MUM Europe 2020
silodk
Show user ip on lan side
Fri Jan 19, 2018 9:28 am
Hi all,
I have a Mikrotik router and a Synology nas.
Before I got the MK router I was able to see the IP of users logged into my NAS.
Now when users log in to my NAS from outside my lan I can only see the router local ip address.
I want to be able to see the users real internet IP in the logfile of my NAS.
I don't know what that option is called or how to fix it.
Thank you very much..
Br. Simon
matiaszon
Re: Show user ip on lan side
Sat Jan 20, 2018 3:34 pm
Post result of:
/ip firewall export hide-sensitive
solar77
Sat Jan 20, 2018 5:12 pm
if you used dst-nat for your NAS, you should see the external IP when they going through the fireware and the NAS device should see it too.
MTCNA MTCTCE UEWA
Sob
Sun Jan 21, 2018 1:22 am
Most likely there's just:
instead of proper:
add action=masquerade chain=srcnat out-interface=<WAN>
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
sebastia
Re: Show user ip on lan side  [SOLVED]
Sun Jan 21, 2018 3:08 am
instead of proper:
Like this is even more precise
add action=masquerade chain=srcnat out-interface=<WAN> src-address-type=!local
silodk
Tue Jan 23, 2018 2:47 pm
Thank you very much. The last one here worked perfect! You are GREAT!
Users browsing this forum: Google [Bot], rebel2234 and 97 guests
