassword=password123
DDNSHostname=hostname.no-ip.org
[Livestream]
LVStreamList=Livestream
LVStreamFQDN=livestream.com
LVStreamRulePrefix=LVSTRM
Any help will be greatly appreciated.
Thank you,
Jose
Users browsing this forum: inteq and 76 guests
