Wed Apr 18, 2018 9:17 am
[admin@MikroTik] > /interface wireless export verbose hide-sensitive
# jan/01/2002 01:02:58 by RouterOS 6.41.4
# software id = S0HE-VZNY
# model = Metal 2SHPn
# serial number = 727F068FC164
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
management-protection=disabled mode=none mschapv2-username="" name=default \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=\
XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none \
static-algo-1=none static-algo-2=none static-algo-3=none \
static-sta-private-algo=none static-transmit-key=key-0 supplicant-identity=\
MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=\
aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=no \
ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=0 \
area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=6Mbps \
basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-Ce \
compression=no country=no_country_set default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=yes \
disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic \
frame-lifetime=0 frequency=auto frequency-mode=manual-txpower \
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mcs-\
1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-1\
3,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 interworking-profile=disabled \
keepalive-frames=enabled l2mtu=1600 mac-address=6C:3B:6B:9C:8F:01 \
max-station-count=2007 mode=station mtu=1500 multicast-buffering=enabled \
multicast-helper=default name=wlan1 noise-floor-threshold=default \
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink \
nv2-noise-floor-offset=default nv2-qos=default nv2-queue-count=2 \
nv2-security=disabled nv2-sync-secret="" on-fail-retry-time=100ms \
preamble-mode=both radio-name=6C3B6B9C8F01 rate-selection=advanced \
rate-set=default rx-chains=0 scan-list=default secondary-channel="" \
security-profile=default ssid=MikroTik station-bridge-clone-mac=\
00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0 tx-power-mode=\
default update-stats-interval=disabled vlan-id=1 vlan-mode=no-tag \
wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
wds-ignore-ssid=no wds-mode=disabled wireless-protocol=any wmm-support=\
disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
[admin@MikroTik] >
