Atentaduh
Switch with low performance!
Sat May 05, 2018 5:37 pm
Hi!
I bought a CSS326-24G-2S + RM and it was just a bad joke! i couldnt barely push over 100Mbps on the switch! and some freezes from time to time
Then i bought a CRS326-24G-2S+RM
this one wont freezes at least!
but the performance is bad!
Heres what happens...
On both cases the switch was connected to a RB1100Dx4 (which is running just fine) at 1Gbps link speed
several devices at 100Mbps (at least 15) connected to the switch. if i run a speed test from internet i cant push over 50Mbps!
If i use any other CHEAP switch on the same setup and port it works just perfect ! and i can push to almost 100mbps (limited by the eth max speed)
But with the mikrotik switches i cant get a stable throughput !
Then i tought can it be the config ?
So i just made a bridge with hardware off-load (aka master port) without vlans! just like a regular switch
same results
tried with vlans.. same results
now im running bonding 2 ethernet + vlans
and i got slightly better troughput
(YES Bonding does support hw-offload with xor or 802.11ad on crs326)
Heres my Question
I got tons of RX-Overruns on the switch trunk port
RX-Overruns happens when the device is slower than the other device right ?
on this case...
RB1100Dx4====>CRS326===>MkDevice
I got 0 Overruns on the 1100
i got tons Overruns on the CRS (on both interfaces (eth1 and eth2 which is the bonding slaves)
i got 0 Overruns on The other MK-Devices..
so the crs is the slow one right ?
Just to be clear... if i connect the the same mk-device direct to the rb1100 works flawless
How can i solve this ?
I already tried with fixed link speed and auto-negotiation
Flow control on and off
PS: eth2 has less overruns because it was added later with bonding
Atentaduh
Re: Switch with low performance!
Sat May 05, 2018 9:26 pm
This what happens when i run some btest from the devices to the rb1100 through the switch MT Devices ===>CRS326====>RB1100Dx4 (upload)
Works nicely!! 8 devices could reach almost 800Mbps, but the other way around just sucks RB1100Dx4====>CRS326====>MT Devices (Download)
I cant reach the same amount of traffic on the devices.. starts to drop packets some devices reach 98Mbps for a short period some just reach 7Mbps. its just driving me crazy.
cdemers
Sun May 06, 2018 3:33 am
I use the same switch, you can't be configuring it correctly. I get wire speed switching. Post a export of your configuration.
Sent from my SM-A520W using Tapatalk
Atentaduh
Sun May 06, 2018 6:27 pm
Thanks for you reply
Heres the config.
add name=bridge-vlans priority=0x20 vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-trunk rx-flow-control=on tx-flow-control=on
set [ find default-name=ether2 ] name=ether2-trunk rx-flow-control=on tx-flow-control=on
set [ find default-name=ether3 ] name=ether3-mrb-hades rx-flow-control=on tx-flow-control=on
set [ find default-name=ether4 ] loop-protect=off name=ether4-jayme rx-flow-control=on tx-flow-control=on
set [ find default-name=ether5 ] name=ether5-mrb-aegon rx-flow-control=on tx-flow-control=on
set [ find default-name=ether6 ] name=ether6-mrb-skadi rx-flow-control=on tx-flow-control=on
set [ find default-name=ether7 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether8 ] name=ether8-mrb-arya rx-flow-control=on tx-flow-control=on
set [ find default-name=ether9 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether10 ] advertise=10M-full,100M-full name=ether10-mrb-tyrion rx-flow-control=on tx-flow-control=on
set [ find default-name=ether11 ] advertise=10M-full,100M-full name=ether11-ptp-loja rx-flow-control=on tx-flow-control=on
set [ find default-name=ether12 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether13 ] name=ether13-saveiros rx-flow-control=on tx-flow-control=on
set [ find default-name=ether14 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether15 ] name=ether15-mrb-pegasus rx-flow-control=on tx-flow-control=on
set [ find default-name=ether16 ] name=ether16-mrb-daenerys rx-flow-control=on tx-flow-control=on
set [ find default-name=ether17 ] name=ether17-mrb-heimdall rx-flow-control=on tx-flow-control=on
set [ find default-name=ether18 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether19 ] name=ether19-mrb-zeus rx-flow-control=on tx-flow-control=on
set [ find default-name=ether20 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether21 ] name=ether21-mrb-poseidon rx-flow-control=on tx-flow-control=on
set [ find default-name=ether22 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether23 ] name=ether23-mrb-diana rx-flow-control=on tx-flow-control=on
set [ find default-name=ether24 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus1 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus2 ] rx-flow-control=on tx-flow-control=on
/interface vlan
add interface=bridge-vlans name=vlan2403-mrb-hades vlan-id=2403
add interface=bridge-vlans name=vlan2404 vlan-id=2404
add interface=bridge-vlans name=vlan2405-mrb-aegon vlan-id=2405
add interface=bridge-vlans name=vlan2406 vlan-id=2406
add interface=bridge-vlans name=vlan2407 vlan-id=2407
add interface=bridge-vlans name=vlan2408 vlan-id=2408
add interface=bridge-vlans name=vlan2409 vlan-id=2409
add interface=bridge-vlans name=vlan2411-ptp-loja vlan-id=2411
add interface=bridge-vlans name=vlan2412 vlan-id=2412
add interface=bridge-vlans name=vlan2413-saveiros vlan-id=2413
add interface=bridge-vlans name=vlan2415-mrb-pegasus vlan-id=2415
add interface=bridge-vlans name=vlan2416 vlan-id=2416
add interface=bridge-vlans name=vlan2417-mrb-heimdall vlan-id=2417
add interface=bridge-vlans name=vlan2419-mrb-zeus vlan-id=2419
add interface=bridge-vlans name=vlan2421-mrb-poseidon vlan-id=2421
add interface=bridge-vlans name=vlan2423-mrb-diana vlan-id=2423
/interface bonding
add mode=balance-xor name=bonding1 slaves=ether2-trunk,ether1-trunk transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=bonding1 name=vlan500-mngt vlan-id=500
add bridge=bridge-vlans interface=ether23-mrb-diana pvid=2423
add bridge=bridge-vlans interface=ether19-mrb-zeus pvid=2419
add bridge=bridge-vlans interface=ether17-mrb-heimdall pvid=2417
add bridge=bridge-vlans interface=ether15-mrb-pegasus pvid=2415
add bridge=bridge-vlans interface=ether13-saveiros pvid=2413
add bridge=bridge-vlans interface=ether21-mrb-poseidon pvid=2421
add bridge=bridge-vlans interface=ether3-mrb-hades pvid=2403
add bridge=bridge-vlans interface=ether5-mrb-aegon pvid=2405
add bridge=bridge-vlans interface=ether11-ptp-loja pvid=2411
add bridge=bridge-vlans interface=ether4-jayme pvid=2404
add bridge=bridge-vlans interface=ether6-mrb-skadi pvid=2406
add bridge=bridge-vlans interface=ether7 pvid=2407
add bridge=bridge-vlans interface=ether8-mrb-arya pvid=2408
add bridge=bridge-vlans interface=ether9 pvid=2409
add bridge=bridge-vlans interface=ether10-mrb-tyrion pvid=2410
add bridge=bridge-vlans interface=ether12 pvid=2412
add bridge=bridge-vlans interface=ether14
add bridge=bridge-vlans interface=ether16-mrb-daenerys pvid=2416
add bridge=bridge-vlans interface=bonding1
/interface bridge vlan
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether3-mrb-hades vlan-ids=2403
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether5-mrb-aegon vlan-ids=2405
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether11-ptp-loja vlan-ids=2411
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether13-saveiros vlan-ids=2413
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether15-mrb-pegasus vlan-ids=2415
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether17-mrb-heimdall vlan-ids=2417
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether19-mrb-zeus vlan-ids=2419
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether21-mrb-poseidon vlan-ids=2421
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether23-mrb-diana vlan-ids=2423
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether12 vlan-ids=2412
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether10-mrb-tyrion vlan-ids=2410
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether9 vlan-ids=2409
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether8-mrb-arya vlan-ids=2408
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether7 vlan-ids=2407
add bridge=bridge-vlans tagged=bridge-vlans,bonding1 untagged=ether6-mrb-skadi vlan-ids=2406
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether4-jayme vlan-ids=2404
add bridge=bridge-vlans tagged=bonding1,bridge-vlans untagged=ether16-mrb-daenerys vlan-ids=2416
sindy
Sun May 06, 2018 8:02 pm
The first thing I would suspect is the flow control. As it is used rarely, it may have got silently broken. And when it works properly, it has the bad habit of pushing peripheral problems to the core - a slow destination cannot handle incoming packets so it says "stop sending", and thus the frames accumulate at the previous device until its buffers overflow and it has to start dropping them anyway. But instead of dropping packets of the slow peripheral device on itself, the core equipment drops any packets on the interface facing that peripheral device, affecting unrelated flows.
Second point, do you really have an IP interface in each of your million and six VLANs? Not that the load of the CPU coming from processing all the ARP requests in all the VLANs should affect switch chip performance, but I'd keep only those /interface vlan which are really necessary.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Atentaduh
Sun May 06, 2018 9:38 pm
Thanks for your reply!
The flow control was enabled later for test purpose! still i got the same results with on/off
each vlan has a pppoe-server for my customers, and ip address only to manage the ap devices
but like i said before, the first thing i tried was without vlans, just like a regular switch.
I'm considering to replace the RB1100Dx4 for a CCR1009 to see what happens...
Atentaduh
Thu May 10, 2018 12:13 am
I'm having trouble with HW-Offload ! when i set it to on i got a lot a overruns on the trunk interface and low throughput!
when i set to off i got no overruns and the throughput is way better! but the cpu load is way higher!
can u guys tell me why ?
Its supposed to be the other way around right ?
Wire speed with hw-offload
samsung172
Thu May 10, 2018 12:19 am
sindy
Thu May 10, 2018 12:31 am
Well, if linking to manuals, this link is more appropriate.
I don't like the /interface vlan name=vlan500-mngt to be attached directly to interface=bond1 directly while all other /interface vlan are attached to the /interface bridge name=bridge-vlan which has bond1 as one of its slave interfaces, but I'm not sure how it is eventually related to the low throughput in hw-offload mode which really should be higher than a software bridged mode.
Atentaduh
Thu May 10, 2018 3:49 am
I Apreciate your reply guys.
i'm not even running bonding interface anymore... just a single interface... eth1 as trunk interface.. and the mngt-vlan is now on the bridge as well
i've already read all those manuals and articles about the CRS! thanks tho
hw-offload gave me worst performance! i know ... doesnt make sense!
sindy
Thu May 10, 2018 3:26 pm
I would start from the default configuration in steps. Create a single bridge with hw-offload, vlan-filtering=no, insert the machine "into" an already existing trunk connection. If it works fine, configure vlan filtering rules permitting all vlans actually used on that trunk and activate vlan-filtering. If it still works fine, add another port as an access one to one of the used VLANs, and see whether the flow between that access port and one of the trunk ports tested previously is still OK, etc.
Atentaduh
Thu May 10, 2018 10:47 pm
Hi there!
thats was the first thing i did, step by step
My laptop on the routerboard was flawless, then the switch on the same port... i coudnt get the same throughput (the first setup the switch was just a bridge with hw-offloading)
But like i said before, with hw-offload i could get almost 800Mbps in one direction, but not the other way around.. and most important for me (download speed).
the next step im gonna try with swos then default routeros version.
for now its working... not like i expected... but its working.
sindy
Thu May 10, 2018 10:56 pm
Well, if you say that it throttles "one direction", what happened when you swapped the roles of the ports? Was it always throttling port A -> port B or always the other RouterBoard -> the PC regardless whether port A was connected to the PC or to the other RouterBoard?
samsung172
Fri May 11, 2018 1:22 am
if you using bonding interface - bonding is the same as a physical ethernet. So a vlan to bonding1 is the same as a vlan to ether1.. if not bonding
Ther is a big different in having vlan to the interface - and to the bridge. If having the vlan to a interface - the interface would tag tjis out to only this port. If tagged to a bridge - all ports in the bridge will have the vlan tagged. And last -but not least- if put in bridge -it goes untagged into this bridge.
Nowdays its no more software bridge like earlier. traffic do not goes trough connection tracking like in old times. but depends on setup,.
Atentaduh
Sun May 13, 2018 3:35 pm
Hey sindy,
Doesnt matter the port i use as trunk, the same thing happen.
chechito
Fri Nov 09, 2018 12:06 am
I confirm this issue
happened to me on
CRS 326
CRS 328 24P
tested on routeros 6.43.4
very frustrating, disappointing and problematic, you buy a mikrotik switch to improve performance and you get to opposite result
Raumaster
Thu Dec 13, 2018 10:42 pm
I solved my CRS 326 RX Overflow problem switching the uplink port that was on an ethernet port to an SFP port. It seems the SFP port can handle all the traffic better then one ethernet port receiveing and transmiting data from and to other ethernet ports.
chechito
Thu Dec 13, 2018 11:07 pm
thank you for sharing your experience i will get a SFP cable to try
sindy
Thu Dec 13, 2018 11:19 pm
If this helps, it sounds to me as if the connection on the copper-only port negotiated a half duplex operation mode, as otherwise there is no sane reason why an SFP should perform different from a copper-only port. Have you used an optical SFP or a copper one?
chechito
Fri Dec 14, 2018 1:47 am
on CRS 326 SFP ports are 10g maybe that's the reason why using SFP helps
i have replicated the same issue in multiple customers, issue present on CRS 326 and CRS 328 when i can get SFP i will try
i think this can be the case of "Head-of-line blocking" issue, of course i dont have proof of that, i am a customer, i dont have a LAB to try and prove that
drros
Fri Feb 01, 2019 2:24 pm
Having the same problem, tried both RouterOS (6.43.8) and SwOS (2.9) about the same results. Tried with flow control both on and off.
root@freenas[~]# iperf3 -c 192.168.0.40 -t 20
Connecting to host 192.168.0.40, port 5201
[  5] local 192.168.0.3 port 16623 connected to 192.168.0.40 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   112 MBytes   936 Mbits/sec    0    567 KBytes
[  5]   1.00-2.00   sec   113 MBytes   945 Mbits/sec    0    807 KBytes
[  5]   2.00-3.00   sec   112 MBytes   941 Mbits/sec    0    989 KBytes
[  5]   3.00-4.00   sec   112 MBytes   941 Mbits/sec    0   1.12 MBytes
[  5]   4.00-5.00   sec   112 MBytes   942 Mbits/sec    0   1.25 MBytes
[  5]   5.00-6.00   sec   112 MBytes   941 Mbits/sec    0   1.33 MBytes
[  5]   6.00-7.00   sec  47.6 MBytes   400 Mbits/sec  1487    342 KBytes
[  5]   7.00-8.00   sec   112 MBytes   941 Mbits/sec    0    667 KBytes
[  5]   8.00-9.00   sec   112 MBytes   942 Mbits/sec    0    878 KBytes
[  5]   9.00-10.00  sec  72.8 MBytes   611 Mbits/sec  900    402 KBytes
[  5]  10.00-11.00  sec   112 MBytes   941 Mbits/sec    0    699 KBytes
[  5]  11.00-12.00  sec   112 MBytes   941 Mbits/sec    0    904 KBytes
[  5]  12.00-13.00  sec   112 MBytes   941 Mbits/sec    0   1.04 MBytes
[  5]  13.00-14.00  sec   112 MBytes   942 Mbits/sec    0   1.18 MBytes
[  5]  14.00-15.00  sec   112 MBytes   942 Mbits/sec    0   1.31 MBytes
[  5]  15.00-16.00  sec  95.7 MBytes   802 Mbits/sec    1   2.85 KBytes
[  5]  16.00-17.00  sec  67.2 MBytes   564 Mbits/sec  1501    443 KBytes
[  5]  17.00-18.00  sec   112 MBytes   941 Mbits/sec    0    724 KBytes
[  5]  18.00-19.00  sec   112 MBytes   942 Mbits/sec    0    922 KBytes
[  5]  19.00-20.00  sec   112 MBytes   942 Mbits/sec    0   1.06 MBytes
[  5]   0.00-20.00  sec  2.03 GBytes   872 Mbits/sec  3889             sender
[  5]   0.00-20.01  sec  2.03 GBytes   871 Mbits/sec                  receiver
iperf Done.
root@freenas[~]# iperf3 -c 192.168.0.40 -t 20 -R
Reverse mode, remote host 192.168.0.40 is sending
[  5] local 192.168.0.3 port 55173 connected to 192.168.0.40 port 5201
[  5]   0.00-1.00   sec  75.5 MBytes   633 Mbits/sec
[  5]   1.00-2.00   sec   112 MBytes   942 Mbits/sec
[  5]   3.00-4.00   sec   112 MBytes   942 Mbits/sec
[  5]   4.00-5.00   sec   112 MBytes   941 Mbits/sec
[  5]   6.00-7.00   sec  40.3 MBytes   338 Mbits/sec
[  5]   7.00-8.00   sec  99.7 MBytes   837 Mbits/sec
[  5]   8.00-9.00   sec   110 MBytes   927 Mbits/sec
[  5]   9.00-10.00  sec   112 MBytes   941 Mbits/sec
[  5]  10.00-11.00  sec   108 MBytes   905 Mbits/sec
[  5]  13.00-14.00  sec   112 MBytes   941 Mbits/sec
[  5]  14.00-15.00  sec  79.1 MBytes   664 Mbits/sec
[  5]  15.00-16.00  sec  75.3 MBytes   631 Mbits/sec
[  5]  16.00-17.00  sec  98.6 MBytes   827 Mbits/sec
[  5]  18.00-19.00  sec  89.3 MBytes   749 Mbits/sec
[  5]  19.00-20.00  sec   105 MBytes   885 Mbits/sec
[  5]   0.00-20.00  sec  1.96 GBytes   841 Mbits/sec  1905             sender
[  5]   0.00-20.00  sec  1.96 GBytes   840 Mbits/sec                  receiver
iperf Done.
And this is the result of using Asus RN-N66 as a switch
[  5] local 192.168.0.3 port 19825 connected to 192.168.0.40 port 5201
[  5]   0.00-1.00   sec   112 MBytes   940 Mbits/sec    0    569 KBytes
[  5]   2.00-3.00   sec   112 MBytes   942 Mbits/sec    0    989 KBytes
[  5]   5.00-6.00   sec   112 MBytes   942 Mbits/sec    0   1.33 MBytes
[  5]   6.00-7.00   sec   112 MBytes   941 Mbits/sec    0   1.33 MBytes
[  5]   7.00-8.00   sec   112 MBytes   942 Mbits/sec    0   1.34 MBytes
[  5]   8.00-9.00   sec   112 MBytes   942 Mbits/sec    0   1.35 MBytes
[  5]   9.00-10.00  sec   112 MBytes   941 Mbits/sec    0   1.35 MBytes
[  5]  10.00-11.00  sec   112 MBytes   941 Mbits/sec    0   1.36 MBytes
[  5]  11.00-12.00  sec   112 MBytes   942 Mbits/sec    0   1.36 MBytes
[  5]  12.00-13.00  sec   112 MBytes   941 Mbits/sec    0   1.36 MBytes
[  5]  13.00-14.00  sec   112 MBytes   942 Mbits/sec    0   1.36 MBytes
[  5]  14.00-15.00  sec   112 MBytes   941 Mbits/sec    0   1.36 MBytes
[  5]  15.00-16.00  sec   112 MBytes   942 Mbits/sec    0   1.36 MBytes
[  5]  16.00-17.00  sec   112 MBytes   941 Mbits/sec    0   1.36 MBytes
[  5]  17.00-18.00  sec   112 MBytes   942 Mbits/sec    0   1.36 MBytes
[  5]  18.00-19.00  sec   112 MBytes   941 Mbits/sec    0   1.36 MBytes
[  5]  19.00-20.00  sec   112 MBytes   941 Mbits/sec    0   1.36 MBytes
[  5]   0.00-20.00  sec  2.19 GBytes   942 Mbits/sec    0             sender
[  5]   0.00-20.00  sec  2.19 GBytes   941 Mbits/sec                  receiver
iperf Done.
[  5] local 192.168.0.3 port 50709 connected to 192.168.0.40 port 5201
[  5]   0.00-1.00   sec  93.7 MBytes   786 Mbits/sec
[  5]   1.00-2.00   sec   112 MBytes   941 Mbits/sec
[  5]   6.00-7.00   sec   112 MBytes   937 Mbits/sec
[  5]   7.00-8.00   sec   102 MBytes   852 Mbits/sec
[  5]   8.00-9.00   sec   107 MBytes   895 Mbits/sec
[  5]   9.00-10.00  sec   112 MBytes   942 Mbits/sec
[  5]  15.00-16.00  sec   112 MBytes   941 Mbits/sec
[  5]   0.00-20.90  sec  2.25 GBytes   926 Mbits/sec    0             sender
[  5]   0.00-20.00  sec  2.16 GBytes   927 Mbits/sec                  receiver
iperf Done.
Raumaster
Mon Mar 18, 2019 5:01 am
I'm using copper SFP. For me it helped, no overuns anymore.
Users browsing this forum: Bing [Bot] and 83 guests
