MUM Europe 2020
ChildOTK
Shared radius server
Thu Dec 28, 2006 10:39 pm
Hi all,
I have 2 routeros servers now, and I would like the second server to use the same radius server as the first.
I thort I knew how to make it work, but obviously not, I keep getting radius time outs.
Is there anybody who has done such a thing? Is it possible?
Thanks.
tneumann
Thu Dec 28, 2006 10:58 pm
Is there NAT between your routers and the radius server?
ChildOTK
Thu Dec 28, 2006 11:27 pm
I haven't set up any NAT at all, just the masq rule for the clients to get access to the net.
tneumann
Thu Dec 28, 2006 11:39 pm
I'm not asking about NAT on your MikroTik routers but if there are any other routers between your MikroTik routers (which are the radius clients) and the radius server, and if there is NAT on any of these other routers that may be between your routers and the radius server...
--Tom
ChildOTK
Thu Dec 28, 2006 11:47 pm
oh, oops, sorry, no there is nothing between them, just a normal hub.
Mikrotik1|-----|HUB|------|Mikrotik2|------|Test Client|
In the hub is the AP, some other clients are also connected straight to the hub. Now for testing purposes, I have a test client, but trying to connect I get a radius time out on the system log of Mikrotik2. Mikrotik1 says nothing.
tneumann
Thu Dec 28, 2006 11:54 pm
I'm missing the radius server in your network picture...
Where/how is it connected?
ChildOTK
Thu Dec 28, 2006 11:56 pm
The radius server is sitting on mikrotik1
tneumann
Fri Dec 29, 2006 12:49 am
Ok, so you're using the RouterOS integrated userman package as a radius server?
--Tom
sergejs
Fri Dec 29, 2006 8:13 am
1. Make sure second router can access first MikroTik router, where User Manager is installed. Check that you can ping one from another.
2. Make sure you have added second router to the 'tool user-manager router' list, and RADIUS client is configured properly on the second router.
3. Check that RADIUS data is not blocked by the any firewall on them or between them.
ChildOTK
Fri Dec 29, 2006 12:17 pm
Tom,
Yes I am using the radius for userman on Mikrotik1.
sergejs,
Thanks, I will relook over my configuration, I must be missing something, I did add the second router to userman, but I guess I am missing the radius client config then.
This is done on the radius option on winbox? or is this another setting I need in the console?
sergejs
Fri Dec 29, 2006 12:21 pm
Yes, you can apply radius configuration in Winbox 'Radius' menu or '/ radius' in CLI.
User Manager documentation on the wiki provides the configuration for the User Manager and remote routers configuration,
e.g. http://wiki.mikrotik.com/wiki/User_Mana ... ot_Example
ChildOTK
Fri Dec 29, 2006 11:53 pm
Thanks everybody, I redid the configuration, and now its working, thanks for the help :D :D
Users browsing this forum: draid, MSN [Bot], vortex and 147 guests
