MUM Europe 2020
gunther01
Why doesn't watchdog turn off
Mon Feb 26, 2018 7:07 pm
Do you think MT could make the watchdog turn off when I uncheck it and apply that change.
It's sickening that something SO SIMPLE does not work properly when you turn it off.
I should not have to change the IP address to something else for it to turn off. Otherwise remove the stupid check box that lets you think you can turn it off.
EIKA
Re: Why doesn't watchdog turn off
Mon Mar 05, 2018 6:16 pm
Same here! ROS 6.41, unticked Timer, but watchdog is still active (per logs) and do router restarts!
ROS developers, WTF?
haik01
Mon Mar 05, 2018 7:01 pm
I assume you used Winbox. What happens if you do it from command line?
gunther01
Mon Mar 05, 2018 7:06 pm
I use Winbox. Don't care what happens in CLI.
EIKA
Mon Mar 05, 2018 7:25 pm
If WinBox interface preperly sees checkbox position (and it's sees!), CLI Watchdog status must be Ok.
Users browsing this forum: No registered users and 43 guests
