freemannnn
Long time Member
Long time Member
ccr1009 missing bad blocks and total sectors writes
Wed May 02, 2018 12:47 pm
why there is no info about bad block and total sectors writes in ccr1009?
i want to use internal flash 128mb for user manager but i dont know if it will wear quick by many read/writes.
freemannnn
Long time Member
Long time Member
Re: ccr1009 missing bad blocks and total sectors writes
Wed May 02, 2018 12:48 pm
this photo is from another rb951 router
chechito
Wed May 02, 2018 4:48 pm
i think is very usefull missing feature to track usage of finite write cycles of flash memory and know if you are heavily using it
freemannnn
Long time Member
Long time Member
Wed May 02, 2018 6:40 pm
i dont trust anymore external usb flash drivers for user manager. disk is missing from system/disks or changing name from disk1 to disk4 without reason. and nobody can login after that because user manager database cannot be found.
internal flash is small 128mb but user manager is working flawless until flash is full.. i dont know why but sqldb file is increasing every day even without adding any users. yesterday it was 266kb and today is 396kb.
i dont use logs. logsdb is always 6kb.
i wish i had bought rb1100ah4 dude edition with ssd for user manager but it was not released and not user manager suppot the date i bought ccr1009.
chechito
Thu May 03, 2018 12:22 am
i wish i had bought rb1100ah4 dude edition with ssd for user manager but it was not available at that date i bought ccr1009.
have you tried the micro sd card??
freemannnn
Long time Member
Long time Member
Thu May 03, 2018 8:22 am
i am using MikroTik CCR1009-7G-1C-PC so no sdcard in this model.
i got a reply from mikrotik support...
"CCR (tile architecture) devices does not provide such information."
i bought another usb flash drive TRANSCEND 32gb. i will give try one more time with user manager in usb flash drive and if happens the same i will post screenshots of the error message.
size of sqldb today is 446kb. there is something more written in this file. not only usernames and password.
this model is expensive and i dont want to wear the internal flash memory.
Muhammadilyasmunir
Radius Server
Thu May 03, 2018 8:56 am
Hello Friends
Hope so you are doing well.
Kindly help me. i have a Mikrotik 750GL router with Os version is 5.20,
facing the issue when i create a PPPOE Radius server, every thing working smoothly, but few hour after automatically crash the Radius server and all the data remove ( Radius server profile, users, and user profile ).
How to solve this problem.
Last edited by Muhammadilyasmunir on Fri May 04, 2018 12:19 pm, edited 1 time in total.
docmarius
Thu May 03, 2018 6:33 pm
@Muhammadilyasmunir: Don't you think you should open another topic because your problem is not related to the one discussed here?
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
freemannnn
Long time Member
Long time Member
Thu May 03, 2018 9:39 pm
i transfer user manager this morning to usb transcend 32gb "disk4". lets see how long it will last without changing name i hope forever!
sqldb increasing day by day without adding new users.
freemannnn
Long time Member
Long time Member
Wed May 09, 2018 1:06 am
the problem of changing the names of the usb flash drive is the usb port is so sensitive to the touch.
the usb plug on ccr is so soft that it moves so easily and after that disk drive is lost.
Users browsing this forum: MSN [Bot] and 89 guests
