Raf
Winbox OUI identify
Fri Feb 16, 2018 9:25 am
What do you guys think of adding new feature in Winbox which would check first six signs of a MAC address and display which company is bound to this MAC? I'd would see this as new column in DHCP Server for example. This would be great timesaver! Builtin OUI search within Winbox.
MAC address database is available from here http://standards.ieee.org/develop/regauth/oui/oui.txt
I've asked MT support and the response was "we may consider it if more people would be interested".
Rafał Wójcik from AWB-NET
High Definition enthusiast
LucZWFM
Re: Winbox OUI identify
Fri Feb 16, 2018 10:54 am
I would like this function... and in webfig too
Volunteer Techie @ZuidWest FM / ZuidWest TV, Stichting Repeater Bergen op Zoom & WRLP CB Repeater
lukaswit
Fri Feb 16, 2018 12:19 pm
Very helpful feautre
wojtekc
Fri Feb 16, 2018 12:26 pm
Hi. +1
pietroscherer
Trainer
Trainer
Fri Feb 16, 2018 12:49 pm
Interesting. +1
Pietro Scherer
http://www.tchesolutions.com.br [ISPs Consulting and Training]
http://www.routermage.com [Backup and Automation System]
:D
JB172
Fri Feb 16, 2018 12:51 pm
+1 This will be helpful.
normis
Fri Feb 16, 2018 12:54 pm
That file is almost 4 Megabytes. Many RouterOS devices have 16MB total storage size.
ryz
Fri Feb 16, 2018 1:18 pm
I like it. Hey support? Can you make it possible?
Wysłane z mojego SM-G800F przy użyciu Tapatalka
Sob
Fri Feb 16, 2018 2:03 pm
Funny you should say that, we keep telling you that 16MB is not much. :)
But this file is unnecessarily large, e.g. http://anonsvn.wireshark.org/wireshark/trunk/manuf is much smaller, and you could compress it even further. Plus it wouldn't have to be at router, WinBox could use local copy.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Raf
Fri Feb 16, 2018 2:18 pm
C'mon Normis. Use local storage. Let Winbox download this file locally into computer. :) Make some GUI to update this file and that's all. :)
LucZWFM
Sun Feb 18, 2018 6:16 pm
Does the file need to be on the router? I know dd-wrt have this feature to see a vendor behind a MAC...
I guess they check it somewhere online... ??
Cha0s
Forum Veteran
Forum Veteran
Sun Feb 18, 2018 6:35 pm
I was just about to say the exact same thing.
16MB flash is simply a joke in year 2018. It's one of those satisfying moments of 'I told you so' :P
+1 for the OUI feature in Winbox. It most likely won't happen due to the arbitrary decision to use 16MB flash on almost all boards since the last 2 years, but one can always hope :)
IIRC The Dude already supports that (at least v4.0b3).
Raf
Mon Feb 19, 2018 8:46 am
I don't think so. Winbox could use local storage for that.
tangram
Mon Feb 19, 2018 5:28 pm
+1.
mrz
Mon Feb 19, 2018 5:44 pm
Compressed would be around 450KB, but then this feature need to be added everywhere (terminal, webfig etc.). Not just winbox, because not everyone is using winbox all the time.
Sob
Mon Feb 19, 2018 7:43 pm
I'm not against some WinBox-exclusive features, but it's true that when WebFig aims to be almost WinBox, it would be nice to have it there too. And for CLI too.
Anyway, even 450kB would fit already, but it's stil a lot, relatively speaking. One way to cut it down would be to include only short names, which would make it look less pretty, but still useful. That could bring the compressed size under 200kB. Some people may still see it as wasted space, but if it wasn't part of system package (could be in advanced-tools, i.e. optional), it would be probably fine. Also the format used for MAC addresses storage could be changed, using string "xx:xx:xx" to represent three bytes is wasting space (but it makes only small difference after compression).
noyo
Mon Feb 19, 2018 9:16 pm
++++1 :)
Raf
Tue Feb 20, 2018 8:27 am
First we could have it in Winbox. WebFig and CLI can come later. And I really don't think that CLI is most important here. Sure, system should have feature consistency/unification, but hey I would not mind if it was Winbox exclusive feature for some time.
So MT devs… Yay or nay?
blingblouw
Tue Feb 20, 2018 9:30 am
I would rather have it as an extra available column than re-writting the mac address.
Raf
Tue Feb 20, 2018 10:13 am
@blingblouw: Erm… I proposed it as additional column. :)
blingblouw
Tue Feb 20, 2018 11:36 am
:? woops. Well, then +1
zeinettelecom
Tue Jun 26, 2018 7:42 am
Very very very useful these buttons to bring up openned windows. Nice!
indjov
Tue Jun 26, 2018 8:24 am
Sorry, but how you do that ?
indjov
Tue Jun 26, 2018 8:26 am
jarda
Tue Jun 26, 2018 8:39 am
In paint by copy paste, it seems. Nice idea but he rather should upgrade ros and delete the admin user. It's much more important than redrawing buttons from the right side to the top.
Raf
Wed Aug 08, 2018 11:41 am
Any news on this feature MT devs? :)
shed
Useful Tools...
Wed Aug 08, 2018 4:00 pm
Raf
Wed Aug 08, 2018 4:17 pm
Huh?
cusco
Wed Aug 08, 2018 5:22 pm
Hello Normis. But if this functionality was for Winbox only, that would not be a problem, right?
I found it attractive
alidamji
Mon Sep 10, 2018 11:25 pm
+1!
snsreal
Wed May 29, 2019 3:28 pm
The Dude do this already, why we cant have it in winbox?
No need to implement it in console, there is no point in that, only winbox and webfig
Users browsing this forum: altermeinhausbrennt, CZFan, ivn, mada3k, mkx and 115 guests
