I've been trying to set up a hEX router and I'm scratching my head. I come from a Cisco and Extreme background, so forgive my ignorance. I'd like to set up the ports on the device as "routed" ports, each being their own interface. Just to try and get things running, I came accross a forum post (viewtopic.php?t=118279) that lead me to apply a VLAN interface to the master port. Once I tagged the other side, I was at least able to ping. But I'm not fond of the idea of using trunk ports, and would rather each port act as its own routed interface.
What I would like to do is have ethernet3 assigned to its own untagged vlan with its own IP interface. I tried assigning a VLAN interface to ethernet3 (configured with "none" master), but that didn't work. Then I tried assigning the IP directly to the port, but that didn't work, either. I tried my best to mirror the configuration of ethernet2 (the default master), but couldn't get it to work outside of assigning the VLAN interface to the default master port.
I assume I'm just doing it wrong. I would appreciate any help I can get.
