robertEIT
VPN - Will my setup work? Same subnet on both ends
Sun May 20, 2018 3:32 pm
I'm going to add a RB951G on my LAN at work and create a VPN using the pptp protocol.
What I want is to be able to access my LAN at work with my laptop when I'm roaming and use the local HP network printer wich has a fixed IP (192.168.0.254), access some SMB shares using the IP (//192.168.0.200/Data) etc.
My work subnet is 192.168.0.1/24. DHCP pool is 192.168.0.10 - 192.168.0.199
I'm going to setup my PPTP VPN using this tutorial https://wiki.mikrotik.com/wiki/Manual:Interface/PPTP and give my laptops an IP in the same subnet using addresses left out by DHCP (ex. 192.168.0.201). I use this setup for my home VPN and it works fine.
My question is what happens when for example I'm with my laptop in a place where the local subnet for internet access is also 192.168.0.1/24 wich is common? If I connect to my VPN will I be able to access the resources in my remote LAN or will there be routing issues?
ingdaka
Re: VPN - Will my setup work? Same subnet on both ends
Sun May 20, 2018 4:21 pm
Sure it will work! Just you need to set your VPN interface as default gateway so all traffic will go through VPN!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE | MTCWE | RIPE NCC Certified Professional
robertEIT
Sun May 20, 2018 4:49 pm
My laptops will run Windows 10 and MacBook Pro connecting to VPN over WiFi. I'll try it for a few days. Does connecting to a VPN automatically selects that connection as default gateway in Windows 10 and MacOS or do I have to manually set that up?
CZFan
Sun May 20, 2018 5:43 pm
No it will not work in that scenario
MTCNA, MTCTCE, MTCRE & MTCINE
robertEIT
Sun May 20, 2018 9:23 pm
Ok, so what options do I have? I can't really change the work subnet from 192.168.0.1/24 and I do need a way to access the printer and shares.
Sent from my STH100-2 using Tapatalk
sindy
Sun May 20, 2018 9:57 pm
You can use a pool in a different subnet for the pptp clients, and use dst-nat rules to provide aliases for the devices in the company LAN, and src-nat rules to make these devices respond to the RB's address if the RB is not their default gateway.
I'd be more afraid of problems associated to establishing a PPTP tunnel through a NAT, which must be there as you say the client PC gets an IP from 192.168.0.0/24.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
ingdaka
Wed May 23, 2018 9:45 pm
On MAC it will work just check: Open Network Configurations > Click VPN interface Created > Advanced > Check Send All Traffic Over VPN Connection. I use more than 10 VPN like that for my remote clients and it works perfect!
Ilir Daka
Mob: +355692982151
Users browsing this forum: No registered users and 66 guests
