ariosvelez
Link debounce
Mon Apr 16, 2018 10:51 pm
I have a RB1072 and my main provider Level3 is asking me if I can do link debounce with Mikrotik. I have never work with that on Mikrotik I know that is Cisco. Does anyone has worked with this?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
MTCNA, MTCRE, MTCINE
sindy
Re: Link debounce
Tue Apr 17, 2018 11:13 am
Do you use any dynamic routing protocol on the uplink? I mean, link debounce is normally a setting used to filter out notification about short link failures to dynamic routing protocols so that they would not start to reconfigure the routing tables on very short outages, and to prevent the outages from being reported by monitoring systems. In both cases it is a measure of last resort if the link quality is poor and the link cannot be fixed in a reasonable time.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: ErickGonzalez, glat, kasievbneha and 92 guests
