MUM Europe 2020
robertpenz
CHR still communicates with 169.254.169.254
Thu Apr 19, 2018 11:02 am
I'm seeing on our firewalls that our test CHR is trying to connect to IP 169.254.169.254 with HTTP every few seconds (= over 250.000 connections attempts in 12h) . Google showed some old posts from 2015 where it was described as bug that will be fixed. As we're running 6.41.4, so it seems not.
I did following to not mess our firewall logs up:
/ip route add distance=1 dst-address=169.254.0.0/16 type=blackhole
pe1chl
Re: CHR still communicates with 169.254.169.254
Thu Apr 19, 2018 11:18 am
You should have that anyway. Same for the RFC1918 networks and RFC6598.
add distance=1 dst-address=10.0.0.0/8 type=unreachable
add distance=1 dst-address=100.64.0.0/10 type=unreachable
add distance=1 dst-address=169.254.0.0/16 type=unreachable
add distance=1 dst-address=172.16.0.0/12 type=unreachable
add distance=1 dst-address=192.168.0.0/16 type=unreachable
(or blackhole if you prefer)
sid5632
Thu Apr 19, 2018 11:24 am
If you add this:
/ip firewall filter add action=reject chain=output dst-address=169.254.169.254 protocol=tcp reject-with=tcp-reset
then it only tries once and gives up (according to the counters on the rule).
Blocking it in other ways means it's constantly trying.
normis
Thu Apr 19, 2018 11:26 am
Are you using CHR on AWS?
This address is used by the Amazon EC2 system, Amazon gives your device the configuration and SSH keys from this IP.
The fetch will only be repeated if there is no route to this address. Otherwise it will stop at the first failure.
robertpenz
Thu Apr 19, 2018 11:39 am
no, the CHR is on our own ESX in our datacenter.
robertpenz
Thu Apr 19, 2018 11:40 am
@sid5632: thx, changed it to your version
normis
Thu Apr 19, 2018 11:41 am
Starting from v6.42 CHR will detect that it's inside AWS EC2 and will not do these checks. Upgrade should fix it.
Joni
Thu Apr 19, 2018 11:44 am
Users browsing this forum: abjaterza, Google [Bot], MSN [Bot], techlord and 117 guests
