rfritz80
Port Forwarding for Security Camera's
Sat Apr 14, 2018 5:44 pm
Hello everyone and thanks for taking your time to review my submission.
I had to setup in the mikrotik firewall under NAT rule for a customers camera system they have installed at their premises. They have a DVR that they can login to view the live stream at all times. Currently I have the customers port forwarding established and they can view their camera systems remotely. However, normally if I wanted to use the Web browser to load up mikrotik GUI on the web, I would type in the IP address for the router that we have for its public gateway, when I do this it is now always directing me to the customers Camera Login Screen.
Typically it should be working were the customer should be entering the IP address that we inform them about and then a colon ( : ) Followed by their port forwarding number to gain accessing into their camera systems remotely.
The customer needs these port forwarding numbers all in TCP: Ports 80, 81, 8000, and 10554.
I go into my Mikrotik Router by Winbox, Click IP, Click Firewall, Click the tab NAT: and begin to add my NAT port forwarding rule.
We set the customer with a static IP address for his Remote Camera system with X.X.X.99 /24
So in the NAT Tab Menu, I click Add new rule, in General I select in Chain: dstnat, and Dst. Address ( Our IP address for the Mikrotik router), then the Protocol: tcp, then the Dst Port: 80, and I select on the In. Interface, on our WAN port.
Next I goto Actions Tab, Under Actions I select: dst-nat, and enter in the To Addresses: X.X.X.99 (customers static IP address we assigned to him for his camera system) and then I Select To Ports: 80,
I repeat this process for all the required ports the customer needs, so they can gain access to their security system through our router.
This is working, however they don’t have to enter the Port Forward number when typing in our Routers IP address, it just directly takes them their!
So for instances the customer is suppose to type X.X.X.72:80 and takes them to their Remote Camera System Login Screen.
However, its now doing this, If I just enter X.X.X.72 with no Port Forward number on the end, it will always take me to the customers Login Screen.
If anyone has any ideas or suggestions I could try to fix this it would be much appreciated.
squeeze
Re: Port Forwarding for Security Camera's
Sat Apr 14, 2018 8:51 pm
TCP port 80 is the default HTTP port. This is basic World Wide Web and TCP protocol knowledge.
In other words, all web browsers implicitly understand http://example.com as http://example.com:80.
If you actually need both of these services on this default (unsecured) web services port, then there is a conflict. This is usually resolved by one of the services being moved to a different port, e.g. remote router administration to a different port.
It can also be resolved by multi-homing with different IPs or by multi-hosting with different host names on the same IP, typically with a reverse proxy or more sophisticated web server in front of these services.
Alternatively, you could do none of the above and have a more secure setup, e.g. either a VPN for both services OR a remote and IP-filtered Winbox administration on one port with a TLS secured connection (with optional certificate auth) for the NVR/IP cam web login on the default HTTPS port (443). Even SSH tunneling would work and be more secure, similarly to the VPN solution, though it may not be as user friendly. Like the VPN solution, it has the advantage of being a single external port solution.
rfritz80
Mon Apr 16, 2018 11:20 pm
Hi Squeeze, and thanks for your reply, ya I understand that port 80 is the default for http (non secured sites), but that's what I was told by the customer from his DVR tech support guy! If you could provide a demonstration on how to set that up in mikrotik it would be awesome, I am very new with Mikrotik and been learning as much as I can. I would truly appreciate this.
BartoszP
Tue Apr 17, 2018 9:50 am
look here https://wiki.mikrotik.com/wiki/Manual:I ... nation_NAT
Ask DVR guy to change ports from 80 to eg. 40080 and follow above examples for port 40080.
You can also redirect external 40080 to port 80 on DVR to have DVR working.
Real admins use real keyboards.
rfritz80
Wed Apr 18, 2018 3:16 pm
Thanks Bartosz, the link you provided is just how I have it setup as, and when you mentioned talking to the DVR guy, I was thinking about doing too, I will have to give him a call and find if they can change that, I do appreciate your help and everyone's help in this matter, thank you all so much.
solar77
Long time Member
Long time Member
Wed Apr 18, 2018 7:25 pm
keep you current rule, forward port 80 to DVR
forward port 82 to Mikrotik port 80
or not to use web interface to manage Mikroitk, using winbox instead?
MTCNA MTCTCE UEWA
Users browsing this forum: vanderweide and 131 guests
