Kazek
VLAN priority
Mon Feb 12, 2018 1:00 pm
Hi all!
I'm reading this forum for a long time but now is a time to make an account since I'm stuck with a problem and there is no solution (or at least I did not find it)
I have a hAP Lite with newest RouterOS.
The eth1 has a tagged VLAN50 and port 4 is untagged VLAN50. There is an extra bridge to connect those 2 interfaces (eth1-vlan50 and ether4)
The VLAN is created for an IPTV (multicast).
My question is how can I priority the VLAN50 in Mikrotik, so the internet traffic would not affect IPTV since it's very sensitive. When someone is downloading the TV image gets shuttered.
Any help would be greatly appreciated!
Cheers!
sindy
Re: VLAN priority
Tue Feb 13, 2018 3:07 pm
Two points here:
  • as you say you have configured "another" bridge for the IPTV VLAN, it is likely that this particular bridge doesn't enjoy the "hardware support" which means that the frames between the two Ethernet ports have to pass through CPU instead of being switched by the switch chip, which theoretically means that if your CPU load is high, some frames may get seriously delayed or lost.
  • prioritization consists in sorting packets into different queues on output, so that the more important ones could overtake the less important ones when choosing the next one to be sent out over a limited bandwidth link. But as you are sending the IPTV packets to your STB via a dedicated Ethernet port, the output bandwidth should not be an issue (because it is not shared with any other traffic). So either the CPU load is the reason, and in such case, using a common bridge for all VLANs (which would mean that the switch chip would take care of all L2 processing) should be enough, or there is something wrong with prioritization of the traffic already at your ISP, and in such case, your only possibility is to throttle the speed of the download by limiting the output bandwidth of the other-than-IPTV traffic to the value of your total downlink bandwidth minus the bandwidth required for the IPTV traffic.
Can you post the output of "/export hide-sensitive" and the output of "/tool profile" while the issue you describe exists (heavy download causing the IPTV picture to deteriorate)?
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
skuykend
Re: VLAN priority
Tue Feb 13, 2018 6:49 pm
Would probably be best to make Ether1 part of the switch group with all other ports (default the untagged internet to something like vlan 40 and make that your new WAN interface) and let the switch do the work of passing the multicast at wire speed.
Then the router just has to work on the routing for your internet and not the IPTV multicast.
sindy
Re: VLAN priority
Tue Feb 13, 2018 7:15 pm
Well, I wasn't clear enough, suggesting to move everything into a single (and thus hardware-assisted) "bridge" in my second point instead of the first one.
So to be more specific for @Kazek - yes, VLAN1 in the "one-for-everything" bridge will stay for the LAN, a new interface of type "VLAN" with VLAN X (e.g., 40) will be created to become the new WAN interface, and you move to it the WAN IP address from ether1. Doing so will make ether1 free for making it a member of the "one-for-everything" bridge and permitting only VLAN 40 (untagged, i.e. pvid=40) and VLAN 50 on it. Ports ether2 and ether3 will be members of that switch on which only VLAN 1 will be permitted untagged (pvid=1) as they are now, port ether4 will be a member with only VLAN50 permitted untagged (pvid=50).
Kazek
Re: VLAN priority
Thu Feb 15, 2018 2:44 pm
Hi guys,
Although I do understand the idea of your solution I'm not quite sure how to achieve it. To help I will show you my config I'm using but with this solution all the IPTV traffic goes through CPU instead of a switch, right?
/interface vlan add interface=ether1 name=eth1-vlan50 vlan-id=50
/interface bridge add name=bridge-vlan50
/interface bridge port add bridge=bridge-vlan50 interface=eth1-vlan50
/interface bridge set bridge-vlan50 protocol-mode=none
/interface bridge port set bridge=bridge-vlan50 [find interface="ether4"]
sindy
Re: VLAN priority
Thu Feb 15, 2018 2:52 pm
Yes. If your RouterOS version is 6.41 or higher as I suppose from what you wrote initially, place here the complete output of "/interface export hide-sensitive", I'll send you back a modified version. (the hide-sensitive prevents your wireless passwords from being exported).
About the same can be achieved in older ROS versions where settings for switch and bridge are completely separated, by setting handling of VLAN 50 on the switch, but I never needed to do that on these older versions so it would be only a theoretic solution from my side.
Kazek
Re: VLAN priority
Thu Feb 15, 2018 3:11 pm
Sorry, totally forgot about that.
# jan/02/1970 00:01:22 by RouterOS 6.41.2
# software id = Y6S2-KRBE
# model = RouterBOARD 941-2nD
# serial number = 7DE308027A97
add admin-mac=CC:2D:E0:02:62:03 auto-mac=no comment=defconf name=bridge
add name=bridge-vlan50 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=netherlands disabled=\
    no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-026206 \
    wireless-protocol=802.11
/interface vlan
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge-vlan50 comment=defconf interface=ether4
pe1chl
Re: VLAN priority
Thu Feb 15, 2018 3:21 pm
Are you sure this is caused by the router? How is the VLAN50 to ISP connection? Is ether1 directly connected to the ISP? Is VLAN50 prioritized by the ISP?
What is the total datarate of the connection and the rate used by TV? Is the CPU load of the router at or near 100% when you download?
Kazek
Re: VLAN priority
Thu Feb 15, 2018 3:37 pm
No, but I want to start with setting it up correctly, so the traffic is processed by switch not CPU.
VLAN50 is connected to separate router and separate ISP (separate uplinks for each VLAN in the switch).
The switch has QoS with VLAN1 on 802.1p level 0 and VLAN50 on level 6
IPTV ISP is 200/20mbps, SDTV is using 3-4mbps per stream, HDTV 8-9mbps per stream. It's a multicast stream. The CPU gets to 50-60% on full load
pe1chl
Re: VLAN priority
Thu Feb 15, 2018 4:36 pm
Ok you can still configure the switch to do this VLAN instead of the bridge, in the old way.
(add the VLAN to the switch and configure port 4 with that VLAN and always-strip)
This performs better than the new "vlan aware bridge" which does not support hardware-accel, no idea why.
The reason I ask is because when the line is saturated by internet traffic and there is not the proper priority for the VLAN, there will still be problems.
So e.g. when your internet connection is faster than the ethernet link, this could be the case.
Buying such low-end equipment for situations like this does not help either...
sindy
Re: VLAN priority
Thu Feb 15, 2018 5:16 pm
Can you be more specific? Do you have in mind that the hardware acceleration is not supported on this particular Mikrotik model or in general?
My experience is such that the hardware support works for just one of the bridges created the new way, which seems quite logical to me so I never thought deeper about that. So creation of a single common bridge for everything which requires more than a single ethernet interface is normally enough to have the switch do everything it can do.
pe1chl
Re: VLAN priority
Thu Feb 15, 2018 5:45 pm
Once you enter VLANs into the new bridge the hardware-access is turned off except in CRS3xx switches.
See this: https://wiki.mikrotik.com/wiki/Manual:S ... Offloading
This is really a big pity, because before this new bridge was introduced the natural way was to configure
the VLANs in the switch config and it was hardware accelerated on almost all models.
(there are some problems with hybrid ports in that method)
sindy
Re: VLAN priority
Thu Feb 15, 2018 6:43 pm
Taking into account what @pe1chl has pointed out, here's my response:
Assuming that you configure the router while connected to ether2, ether3 or wlan, and that you can interrupt the internet uplink and the IPTV transit for a while, you would do the following:
  1. backup the existing configuration in order to be able to restore it if something doesn't work as expected
  2. check in the configuration of the upstream router that VLAN 40 is not permitted at the port to which your mikrotik's ether1 is connected; if it is, choose a VLAN ID not permitted at that port for use instead of the 40 for the steps below
  3. add the following to the configuration:
    /interface vlan
    add interface=bridge name=vlan40 vlan-id=40
  4. change the interface to which your static uplink IP address is attached from "ether1" to "vlan40", or move the dhcp client from "ether1" to "vlan40" if you don't use a static address
  5. replace "ether1" by "vlan40" in "/interface list member" for list=WAN
  6. check all your firewall rules (filter, NAT, mangle, raw) and if any of them checks for in-interface or out-interface "ether1", replace that respectively by in-interface-list or out-interface-list "WAN"
  7. remove the following items from the configuration:
    /interface vlan
  8. add the following items:
    add bridge=bridge interface=ether1 pvid=40
    add bridge=bridge interface=ether4 pvid=50
  9. inform us about the result :-) (whether it works at all and whether it has removed the issue with the IPTV performance)
As you wouldn't add the vlan filtering rules and wouldn't switch on the vlan-filtering for the bridge, hardware acceleration should work (please put here the result of "/interface bridge port print") and VLAN 50 should be only running through the switch.
skuykend
Re: VLAN priority
Fri Feb 16, 2018 3:09 am
Not completely true. Only if you set the switch bridge to use vlan-filtering=yes and try to use the bridge vlan menu to set up vlans.
That's not the proper method for the smaller/non-CRS3xx switch chips.
You can still get hardware accelerated vlans by using the pre-6.41 way with only a couple changes. Only difference is to use a bridge to set up the swtich group instead of a master port and then, for any needed management/routing vlans,under /interface vlan use the bridge as the parent interface instead of the old master-port. You still use the switch menu to set up what vlans are allowed on what ports, default vlan-id, etc.
pe1chl
Re: VLAN priority
Fri Feb 16, 2018 10:32 am
I know that the old method still works, but I expect that it is to be phased out.
At the moment the switch/bridge situation, that was already difficult for some people, has become completely unclear.
As it is now, when I configure all the VLAN stuff on the bridge (including tagged/untagged ports) but I just leave out the "vlan-filtering=yes",
what will happen? Will it still process the VLANs and enable hw accell but is there some lack of filtering e.g. of unspecified VLANs?
That is not clear from the documentation, at least not to me.
And in fact I don't understand why the old situation of having a configured switch chip with a couple of VLANs and some tagged/untagged
ports plus VLAN interfaces on the master-port (cpu port) to attach them to the router, cannot be translated into the new VLAN-aware bridge configuration
with all VLANs in a single bridge and the same VLAN interfaces on the bridge instead of the master-port, without losing the hardware
accelleration between the ports. I can understand that it is lost when you enable some advanced function like bridge firewall, IGMP
snooping, spanning tree etc on a chip that does not have the capability, but why not simple VLAN tagging/untagging??? All those chips
should support that in hardware...
sindy
Re: VLAN priority
Fri Feb 16, 2018 12:52 pm
This is why I hope that the current stage of integration of "bridge" and "switch" configuration into one is only an intermediate one - as even the simpler switch chips can be told to filter VLANs, I hope the vlan filtering will eventually also be made "hardware-assisted". Similarly, the need to explicitly indicate that the bridge is a tagged member of itself in the vlan-filtering rules under "/interface bridge vlan" if you want to open the path to CPU (and thus wlan and vlan interfaces) will I hope disappear later on.
pe1chl
Re: VLAN priority
Fri Feb 16, 2018 2:56 pm
I agree! This one got me when I tried to convert my old multi-bridge + switch VLAN configuration into the new single-bridge.
It is shown in an example but it is easy to miss and it should not really be required to have this, it could be default or it could be auto-enabled when there is a VLAN interface attached to the bridge.
Only when I came back to this task on another day I found this mistake...
saluthiago
Re: VLAN priority
Sat Feb 17, 2018 2:05 am
!as you receive iptv and internet would be in separate vlans because I have internet plus iptv on my router the to work very well!
Kazek
Re: VLAN priority
Tue Feb 27, 2018 5:21 pm
sindy the internet part works - but when plugged to port 4 still getting internet not into vlan 50
Is this really the way to configure it (with dummy vlan40?)
sindy
Re: VLAN priority
Tue Feb 27, 2018 8:04 pm
As I've found in the meantime, the incorporation of switch chip configuration into bridge configuration is not as tight as it seemed to be, plus the switch chip used in your machine (hAP lite) is an ar8227 which does not support hybrid ports (where one or more VLANs may be present tagged and a exactly one VLAN untagged). Luckily, it does support ingress tagging and egress untagging on an access port as well as internal forwarding of untagged packets.
So if you could make the internet come also tagged with VLAN ID 40 to ether1, it would be much easier to handle and it would be possible to have ether2 and ether3 (LAN ports) hardware accelerated; if you don't mind having the LAN ports not hardware-switched together, it would make it a bit easier but there may still be problems. What is your standpoint on these two points?
sindy
Re: VLAN priority
Sun Mar 04, 2018 9:18 pm
I have made some tests with 8227 switch chip and the result is that VLAN ID 0 (which is normally reserved to indicate that the 802.1Q tag only carries the CoS information) can be used to control handling of tagless packets on the switch chip, so you can have
  1. internet uplink tagless together with IPTV tagged on the same physical interface (ether1)
  2. tagless IPTV alone on another physical interface (ether4)
  3. if required, tagless LAN on the remaining physical interfaces (ether2, ether3) still with "hardware acceleration" (forwarding by the switch chip) between these two interfaces.
To do that from the default CPE configuration, you need to:
  • keep the currently existing bridge (referred to as "bridge-lan"), with member ports ether2 and ether3 and the current LAN IP configuration attached to it, except that you would change the "hw" setting to "no" in "/interface bridge port" settings. Detach ether4 from that bridge.
  • create another bridge (named e.g. "bridge-wan" or just "bridge" if the final goal is to implement point 3 above as well), with "protocol=none"
  • attach the WAN IP configuration (static, dhcp client, pppoe client - whatever) directly to "bridge-wan" itself, and make ether1 a member port of "bridge-wan" with "hw=yes"; if anything in your firewall refers to "ether1", make it refer to "bridge-wan".
At this point, you should still have access to internet.
Next, you would prepare the VLAN filtering/membership rules in the switch chip:
add switch=switch1 vlan-id=0  ports=switch1-cpu,ether1
add switch=switch1 vlan-id=50 ports=ether1,ether4
add switch=switch1 vlan-id=33 ports=switch1-cpu,ether2,ether3
The last line above, with vlan-id=33, is only necessary if you want hardware-accelerated forwarding between ether2 and ether3.
Now it is time to activate safe mode - if you eventually lose connection to the box if one of the following steps is wrong, it is enough to wait a minute or two and then connect again.
The following step is to change VLAN handling (vlan-mode and vlan-header) on the switch chip ports. By default all of them are set to "vlan-header=leave-as-is vlan-mode=disabled".
set switch1-cpu default-vlan-id=0 vlan-mode=secure
set ether1 default-vlan-id=0 vlan-mode=secure
set ether4 default-vlan-id=50 vlan-mode=secure vlan-header=always-strip
At this point, you should have IPTV working (forwarding between tagged ether1 and tagless ether4 done by the switch chip), internet uplink working, and access to the LAN working as well.
If you want the hardware-accelerated forwarding between ether2 and ether3, do the following, again with safe mode activated:
  • create a new "interface vlan" with "vlan-id=33" and "interface=bridge-wan" and e.g. "name=vlan33"
  • attach to it a new IP subnet (a temporary one, so do not configure a DHCP server on it if you can set up the address of your PC manually)
  • modify your firewall so that it handles packets to/from "vlan33" the same way like packets to/from "bridge-lan"
  • depending on to which port out of (ether2, ether3) you are connected, change the other one's VLAN handling:
    /interface ethernet switch port set etherX default-vlan-id=33 vlan-mode=secure vlan-header=always-strip
    /interface bridge port set [find interface=etherX] bridge=bridge-wan hw=yes
  • log out, reconnect your PC to etherX (and configure manually its IP settings if you haven't configured a DHCP server for VLAN 33), and log in again to Mikrotik's address in VLAN 33
  • repeat the setting above for the other LAN port
  • move the original LAN IP configuration from "bridge-lan" to "vlan33" in parallel to the temporary one. You can have several IP subnets on the same interface but you can only attach a single DHCP server to an interface, so if you had to configure a DHCP server on vlan33, you now have to remove it before you can attach the one serving the original LAN subnet to it.
  • log out and either change your PC's IP configuration back to DHCP client or just disconnect and reconnect the cable if you haven't changed the IP configuration to static
  • log back in with the original IP address of your LAN.
  • remove references to bridge-lan and bridge-lan itself
Done.
Users browsing this forum: Bing [Bot], Google [Bot], kvstudio6 and 66 guests
