49er
Dude server on RB-3011 CPU at 100%
Sun Apr 29, 2018 12:38 pm
When I enable the dude on a RB-3011 then both CPU's are runniing at 100%./
Is this normal?
I'm running RouterOS 6.42.1
chechito
Re: Dude server on RB-3011 CPU at 100%
Sun Apr 29, 2018 3:57 pm
are you using external USB storage for the dude database?
49er
Fri May 04, 2018 11:56 am
No, all on the RB3011
But I see If I uncheck DNS lookup that the cpu us going ot 0 or 1 %
chechito
Fri May 04, 2018 6:55 pm
is better to use a usb external storage for that
you wear out internal flash memory with all the intensive writes of monitoring database
p3rad0x
Long time Member
Long time Member
Mon May 07, 2018 1:32 pm
How many devices are you polling in the dude?
I had a RB750Gr3 doing about 20 devices and experienced the same issue.
Setting up CHR as a virtual machine sorted all the problems.
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
Users browsing this forum: No registered users and 82 guests
