Greetings to all...
I would appreciate if you can give me suggestions how to perform the following configuration with Mikrotik.
I have 4 ports for my LAN on a 192.168.1.X / 24 subnet, each port is connected to an access point. What I need is that they are isolated one port from the other to go to the internet (to WAN), but without losing access to their administration, that is; that from an IP address 192.168.1.X can access another IP address 192.168.1.Y regardless of the port to which it is connected
Example:
Ether2: 192.168.1.1, 192.168.1.3, 192.168.1.5, ...
Ether3: 192.168.1.2, 192.168.1.7, 192.168.1.8, ...
Ether4: 192.168.1.4, 192.168.1.9, ...
Ether5: 192.168.1.6, 192.168.1.10, ...
The idea is to reduce the collision domain to each port (each access point)
I have been able to do it by creating a Bridge on all four ports but the collision domain would be the entire subnet, or am I wrong?
I hope you have explained me well. Regards!
