mip
route en/dis
Tue Nov 02, 2004 4:38 pm
I try to enable/disable route list item 0 from a script.
I wrote this:
/ip route pr
/ip route en 0
No effect
I wrote it into winbox's script editor, and tried { } version too. No effect. Whats wrong?
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
[ASM]
Tue Nov 02, 2004 4:47 pm
try:
/ip route disable [/ip route find gateway=xxx.www.yyy.zzz]
or something like that
mip
Tue Nov 02, 2004 4:49 pm
the task is that if an ospf distributed def gw is unreacable, a static def route should be enabled. So in normal I have a route for 0.0.0.0 from ospf, and a disable static. If a spec ip has no answer from netwach, the static route should be enebled, if has answer, disabled.
Users browsing this forum: cedie, dioeyandika, eworm and 52 guests
