MUM Europe 2020
kojikabuto
DEVICE HACKED
Thu Feb 08, 2018 9:17 am
Hello everyone
I was testing a new router RB2011UiAS-2HnD-IN and I forgot to enter password : ( (my bad) I suffered an attack by telnet and someone hacked the router, changed the password and changed the identity to HACKED.
I reset the router, restored the backup, put a password, created a new user and deleted admin, and also disabled the services ssl, telnet, ftp, www
apparently there have been no connection attempts in 24 hours
BUT, in the console, it looks like the message DEVICE HACKED - ACCOUNT ADMIN HAD UNSAFE PASSWORD.
Now I'm not in front of the router, but I think there was a new file maybe can be a /system note ? (i have just realized)
Is my router still safe?
thanks in advance
PS: I'm totally amateur
normis
Re: DEVICE HACKED
Thu Feb 08, 2018 10:07 am
Post a screenshot of the message, we'll see where the message came from
kojikabuto
Re: DEVICE HACKED
Thu Feb 08, 2018 5:34 pm
Here is
TomjNorthIdaho
Re: DEVICE HACKED
Thu Feb 08, 2018 7:41 pm
reset it to default config , then re-program it.
Or , possibly , you can do an /export and look at the config and fix it.
I myself would just default the config then re-configure it.
North Idaho Tom Jones
CZFan
Re: DEVICE HACKED
Thu Feb 08, 2018 8:04 pm
Personally I would netinstall it, not just reset to default
MTCNA, MTCTCE, MTCRE & MTCINE
juliokato
Re: DEVICE HACKED
Thu Feb 08, 2018 10:13 pm
Just delet the sys-note.txt file.
Or create your sys-note.txt.
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
esencialatina
Re: DEVICE HACKED
Sun Sep 16, 2018 9:27 pm
I have Exactly the same issue in 02 differents offices.................... Some is wrong with Mikrotik.
WE NEED HELP..... Mikrotik
normis
Re: DEVICE HACKED
Mon Sep 17, 2018 12:17 pm
Guys, if your device has no firewall and winbox is open to the world, your device is in danger. Please upgrade, change password, and then inspect every line of configuration for things you don't recognize. Remove everything your don't recognize, then implement a secure firewall according to the manual.
datispro
Re: DEVICE HACKED
Mon Sep 17, 2018 12:32 pm
you can solve by create your sys-note.txt.
We thinks Mikrotik is the best solution for network Jobs.
Mikrotik Course - mikrotik
Users browsing this forum: Google [Bot] and 94 guests
