fleg
Backup and restore between platforms
Wed May 02, 2018 6:51 am
I have a gw CRS226-24G-2S+ and now I`ve bought a new one CCR1009-7G-1C-1S+. I`d like to transfer all settings from old to new but I think it is not possible to use backp and restore between architectures.
I tried it in my home AP (RB941 vs RBD52G-5HacD2HnD-TC, hAP ac2, mipsbe vs arm) and I couln`t restore from backup file (wrong password).
Is there some easy way to move settings (dhcp, vpn, fw rules....etc) between 2 different routers?
jarda
Re: Backup and restore between platforms
Wed May 02, 2018 7:27 am
Have you seen the manual? Check it first.
Use export, make manual corrections and then import into new device. Don't forget to wipe the default config before the import.
chechito
Wed May 02, 2018 5:08 pm
dont use .backup file to restore on different machine
that generate unpredictable problems
.backup file is to use on the SAME machine
jarda
Wed May 02, 2018 5:14 pm
... and with the same Ros version.
Users browsing this forum: No registered users and 80 guests
