some changes.
have CCR1009-7G-1C-PC at home right now. My friend recommended me it for better speeds. My ONT is in bridge mode again, PPPoE is in CCR. Speeds are slow again.
There must be something in settings. Have fasttrack enabled.
Any idea please?
I made a decision. Will pay $10 someone how can connect to my computer via Teamviewer and make good settings in mikrotik for me.
Thank you.
filter rules
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; fasttrack
chain=forward action=fasttrack-connection connection-state=established,related
2 ;;; accept established,related
chain=input action=accept connection-state=established,related
mangle
chain=prerouting action=passthrough
1 D ;;; special dummy rule to show fasttrack counters
2 D ;;; special dummy rule to show fasttrack counters
chain=postrouting action=passthrough
nat
0 chain=srcnat action=masquerade out-interface=pppoe-out1
1 ;;; port 1
chain=dstnat action=dst-nat to-addresses=10.31.0.150 to-ports=1234 protocol=tcp in-interface=pppoe-out1 dst-port=1234
2 ;;; synology dsm
chain=dstnat action=dst-nat to-addresses=10.31.0.102 to-ports= 1235 protocol=tcp in-interface=pppoe-out1 dst-port=1235
4 ;;;ssh
chain=dstnat action=dst-nat to-addresses=10.31.0.150 to-ports=1236 protocol=tcp in-interface=pppoe-out1 dst-port= 1236
interfaces
add name=bridge1
set [ find default-name=combo1 ] disabled=yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="Synology DS216play"
set [ find default-name=ether3 ] comment="Debian Server"
set [ find default-name=ether4 ] comment="Apple MacBook Pro 13\" Retina"
set [ find default-name=ether5 ] comment="Apple TV 4 64GB"
set [ find default-name=ether6 ] comment="Mikrotik RB962UiGS"
/interface pppoe-client
add add-default-route=yes default-route-distance=0 disabled=no interface=ether1 name=pppoe-out1 password=MyPPPoEPass use-peer-dns=yes user=MyPPPoEName
add bridge=bridge1 hw=no interface=ether2
add bridge=bridge1 hw=no interface=ether3
add bridge=bridge1 hw=no interface=ether4
add bridge=bridge1 hw=no interface=ether5
add bridge=bridge1 hw=no interface=ether6
