MUM Europe 2020
gmac63
Where/Who di I go to for RouterBoard hardware issues?
Thu Jan 11, 2007 2:00 pm
Subject says it all. I'm having issues with the NICs dropping off (according to the Interface traffic graphs in winbox). This is not a good thing. Routerboard 532A model. Ether1 is a management port, ether2 and ether3 are bridged. I'm doing traffic control on 2 and 3.
Also the Routerboard seems to be giving me an issue with bad communication to an HP Procurve switch. "Excessive Jabber" is the error.
-Wes Yates
normis
Thu Jan 11, 2007 2:02 pm
always contact the seller of the item. they will look at the issue, and organize a replacement if necessary.
gmac63
Any other suggestions?
Thu Jan 11, 2007 3:11 pm
The reseller was WISP-Router Inc and I have not had a positive experience with them.
Are there any other users that seem to be having issues with the NICs/dropping packets? Are there any forums for hardware? What would be a good search term in the forums?
Thanks for the reply!
-Wes Yates
cmit
Thu Jan 11, 2007 3:36 pm
I don't have similar experiences, but there is a RouterBoard (hardware) forum at http://forum.routerboard.com/ - perhaps take a peek there?
Best regards,
Christian Meis
Best regards,
Christian Meis
normis
Thu Jan 11, 2007 3:42 pm
contact mikrotik support if the reseller is not available.
nickb
Thu Jan 11, 2007 9:45 pm
Good vendor, but not very good support. Every time I ask them a question the answer is "I don't know"... granted, I only call them to ask hard questions, because I can cover the easy ones on my own....
gmac63
Thanks all!
Fri Jan 12, 2007 12:33 am
Thank you all for the replies and the RouterOS is one scarry good product! I am into traffic marking/queueing and the knowledge I have gain just by using RouterOS is amazing. Talk about an quantum leap in using HTB.
-Wes Yates
Equis
Forum Veteran
Forum Veteran
Fri Jan 12, 2007 1:42 am
I would upgrade to 2.9.39 if you have not already.
It will only take a min and may fix your problem
gmac63
Fri Jan 12, 2007 1:51 pm
Equis,
I am at 2.9.35, so that is a good suggestion. I will try that.
On another note, anyone know the admin email of the routerboard forum? I'm having difficulty logging in / registering.
Thanks.
sergejs
Fri Jan 12, 2007 1:53 pm
Users browsing this forum: 0012nish, adam900331, dad2312, erlinden, eworm, IvanHC4, r00t and 123 guests
