My entire wireless network is composed or RouterOS, and I understand your concern about bridging.
When I started I was using a simple WDS solution with PPPoE. However I was not satisfied with the performcance of the wireless when working with WDS and bridges. I very soon reworked the entire network to be routed only, no bridges, no WDS. As I appreciate all the benefits of using PPPoE style tunnel connections and could no longer use them across the routed netowork I started to use PPTP for client connections. I have been operating this way for some time and have had very few issues.
Using this method I can concentrate all users to logging into my main server (you can still use RADIUS is desired), it also means that the 'work' the APs do is maintaining connections and passing data. All advanced routing, queues, etc., is also completed either at the CPE and/or the server.
how do you use network without WDS ?
You use eoip ?
You use Nat ?
example
MT - router with PPPOE - i can change it to PPTP or L2TP
------ wlan WDS ------
MT - WDS and after it are 4 other MT based AP connectet do it with wds.
without wds even routed network will not work , i think maybe i'm wrong ?
theanks for answer
