AutoEmocion
RB2011UAS-2HnD-IN v6.4.1 VLAN Trunk with WLAN
Mon Apr 30, 2018 12:35 pm
I owned a RB2011LS (ether1 connects to internet, DHCP Servers) and RB2011UAS-2HD-IN, both with v6.4.1
I have successfully configure the SFP port to be a VLAN Trunk Port carrying Vlan 5,10,20,30,40.
I have problems trying to configure the wireless (interface=wlan) to join the VLAN, I have include. It just can't obtain IP Address from the RB2011LS
Attached is current configuration
Can anyone help?
Code: Select all
add name=bridge igmp-snooping=no protocol-mode=none
add bridge=bridge interface=sfp1 hw=yes
add bridge=bridge interface=ether1 hw=yes
add bridge=bridge interface=ether2 hw=yes
add bridge=bridge interface=ether3 hw=yes
add bridge=bridge interface=ether4 hw=yes
add bridge=bridge interface=ether5 hw=yes
add ports=sfp1,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=5
add ports=sfp1,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=10
add ports=sfp1,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=20
add ports=sfp1,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=30
add ports=sfp1,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=40
set spf1 vlan-mode=secure vlan-header=add-if-missing
set ether1 vlan-mode=secure vlan-header=always-strip default-vlan-id=10
set ether2 vlan-mode=secure vlan-header=always-strip default-vlan-id=20
set ether3 vlan-mode=secure vlan-header=always-strip default-vlan-id=30
set ether4 vlan-mode=secure vlan-header=always-strip default-vlan-id=40
set ether5 vlan-mode=secure vlan-header=always-strip default-vlan-id=5
CZFan
Re: RB2011UAS-2HnD-IN v6.4.1 VLAN Trunk with WLAN
Mon Apr 30, 2018 3:31 pm
In wireless (WLAN) config, specify VLAN Mode as "use tag" and specify the VLAN ID
MTCNA, MTCTCE, MTCRE & MTCINE
AutoEmocion
Mon Apr 30, 2018 3:51 pm
thanks for the prompt reply, I am still not getting a DHCP on the wlan from RB2011LS (works on my ether5 port).
Code: Select all
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=profile1 supplicant-identity="" \
wpa2-pre-shared-key=qwertyuiop
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n bridge-mode=disabled \
disabled=no mode=ap-bridge security-profile=profile1 ssid=\
MikroTik-Management vlan-id=5 vlan-mode=use-tag wps-mode=disabled
CZFan
Mon Apr 30, 2018 4:44 pm
I think you need to also add vlan 5 to interface wlan under interface vlan
AutoEmocion
Mon Apr 30, 2018 4:50 pm
thanks again,
Code: Select all
/interface vlan
add interface=wlan1 name=vlan5-wlan1 vlan-id=5
No Go,,,, not able to get IP....
Do i need to bridge it?
CZFan
Mon Apr 30, 2018 5:03 pm
Did you assign the DHCP server to WLAN or VLAN 5? If on WLAN, change to VLAN 5 and feedback
AutoEmocion
Mon Apr 30, 2018 5:14 pm
Hi.
Dhcp has no issues as I am able to request IP on ether5 of the rb2011uas.
The wlan1 just doesn't get the vlan.
Sent from my SM-N9005 using Tapatalk
sindy
Mon Apr 30, 2018 6:45 pm
You talk about trunk in the topic subject, and then you talk about adding a single VLAN. Is your intention to transport tagged packets over WiFi or you're fine with a dedicated SSID for each VLAN? Because wireless packets cannot accommodate the VLAN tag directly, you have to use an EoIP or VPLS tunnel to transport tagged L2 packets across wireless hops, or you have to use a single SSID per each VLAN so you cannot have the same wireless client in more than one VLAN (as a client won't associate to several SSIDs simultaneously).
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
chechito
Mon Apr 30, 2018 7:21 pm
i think a practical way to do this is:
you have to clear all the vlan configuration on switch menu leave it as default
create and manage all vlans on bridge configuration, dont forget to enable vlan filtering to make vlans on bridge work
sindy
Mon Apr 30, 2018 8:29 pm
I respectfully disagree here.
vlan-filtering
is exactly what it says - filtering. If it is set to
no
, all ports are members of all VLANs.
vlan-filtering=yes
allows you to control membership of ports in VLANs by means of the rules in
/interface bridge vlan
. If
vlan-filtering=no
, these rules are ignored and tagged packets are forwarded between any member ports of the bridge.
AutoEmocion
Tue May 01, 2018 2:49 am
Hi sindy
Thanks for the reply.
I have a trunk coming from spf1 rb2011LS to spf1 rb2011uas, carrying vlan 5 10 20 30 40.
As you can see from my config in post 1, ether 1 to 5 together with spf1 of rb2011uas are configured using switch chip, and all the 5 ether ports have no problems getting IPs from DHCP server at rb2011LS.
My intention is to configure a multi ssid on the rb2011uas with various vlans connecting to the trunk. But I am stuck with the 1st wireless interface.....
AutoEmocion
Tue May 01, 2018 2:51 am
Thank you.
I suspect that could be the only way to get both switch chips & wlan to work in a vlan environment.
AutoEmocion
Tue May 01, 2018 2:54 am
I have Google very hard and found this blog.
https://blog.ligos.net/2018-01-01/Mikro ... -VLAN.html
This could be the type config I am after. Put vlan on the bridge.
What do u guys think?
chechito
Tue May 01, 2018 3:23 am
vlan-filtering
no
vlan-filtering=yes
. If
vlan-filtering=no
Are you sure that without having that marked the vlan work?
taken from
https://wiki.mikrotik.com/wiki/Manual:I ... face_Setup
vlan-filtering (yes | no; Default: no) Globally enables or disables VLAN functionality for bridge.
chechito
Tue May 01, 2018 3:28 am
Thank you.
Today is the simplest way to do it
im sorry not being of more help, i have clear how to do use of switch chip vlan and bridge in integration with vlans in old bridge 6.40.x
i have not tested that config in new bridge implementation
AutoEmocion
Tue May 01, 2018 9:30 am
Thank you.
Thanks Chechito and Sindy,
I believed I have found the correct way of running vlan over bridges in 6.41.3
please have a look.
Code: Select all
# jan/02/2002 02:15:45 by RouterOS 6.41.3
# software id = ISEF-IIMI
# model = 2011UAS-2HnD
# serial number = 3F0702EC61D0
add fast-forward=no name=Sfp1-Vlan-Trunk
add fast-forward=no name="Vlan05 Bridge"
add fast-forward=no name="Vlan10 Bridge"
add fast-forward=no name="Vlan20 Bridge"
add fast-forward=no name="Vlan30 Bridge"
add fast-forward=no name="Vlan40 Bridge"
/interface vlan
add interface=Eth1-Vlan-Trunk name=Sfp1-Vlan05 vlan-id=5
add interface=Eth1-Vlan-Trunk name=Sfp1-Vlan10 vlan-id=10
add interface=Eth1-Vlan-Trunk name=Sfp1-Vlan20 vlan-id=20
add interface=Eth1-Vlan-Trunk name=Sfp1-Vlan30 vlan-id=30
add interface=Eth1-Vlan-Trunk name=Sfp1-Vlan40 vlan-id=40
allowed mode=dynamic-keys name=wlan1-profile supplicant-identity="" \
wpa2-pre-shared-key=12345678
allowed mode=dynamic-keys name=wlan2-profile supplicant-identity="" \
allowed mode=dynamic-keys name=wlan3-profile supplicant-identity="" \
allowed mode=dynamic-keys name=wlan4-profile supplicant-identity="" \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge \
name=wlan05 security-profile=wlan05-profile ssid=MikroTik-Management \
wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:6E:91:CF \
master-interface=wlan05 multicast-buffering=disabled name=wlan10 \
security-profile=wlan10-profile ssid=Smurfs wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:6E:91:D0 \
master-interface=wlan05 multicast-buffering=disabled name=wlan20 \
security-profile=wlan20-profile ssid=IOT wds-cost-range=0 \
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:6E:91:D1 \
master-interface=wlan05 multicast-buffering=disabled name=wlan30 \
security-profile=wlan30-profile ssid=Watching_You wds-cost-range=0 \
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:6E:91:D2 \
master-interface=wlan05 multicast-buffering=disabled name=wlan40 ssid=\
Guest wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add bridge=Sfp1-Vlan-Trunk interface=Sfp1
add bridge="Vlan05 Bridge" interface=ether1
add bridge="Vlan10 Bridge" interface=ether2
add bridge="Vlan20 Bridge" interface=ether3
add bridge="Vlan30 Bridge" interface=ether4
add bridge="Vlan40 Bridge" interface=ether5
add bridge="Vlan05 Bridge" interface=ether6
add bridge="Vlan10 Bridge" interface=ether7
add bridge="Vlan20 Bridge" interface=ether8
add bridge="Vlan30 Bridge" interface=ether9
add bridge="Vlan40 Bridge" interface=ether10
add bridge="Vlan05 Bridge" interface=Sfp1-Vlan05
add bridge="Vlan10 Bridge" interface=Sfp1-Vlan10
add bridge="Vlan20 Bridge" interface=Sfp1-Vlan20
add bridge="Vlan30 Bridge" interface=Sfp1-Vlan30
add bridge="Vlan40 Bridge" interface=Sfp1-Vlan40
add bridge="Vlan05 Bridge" interface=wlan05
add bridge="Vlan10 Bridge" interface=wlan10
add bridge="Vlan20 Bridge" interface=wlan20
add bridge="Vlan30 Bridge" interface=wlan30
add bridge="Vlan40 Bridge" interface=wlan40
sindy
Tue May 01, 2018 9:38 am
What I have missed in your first post (as I have concentrated on the "VLAN trunk over wireless" thought) is that you haven't permitted the vlans to the CPU port:
add ports=sfp1,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=x
should read
add ports=sfp1,ether1,ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=x
The point is that the wireless interface has no direct connection to the switch chip, so the packets must be bridged via the CPU.
Of course you can clear the switch configuration and do everything using bridging as @chechito suggests, but that would cost you quite some CPU power wasted on forwarding traffic between the Ethernet ports.
Users browsing this forum: No registered users and 81 guests
