leosmendes
hardware offload for rb922 and hEX
Tue Apr 24, 2018 3:35 pm
Hello, good morning everyone. I would like to know if the chips of the rb's 922 and hEX support hardware offload, I see mention of hEX, but even enabling the option in the interface inside the bridge does not appear the H in the list of bridge interfaces. I'm using version 6.42.1 for firmware too
Sob
Re: hardware offload for rb922 and hEX
Tue Apr 24, 2018 6:16 pm
I don't know about these two exactly, but generally HW offload works only for some features. When you enable some extras not supported by HW, you're back to SW for whole thing.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
leosmendes
Tue Apr 24, 2018 9:03 pm
a simple bridge with no filter
squeeze
Thu Apr 26, 2018 4:39 am
I checked the default configuration of a hEX (gr3) today, after resetting it, and there's no indication of hw-offload being enabled with the default single bridge. I am not sure what to make of that.
Paternot
Long time Member
Long time Member
Thu Apr 26, 2018 5:36 am
Weird. With mine it's working. I'm with 6.42.1 - but I'm sure it worked too with 6.41
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ether1        bridge1        yes    1     0x80         10                 10       none
 1   H ether3        bridge1        yes    1     0x80         10                 10       none
 2   H ether4        bridge1        yes    1     0x80         10                 10       none
 3   H ether2        bridge1        yes    1     0x80         10                 10       none
And
/interface bridge port export
# apr/25/2018 23:32:06 by RouterOS 6.42.1
# software id = <software ID>
# model = RouterBOARD 750G r3
# serial number = <serial number>
nmt1900
Thu Apr 26, 2018 10:28 am
It might have something to do with IGMP snooping - if it's turned on (as it is by default on new bridges) then HW offload is deactivated. HW offload will be available after IGMP snooping is turned off on the bridge.
It looks like only CRS series devices can have both at the same time.
https://wiki.mikrotik.com/wiki/Manual:S ... Offloading
leosmendes
Thu Apr 26, 2018 5:05 pm
even after disabling igmp makes no difference, offload hardware continues disabled
krzysztof
Fri Apr 27, 2018 1:33 am
Please don't test IGMP snooping still doesn't work.
I am asking engineers from Mikrotik to test it on my TV network, but they don't want to.
So many years please Mikrotika to do IGMP snooping and nothing.
Why don't you listen to your customers?
krzysztof@pawluk.org
chechito
Fri Apr 27, 2018 1:51 am
in case of rb922
i think Hardware offload in bridges, works inly for physical Ethernet ports members of same switch chip (mikrotik wiki specifically touch this topic on switch chip features)
if you are bridging a wireless interface i think you are limited to fast path acceleration
if your bridge has only 2 ports you can try fast forward, "Special and faster case of Fast Path which works only on bridges with 2 interfaces", available since routeros 6.39 (cli only)
in the case of hEX (rb750gr3) mmips
What's new in 6.42.1 (2018-Apr-23 10:46):
*) bridge - fixed hardware offloading for MMIPS and PPC devices;
baragoon
Fri Apr 27, 2018 8:00 am
disable (r)stp and hw-offload will work
anav
Wed May 16, 2018 6:41 am
(HEX UNIT, latest firmware): I too noticed today that my HW offload is selected (checked off in the box) but comes as a big FAT NO in my configuration file.
Why would that be?
SOLVED: I had RTSP selected in the RTP tab for some strange reason. With the setting of NONE, my hw offload works!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
krzysztof
Fri Aug 31, 2018 1:19 am
Important announcement. IGMP snooping works ok!!
From the RuterOS version 6.43rc66, IGMP snooping works.
I don't know whether to be happy or congratulate, whether to cry, I waited for IGMP 10 years!
Many years of requests and reminders.
Thank you IPTV works.
Muqtada
Wed Oct 03, 2018 10:57 pm
rb922 has no switch chip hardware offload work on devices has switch chip for rb922 use fast-path or fast track depend on device configs .
hex RB750Gr3 has MT7621 switch chip if you want hardware offload work you have to disable
1-Bridge STP/RSTP
2-Bridge MSTP
3-Bridge IGMP Snooping
4-Bridge DHCP Snooping
5-Bridge VLAN Filtering
6-Bonding
make sure every thing above is disabled
Users browsing this forum: Google [Bot], mkx, MSN [Bot] and 83 guests
