mozerd
CCR1009 and NAND memory
Mon Feb 12, 2018 2:54 pm
Can someone please inform me on How can I check the integrity of the NAND memory?
Is there a CLI command that displays the status of the NAND?
On my CCR1009 I am running RouterOS v 6.42rc24 and I am using Winbox v 3.12
Via WinBox system resources doe not show the status of the NAND --- it show memory usuage but not condition of the NAND
samsung172
Re: CCR1009 and NAND memory
Wed Feb 14, 2018 12:49 am
/system check-disk
mozerd
Fri Feb 16, 2018 5:28 am
/system check-disk
does not produce the desired result
it returns: bad command name check-disk (line 1 column 9)
donsergio
Fri Feb 16, 2018 3:57 pm
Hi, have you tried to upgrade to last ROS?
I tried and working
Regards!!
mozerd
Fri Feb 16, 2018 7:35 pm
I tried and working
Hi .... very interesting becasue it dos not work for me. Following is PIC
As you can see I have the latest ROS and when using TAB completion it does not show check-disk as an available command
Can you post a pic of your terminal with the same command so that I can compare please? Thanks.
mozerd
Sat Feb 17, 2018 2:47 pm
Here is what I have found out:
WinBox application interfaces and command structure used in Terminal adapts to the RouterBoard model in use.
So for example in the CCR Router series each model based on its capabilities and "sensors" built-in presents information specific to that board. The very same applies to all the other RouterBoards.
So WinBox and its associated apps like Terminal etc provide interface information "specific" to the Routboard having FOCUS.
That is why stuff that some of your see and execute may be and is subtly different than what others see and execute.
Sure makes Winbox a very impressive tool IMO !
Users browsing this forum: Google [Bot] and 72 guests
