neutronlaser
Fast Path not being used
Fri Feb 02, 2018 8:46 pm
Hi
I have a Mikrotik CRS125-24G-1S-2HnD operating as a router for a cable modem with internet access. I have a computer connected to a port, and a POE switch connected to a few CCTV IP cameras. The cameras send video data to the server. When I look at the traffic stats for the ports, they are not using Fast Path.
How/can I make this traffic use Fast Path and save CPU?
Connection Tracking is on Auto, and IGMP Snooping is off. Fast Forward is On for the bridge-local.
jarda
Re: Fast Path not being used  [SOLVED]
Fri Feb 02, 2018 8:49 pm
Most probably you are using the switch so there is no cpu involved in processing of internal traffic at all. At least you should, in any other case.
neutronlaser
Fri Feb 02, 2018 8:53 pm
Thanks, so using the Switching chip is different from Fast Path?
jarda
Fri Feb 02, 2018 8:57 pm
Absolutely. It is hw switching in separate chip against sw bridging by cpu.
neutronlaser
Fri Feb 02, 2018 8:58 pm
Thank you.
neutronlaser
Fri Feb 02, 2018 9:04 pm
Are there any disadvantages to using Fast Forward (which I assume is the same as Fast Path)?
jarda
Fri Feb 02, 2018 9:09 pm
It is not the same. See the manual.
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
neutronlaser
Fri Feb 02, 2018 9:13 pm
Thank you.
Users browsing this forum: MSN [Bot] and 104 guests
