sa4351ad
layer 7 protocols exception
Tue Mar 13, 2018 4:45 pm
Hi there , I have a comment for block video stream , but I want to make an exception for a PC by MAC address , how can I make it .
dadaniel
Re: layer 7 protocols exception
Tue Mar 13, 2018 5:10 pm
You can only do exceptions for IP address, see viewtopic.php?t=120819
Sob
Re: layer 7 protocols exception  [SOLVED]
Tue Mar 13, 2018 6:02 pm
That topic is about list of MAC addresses and RouterOS doesn't have that. But you can use src-mac-address option for one MAC address and it works (for directly connected devices of course).
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
sa4351ad
Tue Mar 13, 2018 6:10 pm
How ?
Sob
Tue Mar 13, 2018 6:48 pm
If you have:
add action=drop chain=forward layer7-protocol=streaming <other options>
Then:
a) If you need only one exception, change it to:
add action=drop chain=forward layer7-protocol=streaming <other options> src-mac-address=!<MAC address>
b) If you need more, add rules like this before the original one:
add action=accept chain=forward src-mac-address=<MAC address>
The latter might interfere with other firewall rules, if you have something more complex.
Users browsing this forum: No registered users and 90 guests
