markovip
Serial Terminal issue CCR1009
Mon Jan 29, 2018 2:50 am
Hi, we are WISP considering moving our network to Mikrotik routers.
I'm trying to make script for General Electric UPS's we have, but get strange beehive of serial-terminal.
When trying to communicate to the UPS, I only get "p" and beeps. This is the terminal output (values for connection are correct).
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 6.41 (c) 1999-2017       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
[admin@CoreRouter] > /port print detail
Flags: I - inactive
 0   name="serial0" used-by="" device="" channels=1 baud-rate=1200 data-bits=8 parity=none stop-bits=1 flow-control=none
 1   name="serial1" used-by="" device="" channels=1 baud-rate=auto data-bits=8 parity=none stop-bits=1 flow-control=none
[admin@CoreRouter] >  /system serial-terminal serial0
[Ctrl-A is the prefix key]
 p
  p
  p
  p
  p
When trying PuTTY for remote serial access get even more wired staff:
login as: serial
serial@192.168.3.178's password:
▒p▒
▒▒p▒
▒▒p▒
▒▒p▒
Tried null-modem cable and a LOOP one also.
Already run out off of ideas.
Any clue?
donsergio
Re: Serial Terminal issue CCR1009
Wed Jan 31, 2018 8:47 pm
Hi, your UPS is not supported, only APC are supported and through serial port (not USB).
Regards!!
donsergio
Wed Jan 31, 2018 8:48 pm
Only APC brand are supported and through serial port (not USB)
https://wiki.mikrotik.com/wiki/Manual:System/UPS
Regards!!
markovip
Sun Feb 04, 2018 1:06 am
Regards!!
Hi, I perfectly know this, it's why I'm making my own scripts.
Although I cannot get any useful reply from UPS from a $500 router...
Maybe some reply from the Mikrotik Company? @janisk
Users browsing this forum: No registered users and 113 guests
