Sat Jan 27, 2018 10:11 am
Hello all I have a CCR 1036 that apparently has a memory leak I use this box for a bandwidth manager using pcq's and queue trees as the queing method. The router started to reboot during heavy traffic times throwing an error stating kernel failure out of memory detected. I replaced the device with a new CCR 1072 with the same configuration. The issue persisted now with a beefier router it has exacerbated the issue now rebooting about every 30 minutes. When I check the memory stats under tools graphing I see the memory Maxis out then the router reboots. I have tried updating to the newest release candidate with no luck. Any help would be appreciated I have about 3,000 clients affected. Thank you
