esquirrel
Thank you for the great Cable Test feature!
Thu Mar 22, 2018 2:56 pm
Its well worth it buying one of your routers just for that!
Add in the ability to mirror ports, making one a really good diagnostic tool...
jarda
Re: Thank you for the great Cable Test feature!
Fri Mar 23, 2018 10:27 pm
It is implemented in only few models unfortunately.
tippenring
Fri Mar 23, 2018 11:34 pm
I find the packet sniffer streaming works great. Not quite port mirroring, but close enough for what I need.
squeeze
Thu Mar 29, 2018 3:14 pm
Isn't port mirroring supported in almost all the switch chips?
Oh nevermind, you meant this about the cable test:
This works on SXT-G, SXT Lite, RB711G, RB2011, RB750 series and other devices with the same switch chips, and also the Cloud Core series devices.
jarda
Thu Mar 29, 2018 4:08 pm
Right. The cable test, as the topic title suggests.
esquirrel
Fri Mar 30, 2018 8:37 pm
I went to the PITA of rebuilding wireshark from source and I must be making some very dumb mistake as I still have not been able to get streaming to WS on my main machine to work for me. I need to devote some quality time to figuring it out.
Once I have that running, I agree, I likely wont need to mirror ports. It would be especially useful because currently all my ports are tied up.
[quote=tippenring post_id=650019 time=1521840876 user_id=74499]
[/quote]
Users browsing this forum: martinclaro, nascent, Shadowtm and 95 guests
