m4rk
Error: maximum connection count reached
Wed Mar 07, 2018 12:07 pm
I'm using a Mikrotik RB751U-2HnD with an old firmware 2.38 (i can't update it) and I found a problem during the execution of this command (on Terminal):
:tool fetch mode=ftp address="IP" src-path="/cloud/version.txt" dst-path="/currversion.txt" user="username" password="passwordftp"
It give me the following error:
failure: maximum connection count reached
I tried also with another Mikrotik same of the previous ones and give me the same error.
So after that I tried the same command with other Mikrotik RB951Ui-2HnD with a firmware 6.38 and works correctly.
Can you help me please?
Thanks,
With best regards,
Marco
CZFan
Re: Error: maximum connection count reached
Wed Mar 07, 2018 4:39 pm
What is reason you cant update?
MTCNA, MTCTCE, MTCRE & MTCINE
BRMateus2
Wed Mar 07, 2018 6:55 pm
That version has tons of vulnerabilities; update all.
m4rk
Wed Mar 07, 2018 6:57 pm
I have a lot of customers with old firmware and I can't force them to update it.
But i found the problem, there were different scripts blocked and, after killed all them, the command worked correctly.
So i think the problem is solved.
Thanks anyway for the reply.
With best regards,
Marco
Users browsing this forum: Bing [Bot], Google [Bot] and 95 guests
