ilja
IPSec Strongswan configuration fails
Thu Mar 15, 2018 8:56 am
Hey all.
I am trying to connect RouterOS to VPN server, but it keeps giving me error 'failed to get proposal for policy.
I have VPN server vpn.opt.example.co.rw which is set up and working. I have a bunch of Rapsberry Pi which are connected to that VPN server and works totally fine.
I know and can see all the working configurations between VPN server(run on linux machine) and any of connected Raspberry Pi's (linux machine), which are:
VPN(running strongSwan U5.4.0/K3.16.0-4-amd64):
cat ipsec.conf
# ipsec.conf - strongSwan IPsec configuration file
config setup
 charondebug="ike 1, knl 1, cfg 1"
conn %default
 ikelifetime=60m
 keylife=20m
 rekeymargin=3m
 keyingtries=1
 keyexchange=ikev2
 authby=secret
 dpdaction=clear
 dpddelay=10
conn mp_iap
 left=%defaultroute
 right=%any
 leftsubnet=10.0.0.0/8,172.30.0.0/16
 rightsourceip=10.10.0.0/16
 leftfirewall=yes
 auto=add
 dpdaction=clear
 dpddelay=20s
 forceencaps=yes
 compress=yes
conn iap-4-001
 rightsourceip=10.10.4.1
 rightid=iap-4-001@example.co.rw
 also=mp_iap
conn iap-4-107
 rightsourceip=10.10.4.107
 rightid=iap-4-107@example.co.rw
 also=mp_iap
 cat ipsec.secrets
 iap-4-001@example.co.rw : PSK WOOdexample
 iap-4-107@example.co.rw : PSK WOOdexample
From Raspberry Pi iap-4-001 (running strongSwan U5.3.3/K4.9.35-v7+):
cat ipsec.conf
# basic configuration files
conn %default
        ikelifetime=60m
        keylife=20m
        rekeymargin=3m
        keyingtries=%forever
        keyexchange=ikev2
        authby=secret
        dpdaction=restart
        dpddelay=10
conn office
        left=%defaultroute
        leftid=iap-4-001@example.co.rw
        leftfirewall=yes
        leftsourceip=%config
        right=vpn.ops.example.co.rw
        rightsubnet=10.0.0.0/8
        auto=add
cat ipsec.secrets
 : PSK WOOdexample
There two machine's connection works perfectly. But when I try to configure RouterOS like:
[admin@MikroTik-gitaraga-router] > /ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - invalid, A - active, * - default
 0 TX* group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
 1 T   group=M src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all proposal=MeshPower VPN
       template=yes
 2  XI  src-address=0.0.0.0/0 src-port=any dst-address=10.0.0.0/8 dst-port=any protocol=all
       action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=0.0.0.0
       sa-dst-address=46.101.50.333 proposal=MeshPower VPN ph2-count=0
[admin@MikroTik-gitaraga-router] > /ip ipsec policy group print
Flags: * - default
 #   NAME
 0 * default
 1   M
[admin@MikroTik-gitaraga-router] > /ip ipsec peer print
Flags: X - disabled, D - dynamic, R - responder
 0     address=vpn.ops.example.co.rw auth-method=pre-shared-key secret="WOOdexample"
       generate-policy=no policy-template-group=M exchange-mode=ike2 send-initial-contact=yes
       my-id=key-id:iap-4-107@example.co.rw hash-algorithm=sha1 enc-algorithm=3des
       dh-group=modp1536 lifetime=1d dpd-interval=2m
[admin@MikroTik-gitaraga-router] > /ip ipsec proposal print
Flags: X - disabled, * - default
 0 X* name="default" auth-algorithms=sha1 enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc
      lifetime=1m pfs-group=none
 1    name="MeshPower VPN" auth-algorithms=sha1 enc-algorithms=3des lifetime=1m pfs-group=modp1536
Checking RouterOS log file it shows me error:
"failed to get proposal for policy"
Please see full log here as pic here - https://ibb.co/fu1E4c
I was very hesitant about what encryption algorithms to choose when configuring routeros, but i have found some default values in strongswan docs - https://wiki.strongswan.org/projects/st ... onnSection
Can anyone please help me to setup strongswan on Routeros?
ilja
Re: IPSec Strongswan configuration fails
Thu Mar 15, 2018 2:55 pm
Any experts in IPSec?
ilja
Fri Mar 16, 2018 8:07 am
Anyone please? :?
ilja
Mon Mar 19, 2018 3:18 pm
Please?
ilja
Sat Mar 24, 2018 10:17 am
---abandoned due to inactivity---
emikrotik
Tue Mar 27, 2018 7:26 am
I had the same issue, I believe phase 2 doesn't rekey the SPI. I was not able to come up with a solution.
vilpalu
Tue Mar 27, 2018 10:18 am
i think you forget ipsec.conf to choose encryption methods:
ike=3des-sha1-modp1536!
esp=aes256-sha1
also authmode change to if you want use psk:
rightauth=psk
leftauth=psk
in mikrotik config i think you must determinate source addresses not 0.0.0.0/0 because router may tunnel tunnel's traffic.
dasiu
Trainer
Trainer
Tue Mar 27, 2018 2:09 pm
ilja,
1. On the policies list you can have actual "policies", and just "templates" - that are not working policies, just "bases" for dynamically creating policies, which match the other end's policies.
2. Your only "policy" (which is not a template) is disabled
3. Your IPSec peer has "generate-policy" set to "no".
You should either set "generate policy" to yes (port-strict usually) or enable/create the policy that will match exactly the policy configured on Strongswan.
Users browsing this forum: skatsman and 71 guests
