Arpanet
Routing Issue accross multiple LANs
Fri Jan 19, 2018 12:00 pm
I cannot find a routing table that works for accessing via winbox every single host in each lan from my office network.
As you can see there are multiple NAT layers.
Below network map:
Arpanet.
There's no distance in the world.
sebastia
Re: Routing Issue accross multiple LANs
Fri Jan 19, 2018 1:03 pm
Hi
which network you you have defined between
* left 3011 and centre
* right 3011 and centre
These routes are added automatically for you when you define the local ip. Then just access "left" & "right" 3011's by ip's on these networks.µ
=> that's just for RB's
To access the whole network:
* either setup automatic routing propagation
* or add static routes to all networks: you have a static network with no loops so that should be fairly straightforward
Ex
static on central 3011
"75" go left
"19" go left
"40" go left
"76" go right
"18" go right
"20" go right
similar for "left" & "right" 3011
payam124
Trainer
Trainer
Fri Jan 19, 2018 1:41 pm
as the network is not so big, you can exclude destinations toward your OFFICE LAN from all the NATS and also write a few static route on each router for the OFFICE LAN
Arpanet
Fri Jan 19, 2018 1:59 pm
RB3011 FROM MY OFFICE LAN:
0 192.168.1.62/24 199.168.1.0 bridge2 -->INTERNET GATEWAY
1 192.168.15.1/24 192.168.15.0 bridge1 -->OFFICE LAN
2 192.168.19.150/24 192.168.19.0 ether3 -->RB3011 192.168.19.1
3 192.168.18.150/24 192.168.18.0 ether9 -->RB3011 192.168.18.1
ROUTES:
0 A 0.0.0.0/0 192.168.1.1 STATIC
A S DST-ADD 192.168.75.0/24 GW 192.168.19.1 STATIC
A S DST-ADD 192.168.76.0/24 GW 192.168.18.1 STATIC
ADC 192.168.15.0/24 192.168.15.1 bridge1 DYNAMIC
ADC 192.168.18.0/24 192.168.18.150 ether9 DYNAMIC
ADC 192.168.19.0/24 192.168.19.150 ether3 DYNAMIC
With this config Ican only ping devices within each lan but no winbox access.
Arpanet.
sebastia
Fri Jan 19, 2018 3:42 pm
Your central RB, is directly connected to both RB "left" & "right". There are "connected" routes defined for them with distance 0.
You SHOULD be able to connect to them, if you can't check firewall settings.
Arpanet
Fri Jan 19, 2018 3:43 pm
no firewall enabled in each rb3011
Arpanet.
acruhl
Fri Jan 19, 2018 3:47 pm
Short answer, get rid of all the natting and run a routing protocol, then you don't have to worry at all. It would all "just be connected".
I'm probably missing the reason why you're using so many nats though.
Stuff.
sebastia
Fri Jan 19, 2018 5:50 pm
Few other things to check:
* can you access winbox from other location(s) on these routers (at all)?
* is the windbox service enabled? Are there any limitations on it?
* has the user on these routers the right privileges?
* how are you accessing it? over ip or mac? if ip, which?
Users browsing this forum: MSN [Bot] and 98 guests
