MUM Europe 2020
Johan
Hotspot on vlan of bridge
Thu Jan 04, 2007 4:14 pm
I am trying to setup a hotspot on a vlan interface which is member of a bridge. I get DHCP from the server on the client.
But the loginpage doesn't appear.
The client (00:13:02:C4:BC:28) is connected on a another ap which has the wlan interface bridged with the vlan interface on the same rstp_bridge.
The both ap's are connected by a static WDS which is ofcourse member of the bridge to.
The hotspot server is running on the interface hotspot.
Remarking when i disabled the hotspot server, and the router is just masquading the data! everything works well.
/int bri port pri
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE  BRIDGE         PRIORITY PATH-COST
 0    wds2       rstp_bridge    0x80     10
/int vlan pri
 #    NAME                             MTU  ARP        VLAN-ID INTERFACE
 0  R management                       1500 enabled    1       rstp_bridge
 1  R hotspot                          1500 enabled    200     rstp_bridge
/int bri host pri
Flags: L - local, E - external-fdb
  BRIDGE         MAC-ADDRESS       ON-INTERFACE   AGE
L rstp_bridge    00:0B:6B:56:80:29 wds2           0s
  rstp_bridge    00:0B:6B:57:07:17 wds2           15s
  rstp_bridge    00:0C:42:04:ED:B6 wds2           15s
  rstp_bridge    00:13:02:C4:BC:28 wds2           0s
How could i solve the problem. It looks that the hotspot server is not working well with the mac addresses.
and when i look at the bridge host table i saw the mac address on 'wds2' but it is incapsulated in a vlan message. It may not appear i think?
best regards,
Johan
uldis
Thu Jan 04, 2007 4:26 pm
you can't run hotspot on the interface that is a part of the bridge, you should run on the bridge interface then.
Johan
Thu Jan 04, 2007 5:01 pm
No I didn't run it on a interface of the bridge. But on a vlan interface of the bridge
tneumann
Fri Jan 05, 2007 11:21 am
You should define your VLAN interfaces on top of a physical ethernet port and not on top of the bridge interface, and then you need to add the VLAN interfaces as member ports to the bridge. Then run the hotspot on the bridge interface.
--Tom
Johan
Fri Jan 05, 2007 11:49 am
So in this case i'am not allowed to bridge a `trunked`line which is running rstp? So i couldn't use dynamic WDS anymore between my ap's.
Notify again that without hotspot the situation works fine.
Johan
Johan
Solved hotspot problems by changing firewall rules
Thu Jan 11, 2007 9:22 pm
I've take a look in the firewall rules, and is saw the dynamic hotspot rules are not locked to a in-interface. So i've tested by a self created rule, and then finally it works.
So Mikrotik engineers may i have the request to able to set the in-interface rules or set them by default.
Johan
peson
Trainer
Trainer
Mon Feb 05, 2007 12:44 am
Johan!
Have a look in our presentation from MUM in Krakow and it will give you some ideas of how to setup VLAN´s and HotSpot in a wireless environment.
riv
Mon Feb 05, 2007 3:14 am
Hi johan ...
Try to run your hotspot oh the bridge interface (ex: bridge1)
Users browsing this forum: aosiqing, Google [Bot], Lazar77 and 89 guests
